Author Topic: Problems with Data East SW  (Read 2674 times)
Flake
  • Last login:January 11, 2025, 01:16:20 pm
  • I am Evil Homer....I am Evil Homer....
« on: February 22, 2011, 10:06:45 am »
Some background:
1.  DE SW has been folded up for about 4 months while I was living in an apartment waiting for house to get built.
2.  Machine was moved into new house about a month ago and was working fine initially.
3.  First sign of trouble was while playing a game a couple times the game would seem like it went into tilt mode and would shut down.  The game would not reset and it just kicked out another ball like it would if you tilted it.  Score remained intact as well.
4.  Last night I turn on the game, kick out a ball and it does its tilt mode thing but I also noticed the left flipper doesnt work at all.  I checked the wiring around the flipper best I can, reseated some wiring connectors, etc.  None of this helped and in fact I then had trouble with the start button not working.  After pushing on it several times I did get it to work once.  At this point it was getting late and I had to call it a night.
Questions:
1.  Does this sound like a famaliar problem to anyone?
2.  What would be your first place to look?
3.  Should I just call a pinball repair man?
Q*Bert_OP
  • Oh yes, we did!
Re: Problems with Data East SW
« Reply #1 on: February 22, 2011, 01:57:26 pm »
Make sure the flipper cabinet switches and end of stroke switches are clean. Clean with a business card or alcohol(do NOT file contacts!)
For the "tilt" problem, does it seem like the game is freezing up? Measure the +5v line, report back with readings of BOTH DCv and ACv.
smartbomb2084
  • Last login:January 13, 2021, 03:14:53 pm
  • Having a SMART phone will make you DUMB.
« Reply #2 on: February 22, 2011, 05:56:49 pm »
Check for a broken switch diode in the Matrix starting with the TILT switch.
We all know how a bad Switch Matrix diode can cause all kinds of strange behavior.
Flake
« Reply #3 on: March 14, 2011, 08:58:57 am »
So finally had a chance to revisit this.  Turns out the flipper problem was merely a bad solder joint (thank god).  Played several games with no tilt issue so hopefully that's not a real problem.
Thanks for the suggestions
darthpaul
  • Last login:Yesterday at 07:23:28 am
  • Join, It's your duty
« Reply #4 on: March 26, 2011, 06:05:31 pm »
I also have a problem with my DATA EAST SW machine, when the Death Star opens and I shoot a ball in it, it doesn't always go into tri-ball mode.
Sith Pedestal
Automated Cabinet
Nintendo Pi
PiCubed
Flake
« Reply #5 on: March 26, 2011, 06:36:15 pm »
Sounds like a switch problem to me but I'd have to refer judgment to those more knowledgeable.
