Author Topic: Cutting a monitor bezel out of foam core board  (Read 7296 times)
Donkbaca
    • Slim built MAME/Xbox cab
« on: April 07, 2011, 04:31:30 pm »
Is hard.
That is all
Re: Cutting a monitor bezel out of foam core board
« Reply #1 on: April 08, 2011, 06:08:19 pm »
It is hard.  You are using the wrong material.  You should use black matteboard (with a black center).  It's way cheaper and way easier to cut than foam board - they make excellent bezels.
Donkbaca
« Reply #2 on: April 08, 2011, 06:21:33 pm »
Thanks for the tip.  I am reasonably pleased with how it looks.  Its not perfect, but I am tinting my glass, so I will see what its like. Thanks for the tip!
« Reply #3 on: April 08, 2011, 10:50:42 pm »
Tinted glass should hide it pretty good.  I used to work with foam core all the time - I hate that stuff.  You need your razor to be super sharp and even then it is hard to get a perfect cut.
DataWest
  • Last login:July 10, 2015, 06:15:35 pm
« Reply #4 on: April 11, 2011, 12:52:33 am »
Hey where do you buy that stuff?
« Reply #5 on: April 11, 2011, 01:30:39 pm »
A.C. Moore or Michael's should carry it - anywhere you can get something framed.  Just make sure you get solid black.  Some matte board has a black exterior but a white interior.  I found a local art store that sold the stuff in 1/4 sheets for like $2 or $3 - too bad they went out of business...
DataWest
« Reply #6 on: April 11, 2011, 01:59:00 pm »
Thanks for the info  :)
Donkbaca
« Reply #7 on: April 11, 2011, 02:22:49 pm »
Yup, I got a huge sheet of it for like 10 bucks.  Matte board is cheaper.
DNA Dan
  • Guys.. we're not talking gold bars here
  • Last login:September 02, 2017, 11:39:00 am
« Reply #8 on: April 11, 2011, 10:52:07 pm »
Hey what's the issue with the foam core when you cut it?
Donkbaca
« Reply #9 on: April 12, 2011, 12:34:02 pm »
its a PITA.  You need a really, really sharp blade, otherwise it doesn't cut cleanly.  I am talking about like swapping razors every 6 or 7 cuts sharp.
DNA Dan
« Reply #10 on: April 12, 2011, 06:17:30 pm »
Can you "smooth" it over with a hot blade? Then once this hardens take some 1200 grit to it to polish it? I guess I am unfamiliar with how dense this foam is. Have a photo?
Donkbaca
« Reply #11 on: April 12, 2011, 06:37:15 pm »
probably not, its just styrofoam sandwiched between 2 sheets of construction paper, or something like that.
« Reply #12 on: April 14, 2011, 10:56:03 am »
Heat of any sort would be a very bad idea when it comes to foam board. You would just destroy it.
DataWest
« Reply #13 on: April 15, 2011, 10:24:08 am »
How thick is matteboard?
Donkbaca
« Reply #14 on: April 15, 2011, 10:25:28 am »
real thin, its like a few cm.
Tumerboy
  • Last login:February 09, 2023, 01:06:11 pm
« Reply #15 on: April 15, 2011, 10:32:39 am »
he means mm
DataWest
« Reply #16 on: April 15, 2011, 10:38:05 am »
Donkbaca
« Reply #17 on: April 15, 2011, 11:00:36 am »
 :angry:
DNA Dan
« Reply #18 on: April 15, 2011, 11:52:55 am »
I think it comes in a few difference thicknesses no? I have seen some art where they layer matte boards as well. Might be interesting to do a satin over flat black play with sheen. You'd have a subtle pinstripe around the monitor.
