Author Topic: Galaga Bartop (99.9 percent done with pics) Update 11/16/2010  (Read 29245 times)
The Evil Collector
  • Last login:April 25, 2011, 06:12:22 pm
Re: Galaga Bartop (Now with assy pics)
« Reply #40 on: November 09, 2010, 04:54:01 pm »
Combo combo combo  ;D
BobA
  • What Me Worry?
« Reply #41 on: November 09, 2010, 05:00:26 pm »
Back to actual construction.  Gathering up the parts to put into the cab and finishing various pieces.
First pic: LCD screen that is going to be used.  Stripped down to screen and bezel.
Second pic: Control panel with button and joystick holes drilled.  Coin button and speaker to be mounted on the front of the cab under the CP. Light for marquee.
Third pic: Test rig and other buttons connected to jamma harness to test the function of the circuit board.  Unused wires cut back as they take up alot of space and probably will never be required.
Fourth pic: Exhaust fan mounted in panel at the top of the back.
Not shown ATX power supply to power the whole bartop. Power on jumpered to GND so the supply can be turned on and off with the PS switch. Marquee light, coin light, LCD monitor, fan and circuit board all connect to 4 pin drive connectors.
« Last Edit: November 09, 2010, 07:01:54 pm by BobA »
« Reply #42 on: November 09, 2010, 07:05:28 pm »
C-C-C-C-COMBO BREAKERRRR
BobA
  • What Me Worry?
« Reply #43 on: November 09, 2010, 10:28:10 pm »
Speaker and fan mounted. Going to have to clean cab and touch up some spots when complete.   Thought I would get the hardware in then design the graphics around it.
That is it for tonight. :cheers:
« Last Edit: November 09, 2010, 10:32:31 pm by BobA »
BobA
  • What Me Worry?
« Reply #44 on: November 10, 2010, 05:05:31 pm »
Installed buttons and joystick on control panel.
ids
  • Fighter Captured
« Reply #45 on: November 10, 2010, 05:18:05 pm »
Great build!
I vote galaxian (waiting for leapinlew to have aneurysm)
Just kidding, dedicated galaga.  I like the 30'th anniv cab, but that's too much artwork for a bartop, imho.  And then there's Galaga - what other game is there?  People might ask what those other characters are?  Were they in a game?  :laugh:
BobA
  • What Me Worry?
« Reply #46 on: November 10, 2010, 05:36:30 pm »
Great build!
Pac-Man's Arcade Party
30 Anniversary Edition
Comes with (13) Thirteen Classic 80's Video Games : Pac-Man, Ms. Pac-Man, Pac-Mania, Galaga, Galaga '88, Bosconian, Dig Dug, Dragon Spirit, Galaxian, Mappy, Rally X, Rolling Thunder and Xevious all in one cabinet !
ids
  • Fighter Captured
« Reply #47 on: November 10, 2010, 05:46:05 pm »
Sorry - something got lost in the translation between the voice in my head and the text i typed.  I was kidding - I do know the other games.  Just having some fun along the lines of "what other games exist?" when you have Galaga.
But since I'm here, another vote for dedicated Galaga.
Tho, that 30'th anniv cab would look nice next to my imaginary pins, skeeball, pool table, etc, in the imaginary game room i imagine i have  :)
« Reply #48 on: November 10, 2010, 10:13:50 pm »
No angle on the CP? Bob, live a little man!
And I like Galaxian ok the problem with it is the slow game play, poor sound effects, static levels, and no challenge stages. Other than that though, awesome game.
abispac
  • Last login:March 18, 2026, 11:03:14 pm
« Reply #49 on: November 10, 2010, 10:45:54 pm »
Hey boba, what joystick are you using? thanks.
BobA
  • What Me Worry?
« Reply #50 on: November 10, 2010, 10:58:14 pm »
Using a Magstick Plus top switchable 4/8.
BobA
  • What Me Worry?
« Reply #51 on: November 10, 2010, 11:00:10 pm »
Screen mounting time.   The bare screen did not have any Vesa mounting holes so I had to open it up and drill holes to screw the screen to the support.
Screen mounted showing back and front.
BobA
  • What Me Worry?
