Author Topic: Wiring Quesion - Auxilary cable use  (Read 1149 times)
jcutler0902
  • Last login:July 14, 2017, 08:42:56 am
« on: February 23, 2011, 09:21:39 am »
Good morning,
I just purchased a Belkin smart strip. This particular unit has a timer/power on button. The timer/button gets plugged into the smartstip via a male auxiliary plug.
My question is, can I clip off the power button off and wire the ends to a happ button?  I am not sure how many wires would be inside of this particular auxiliary wire.
Any thoughts.  I was going to use it as is, but it would look so much cleaner if I could use a Happ button.
Jason
Re: Wiring Quesion - Auxilary cable use
« Reply #1 on: February 23, 2011, 09:40:24 am »
If the power supply's button uses a momentary switch, I don't see a problem with wiring it to an arcade button microswitch.
BobA
  • What Me Worry?
« Reply #2 on: February 23, 2011, 09:53:59 am »
If it is actually switching the power to the strip directly then it has too high a voltage and is not momentary.  If the plug is large it will probably not be safe.  If it is small then it is probably controlling a lower voltage.  You will have to test with a multimeter to see what is being switched.
jcutler0902
« Reply #3 on: February 23, 2011, 09:55:09 am »
Thanks for the reply.
How would I know it is has a momentary switch?
I have not recevied it yet, but wanted to see if that was a possibilty.
BobA
  • What Me Worry?
« Reply #4 on: February 23, 2011, 10:01:35 am »
You would have to check the end of the timer that plugs into your power stip.   If it is just a contact you can check it with the continuity tester on a dvm.   Do you have a model number or other info so we can see what it looks like?
jcutler0902
« Reply #5 on: February 23, 2011, 10:34:00 am »
Thanks for the help Bob,
Belkin CNS08-T-06 Conserve Surge Protector with Timer (Ivory)
« Reply #6 on: February 23, 2011, 10:39:58 am »
By looking at it, my bet is that it is a momentary microswitch. I wouldn't be affraid to cut that off and wire it to an arcade microswitch.
Donkbaca
    • Slim built MAME/Xbox cab
« Reply #7 on: February 23, 2011, 10:42:43 am »
doubt its a momentary from the description
jcutler0902
« Reply #8 on: February 23, 2011, 10:47:19 am »
Donkbaca,
Lack of knowledge on my part...What makes you say that?
