Author Topic: Donkey Kong sounds  (Read 1434 times)
zcabrage
  • Last login:August 30, 2011, 05:42:36 pm
Donkey Kong sounds
« on: November 18, 2010, 11:03:29 pm »
I have been away from my cabinet for a while. Today I went to play Donkey Kong and there were no sounds at all, but I know they were there when a played about a year ago. I don't believe I changed anything but I could be wrong  :angry: So after some searching I found that it could be the samples were not in the samples directory, although there is some debate as to if they are needed with the later versions of MAME. So I downloaded the samples and put them in the samples directory and I now get the jumping, running and stomping sounds but there is no background sounds. Does anyone know what I am missing? I don't remember ever having the samples installed before so I don't really think that is what the problem is. Thanks for your help.
Ed G.
Re: Donkey Kong sounds
« Reply #1 on: November 19, 2010, 01:01:55 am »
We need more info.  What version of MAME are you running?
Also what OS?
zcabrage
« Reply #2 on: November 19, 2010, 07:45:23 am »
Thanks for the response. I was in a hurry last night as I was looking things over. I have Win XP and Mame .102. Based on my investigation last night it seems I need the samples with that version of Mame but I know this was working before and I don't recall loading the samples and can't imagine why they would be gone now. Also, I have the samples working but there is no music. Like I said in my original post it has been at least a year since I messed with the anything, I know I never changed MAME or the ROMs. I was playing around with different front ends. I am using MAMEWah and always had been. I just don't know what else may have changed. Looking for any ideas. Thanks,
« Reply #3 on: November 19, 2010, 04:04:23 pm »
Also posting your mame.ini may help as well.
D
zcabrage
« Reply #4 on: November 20, 2010, 10:24:37 am »
Thanks for helping D, here is the mame.ini
### mame.ini ###
### Frontend Related ###
### Windows path and directory options ###
rompath                 roms
samplepath              samples
# inipath               <NULL> (not set)
cfg_directory           cfg
nvram_directory         nvram
memcard_directory       memcard
input_directory         inp
hiscore_directory       hi
state_directory         sta
artwork_directory       artwork
snapshot_directory      snap
diff_directory          diff
ctrlr_directory         ctrlr
cheat_file              cheat.dat
### Windows video options ###
autoframeskip           0
frameskip               0
waitvsync               0
triplebuffer            0
window                  0
ddraw                   1
direct3d                0
hwstretch               1
# screen                <NULL> (not set)
cleanstretch            auto
resolution              640x480
refresh                 0
scanlines               0
switchres               0
switchbpp               1
maximize                1
keepaspect              1
matchrefresh            0
syncrefresh             0
throttle                1
full_screen_brightness   0.000000
frames_to_run           0
effect                  none
screen_aspect           4:3
### Windows Direct3D 2D video options ###
zoom                    2
d3dtexmanage            1
d3dfilter               1
d3dfeedback             0
d3dscan                 100
d3deffectrotate         1
d3dprescale             auto
d3deffect               none
# d3dcustom             <NULL> (not set)
# d3dexpert             <NULL> (not set)
### Windows misc options ###
sleep                   1
rdtsc                   0
high_priority           0
### Windows sound options ###
audio_latency           1
# wavwrite              <NULL> (not set)
### Input device options ###
mouse                   1
joystick                1
lightgun                0
dual_lightgun           0
offscreen_reload        0
steadykey               0
keyboard_leds           1
led_mode                ps/2
a2d_deadzone            0.300000
# ctrlr                 <NULL> (not set)
paddle_device           keyboard
adstick_device          joystick
pedal_device            keyboard
dial_device             keyboard
trackball_device        mouse
lightgun_device         keyboard
digital                 none
### Mame CORE video options ###
norotate                0
ror                     0
rol                     0
autoror                 0
autorol                 0
flipx                   0
flipy                   0
gamma                   1.000000
brightness              1.000000
pause_brightness        0.650000
### Mame CORE vector game options ###
antialias               1
translucency            1
beam                    1.000000
flicker                 0.000000
intensity               1.500000
### Mame CORE sound options ###
samplerate              44100
samples                 1
sound                   1
volume                  1
### Mame CORE misc options ###
artwork                 1
use_backdrops           1
use_overlays            1
use_bezels              1
artwork_crop            0
artwork_resolution      0
cheat                   0
debug                   0
# debugscript           <NULL> (not set)
# playback              <NULL> (not set)
# record                <NULL> (not set)
log                     0
oslog                   0
skip_gameinfo           1
bios                    default
# state                 <NULL> (not set)
autosave                0
### Configuration options ###
readconfig              1
verbose                 0
