Author Topic: Running XP with a wide screen  (Read 1225 times)
eds1275
  • Last login:Yesterday at 10:59:00 am
  • Rock and Roll!
« on: January 16, 2011, 12:13:35 pm »
What I want to do is this:
Run windows xp
on a 26" widescreen with a widescreen desktop resolution
Run Mala and Mame not widescreen and not stretched - well, mala could be widescreen if possible but I don't think it is supported
Is this possible?
The reason being that my machine is going to double as a second tv for the house, and I was going to have the Blue-Ray drive right inside the coin door as well as running Netflix. My machine is going into the lounge of my recording studio that also doubles as a guest bedroom.
nitz
  • Last login:November 24, 2015, 07:57:29 pm
Re: Running XP with a wide screen
« Reply #1 on: January 16, 2011, 03:58:35 pm »
Yep, it's possible, just set the aspect ratio in mame.ini to 16:9 (that should be what your tv is) and the games will be pillarboxed so you have the correct aspect ratio.
As for mala, the way I did this was by making a layout at the resolution of my display, but I only use the area of the screen that's in the 4:3 "box" if that makes sense. I just filled in the rest with black which gives you a pillarboxed image.
