January 30, 2026, 08:36:41 am
You can switch your jpac with a jamma switcher but if you have wired any of the additional buttons directly to the jpac they will not switch.
On a jpac does'nt the video go like a regular vga cable from the pc to the jpac and then like regular jamma to the monitor.
I have done it with Clay's MultiJAMMA kit and it worked fine.The only issues have to do with things that fall outside of the JAMMA standard -- extra controls (extra buttons, sticks, trackball, etc.) and amplified audio come to mind.
Quote from: CheffoJeffo on January 25, 2011, 03:05:04 pmI have done it with Clay's MultiJAMMA kit and it worked fine.The only issues have to do with things that fall outside of the JAMMA standard -- extra controls (extra buttons, sticks, trackball, etc.) and amplified audio come to mind.Did the amplified audio work when the Jpac was active?
