Author Topic: Two-Headed Beast -- Finished  (Read 188633 times)
Re: Two-Headed Beast MAME Conversion
« Reply #360 on: July 20, 2012, 03:11:58 pm »
Holy ---steaming pile of meadow muffin---, 10 pages! :dizzy:
I wired up that VGA breakout board this morning (boring stuff, I know). Went really smooth and it looks a lot cleaner inside the cab without those hacked VGA cables. Here's a shot of the rat's nest that is my interface panel:
I'm going to run longer power harnesses for the monitors as well as their earth ground, so that they can be zip tied back out of the way. Once that's done, I'll put up some pics of under the hood...
I just posted the Beast over on the Hyperspin forums the other day. I took some new pics to post over there and thought I'd drop 'em off here for those that don't frequent those boards.
The last one was taken while the HS wheel was on the SNES bootleg for Killer Instinct (and before my last monitor repairs). Only because it lights up the majority of all the buttons and joysticks. Those are also what I have set for MAME's default control colors.
« Last Edit: July 20, 2012, 03:14:32 pm by Nephasth »
Woodshop Flunky
« Reply #361 on: July 20, 2012, 07:46:30 pm »
Wow!  I really... really like this build!  Everything looks top notch.  But even more than the quality and creativity of your cab... it just looks like it would be a blast to play with a friend!
Excellent job!  :cheers:
TopJimmyCooks
« Reply #362 on: July 20, 2012, 10:32:39 pm »
Looks like it's ready for a reveal vid.   8)
MacGyver
  • Last login:December 18, 2023, 12:49:00 am
    • Project Build
« Reply #363 on: July 26, 2012, 04:22:19 pm »
I think I see a short in the black wire.  >:D
Seriously though, that is an impressive wiring job.  It looks like a jet fighters wiring harness (only in black).
My idea of cord control is a well placed zip-tie here or there. At least I know now not to post the underside of my control panel.  :notworthy:
« Reply #364 on: August 01, 2012, 04:39:54 pm »
Thanks a lot for the kind words guys! :cheers:
I decided to make a little video showing the Beast in operation. It's by no means perfect (hey, it's a Beast), but it has come a long way. I've just started messing around with different cabinet animations and really need to take some time to site down and make some new ones and some more game specific ones. Right now I only have a game specific cabinet animation for Mortal Kombat. I just threw something together pretty quick to see how it works. The video quality sucks and the volume is low, so you may want to turn up the volume on your end (no devil music this time :angel:). But this will give you a good idea what the cab is like during use.
Getting closer. This isn't the "reveal" video. ;)
millercentral
  • Last login:March 07, 2024, 04:38:47 pm
« Reply #365 on: August 05, 2012, 01:39:43 am »
As so many others have said, this really is an inspirational project. The button "light rings" are the coolest use of LEDs on a cabinet I've seen yet, I'm definitely going to steal that idea for my cab refresh.
One (unrelated) question... How do you manage the dual screens? Are you mirroring the the output, or only using the second screen side for dual screen games?
  • Last login:Today at 01:55:45 am
« Reply #366 on: August 05, 2012, 02:06:46 am »
Nep's running the same video signal to both screens using a VGA splitter described in his posts here and here.
« Reply #367 on: August 05, 2012, 11:15:02 am »
Thanks miller! As PL1 said, both screens are mirrored. The second side is actually the side players 2 and 4 play on. I'm glad I laid the players out like this, otherwise I don't think the second side would have hardly got any play.
mytymaus007
« Reply #368 on: September 19, 2012, 04:07:35 pm »
Looks awesome great job! Just wondering what USB devices you have that are conflicting with HS
« Reply #369 on: September 19, 2012, 04:49:38 pm »
My USB controllers are conflicting with HS. I've got a Lono2 and 2 U360s. The problem goes away when all three are unplugged, but when I plug in just one (doesn't matter which) HS stutters on startup. Apparently it's a known issue.
mytymaus007
« Reply #370 on: September 19, 2012, 08:47:46 pm »
Thats ashame I hope HS guru's are on it. I was thinking about getting u360 but i might hold off. the last time my HS stuttered like that is when i had a my weak AMD system sure enough threw that away what a waste :lol Been running 200% ever since i upgrade to a i5 core 2500k  :cheers: Good Luck!! and nice work!
