Author Topic: my new problem...  (Read 1218 times)
jolietcr14
  • Last login:January 31, 2011, 01:21:53 pm
my new problem...
« on: January 25, 2011, 10:19:50 pm »
just swapped mk3 board for sf hyper fighting...cant seem to access my menu to put on free play...manual says there is a switch in the  coin door but after drillin out locks ..opened the door and see no switch....im sure its an easy explanation but this is my first board swap!!!...
Re: my new problem...
« Reply #1 on: January 25, 2011, 10:39:59 pm »
Just wire up a switch to the pins on the board for the switch that is supposed to be behind the coin door.
BobA
  • What Me Worry?
« Reply #2 on: January 25, 2011, 11:18:29 pm »
You might already have a test switch somewhere in you cab. Check the jamma connector to see if one is already wired.
jolietcr14
« Reply #3 on: January 26, 2011, 11:03:26 am »
FIGURED IT OUT...YOU SET THE DIPSWITCHES...THANKS GUYS
