Author Topic: Cocktail cab 32" tv advice  (Read 1726 times)
JayB
  • Last login:January 25, 2013, 06:11:59 pm
« on: February 07, 2011, 08:15:31 am »
Anyone made a cocktail cab using a TV screen? Heat a problem and how do you think the screen would last being orientated on it's back? 28" widescreen for example would that look ok as split screen for P1 & P2?
http://cgi.ebay.co.uk/Panasonic-28-100Hz-TV-stand-crt-excellent-cond-/260731736593?pt=UK_AudioTVElectronics_Video_Televisions&hash=item3cb4d29211
Jay
matsadona
Re: Cocktail cab 32" tv advice
« Reply #1 on: February 07, 2011, 03:13:34 pm »
Are your plan to leave it as is, or shall you remove the plastic housing and have it "naked" inside the cabinet?
The second alternative gives you more options of where to place the chassies board, which is the biggest heat generator.
My personal opinion is to always avoid widescreen CRT's when it comes to arcade games, since none of the original games used that format.
JayB
« Reply #2 on: February 07, 2011, 04:03:32 pm »
Thanks for the reply.
I'm just seeing if it's a sensible option really. I'd probably leave it housed as is. Only thought that with it being widescreen it would equal out better for split screen view. I could be wrong in thinking that however  :D
NoBullMAME
  • Last login:April 11, 2011, 11:23:34 am
  • Author, The No Bull MAME Guide
    • No Bull MAME Guide Blog
« Reply #3 on: February 07, 2011, 05:21:45 pm »
If you are setting it up as a dedicated slip-screen cocktail cab, I guess it might work. I'd make sure I played around with games in slit-screen first, to make sure you like the way it looks. I haven't used split-screen, except to check it out. Maybe there's a forum member out there with this type of setup?
However, if this is your only cocktail cabinet, I'd go with an old 4:3 CRT; it just works better for almost every game (except maybe games  set for split-screen).
Author,The No Bull MAME Guide Intro priced at: $2.99
JayB
« Reply #4 on: February 08, 2011, 06:46:38 am »
yeah I was sort of hoping someone may have gone that route with a widescreen.
I have an upright cab but I think you're probably right.