« Reply #371 on: September 19, 2012, 09:01:18 pm »
The HS team isn't working on HS anymore. But they are working on HS2 and supposedly this issue has been corrected. Now it would just get released... :-\
The stuttering doesn't really bother me. I turn the machine on and go play a few games of skeeball while I'm waiting for it to do its thing.
« Reply #372 on: September 20, 2012, 02:50:14 pm »
Did you ever get a light gun to test out?
« Reply #373 on: September 20, 2012, 06:11:28 pm »
No, they ended up being composite guns, not VGA. AimTraks someday...
patm95
  • Last login:January 11, 2026, 10:16:48 pm
« Reply #374 on: October 06, 2012, 12:13:16 pm »
I love that video.  I am loving those LEDs.  That is perfect with the two monitor setup doing multiplayer.
« Reply #375 on: October 06, 2012, 12:23:16 pm »
Hey Neph
One thing I noticed in the Vid is that your button led's seem to fade in and out +while+ windows is booting up.
I must have missed something in your build thread. Do you have an arduino or something controlling the LEDS on boot? Or is that some feature of the particular LED controller you're using?
And definitely great use of LEDs on those invader cutouts. I love that effect!
« Reply #376 on: October 06, 2012, 12:54:36 pm »
Thanks for the compliments guys! :cheers:
Hey Neph
Hmm, I guess I never discussed that animation in this thread. I use PACLED64s for my CP lighting. One feature of Andy's LED controllers is that they have the ability to run a programmed animation without the presence of a computer, as long as they have a power source. The animation you're seeing while the computer is booting up is the stock animation programmed into the PACLED64s. The end user can program in their own animation if they so wish. Can't do this with my cabinet lighting though, as they're ran off of an LED-Wiz...
« Reply #377 on: October 06, 2012, 01:57:11 pm »
I have great respect for the LED work and others do (Santorini comes to mind) however I can't seem to bring myself to include it in any designs I do.  Perhaps I'll eventually do a low boy with no art that is centered around lighting.  It seems that when you mix lights and art one over powers the other.  Yours, as with other great lit cabs, really highlights the lighting and form.  Kuddos for finding the right mix.
« Reply #378 on: October 06, 2012, 02:31:29 pm »
Ah, that would explain it. Yeah, i'm using 3 ledwiz 32's so no cool power on anims for me. (unless it convert to a pacled, I guess).
Good to know, in any case. Thanks!
Re: Two-Headed Beast -- Finished
« Reply #379 on: November 05, 2012, 05:29:15 pm »
FINISHED!
Finally got around to cleaning up the wiring inside the cab...
Here's a slideshow style video covering the progress of the project:
Somehow, the last part of the credits got cutoff during the conversion of the video, here are the ones that were left out:
Mamefreak2
MacGyver
Millercentral
Mytymaus007
Patm95
PBJ... RIP
And the rest of BYOAC!
The Beast is finally finished. :) There will be no more updates to this thread, unless I ever get around to adding guns to the cab. Thanks again everyone!
« Reply #380 on: November 05, 2012, 05:56:31 pm »
And I made the credits!!  :woot
« Last Edit: November 05, 2012, 05:58:36 pm by yotsuya »
« Reply #381 on: November 05, 2012, 06:16:20 pm »
no love for me :(
looks good bro!
« Reply #382 on: November 05, 2012, 06:24:49 pm »
no love for me :(
looks good bro!
You're 3rd on the list under Inspiration and Motivation! ;)
selfie
« Reply #383 on: November 05, 2012, 06:25:05 pm »
This cab is an amazing conversion with epic wiring.  :notworthy: :notworthy:
« Reply #384 on: November 05, 2012, 06:27:47 pm »
Thanks selfie! :cheers:
Woodshop Flunky
« Reply #385 on: November 05, 2012, 06:31:01 pm »
I've said it before, but this is a top-shelf build.  :cheers:
I like to show my son the amazing cabs on this forum, but I can't show him this one.  If I did, he would wheel his back into the shop and demand I build another and join the two together.   ;D
Again... great job!
Well Fed Games
  • Delicious!
« Reply #386 on: November 05, 2012, 08:16:32 pm »
Truly a work of art! As been said many times, the metal CPs + LEDs is inspired. Love the summary video too!  :cheers:
« Reply #387 on: November 05, 2012, 08:42:58 pm »
Finished?  :laugh2:
They are NEVER finished.  >:D
jk, EPIC build!!!!!!!
« Reply #388 on: November 05, 2012, 08:44:46 pm »
no love for me :(
looks good bro!
oh yeah there I am! missed it the first time. I got left off of Pixelhuggers's credits for not doing anything, I didnt want it to happen again, lol
Im almost as happy as you are that the cab is done, HALL OF FAME for lightning and 2 monitor set ups IMO
« Reply #389 on: November 05, 2012, 09:08:14 pm »
Nice vid.
And even nicer cabinet!  :applaud:
Those glowing invaders are the perfect touch, and they work even while the cab is booting.   :notworthy:
Pure Sweetness.
« Reply #390 on: November 05, 2012, 10:09:28 pm »
Again... great job!
 :lol The reactions kids get from seeing this the first time make it all worth it. Many thanks on the compliments, but I do feel like I cheated a little since build required practically zero woodworking skills...
Thanks! Early on I planned on CPOs, but after getting the CPs from DMEN, there was no way I could cover up that beautiful metal. :cheers:
Finished?  :laugh2:
 ;D Nope, but you got to draw the line somewhere. It's been "done" for months and getting used frequently, but the loose ends have finally been tied up. Looking forward to tweaking the Beast down the road though! ;)
I wouldn't forget ya! I'm still wanting to copy you stuffing large monitors in tight spaces... 8)
Nice vid.
Pure Sweetness.
Thanks drventure! Just a quick note, the invaders don't light during the booting process, they're on the LED-Wiz.
« Reply #391 on: November 05, 2012, 11:39:23 pm »
Doh. I meant the button lights. Regardless, cool effect.
TalentedM
  • Last login:August 05, 2014, 11:15:52 pm
« Reply #392 on: November 06, 2012, 05:31:23 am »
 :notworthy: Great job! Looks amazing!
jmike
« Reply #393 on: November 06, 2012, 07:16:49 am »
 :applaud: :applaud:   :notworthy:
Absolutely amazing work Nephasth. Has it really been 2 years? I still remember asking you for the Run and Gun 2 board when you were trying to sell them. I think this is one of the best (if not the best) wiring job I've ever seen. Thanks for including me in the credits.
On to the next one   ;)
« Last Edit: November 06, 2012, 07:22:14 am by jmike »
lcmgadgets
« Reply #394 on: November 12, 2012, 08:24:22 am »
Omg. That is absolutely amazing. Sigh...
Professor Hayashida
TopJimmyCooks
« Reply #395 on: November 12, 2012, 08:56:13 am »
Really good stuff.  My favorite 4 player I've seen.
Santoro
  • Santoro
  • Trade Count: (+32)
  • Boycott Quarters!!!
    • ArcadeReplay!
« Reply #396 on: November 12, 2012, 03:26:13 pm »
!nice!
AzureKnight
« Reply #397 on: December 25, 2012, 01:04:45 am »
This is some very nice work, I was a huge Tournament Cyberball player back in the day and I have to say...seeing the cabinet come back to life in this fashion is incredible.  Very nice work!
-AK
a1pharm
« Reply #398 on: January 20, 2013, 06:29:21 pm »
 :notworthy:  ...Wow...  just... wow...  :notworthy:
kahlid74
  • Gaming for a better future!
    • GamersAnon
« Reply #399 on: January 21, 2013, 10:28:31 am »
Great stuff indeed man!  Inspiration for a great project!