« Reply #52 on: November 10, 2010, 11:08:33 pm »
Good point.   I will give it a try flat and see what it feels like.  I can put it on an angle by unscrewing the back of the panel and lifting it a bit. I will give it a try too.  Good thing the screen is floating.  My original mounting idea would have had it supported by the control panel.
Thanks leapinlew
Edit:  As per leapinlew's suggestion gave the panel about a 5 degree rise for an angle. It is hard to see in the picture but it now has a definite slope.  Also lined the marquee top and bottom shelves with metalized tape for better light reflection.
« Last Edit: November 11, 2010, 12:52:49 am by BobA »
BobA
  • What Me Worry?
« Reply #53 on: November 11, 2010, 10:00:54 am »
Here we go today.  If I don't run into any unexpected problems it will be running by this evening.
Mounted circuit board in cab and attached jamma harness.
Left to do:
Mount Power supply
Connect buttons and joystick
Mount marquee light
Mount back panel with hinge and lock
« Last Edit: November 11, 2010, 10:04:14 am by BobA »
BobA
  • What Me Worry?
« Reply #54 on: November 11, 2010, 03:47:29 pm »
Buttons and joystick connected.   Service and Test buttons added to interior of cabinet.
Jamma harness tie wrapped and made neat.
Power supplied wired in but not strapped down yet.
It's alive!
GALAGA!
Total time elapsed since original post 7 days.
« Last Edit: November 11, 2010, 03:51:21 pm by BobA »
BobA
  • What Me Worry?
« Reply #55 on: November 11, 2010, 04:00:34 pm »
Now that it is running it is time to finalize the to do list.
Mount Power supply (strapping) DONE
Mount marquee light (HD double sided tape used to mount touchscreens) DONE
Mount back panel with hinge and lock probably add some wood or mdf stops DONE
Cut and install plexi for bezel DONE
Cut and install plexi for marquee DONE
Artwork for marquee, side and control panel. DONE
This is the last little bit that always seems to take the longest.
Have to go play some Galaga. :cheers: :cheers:
« Last Edit: November 16, 2010, 08:13:07 pm by BobA »
« Reply #56 on: November 11, 2010, 04:04:10 pm »
We'll check on you in a couple months, to see when you're ready for your next update.
BobA
  • What Me Worry?
« Reply #57 on: November 11, 2010, 04:12:35 pm »
Hopefully it will not be that distracting since I have a full featured bartop with MAME and other emulators.  This unit is actually a present for a family friend so I had to make sure I got a jump on it to be finished for Christmas  ;D ;D
« Reply #58 on: November 11, 2010, 04:15:19 pm »
You're the lucky one.  I have promised myself I won't wire up the joysticks and buttons until the entire cab is ready.  Let's see how long that lasts.
Bender
« Reply #59 on: November 11, 2010, 10:48:53 pm »
looking sweet!!! It's like a twin of one I built
I have art for the Marquee, side, CP and Bezel PM me the dimensions and I think I can hook you up
« Reply #60 on: November 11, 2010, 11:25:18 pm »
Looks good. The only issue I have is the clarity of the LCD with Galaga. It's just a little too sharp. Know what I mean? Not much you can do about it. It's one of the few games I prefer a CRT with.
BobA
  • What Me Worry?
« Reply #61 on: November 12, 2010, 03:27:50 pm »
I use the scientific additive method to reduce the sharpness.   Just add BEER  :cheers:
Re: Galaga Bartop (95 percent done with pics)
« Reply #62 on: November 12, 2010, 03:35:21 pm »
Just remember, when the display suddenly disappears (this has been known to happen with this method) rotate 180 degrees.
BobA
  • What Me Worry?
« Reply #63 on: November 15, 2010, 05:28:00 pm »
Went with a combo look.  Pac-man and Galaga art.  Hate the split front panel on anniv cabs so I just left it alone for now.
So here it is at about 98 percent done.
Finished back panel.  Used a cutout for the ATX power supply so I could use it's AC cord and on/off switch.  Fan is reversed to blow air in and the fan at the top of the cab blows air out.
Pac-Man art for the left side of cab.
Galaga art for the right side of the cab.
Combo marquee for Pac-Man and Galaga.  I know - wrong game on screen  :D
Total elapsed time 11 days
« Last Edit: November 15, 2010, 06:43:02 pm by BobA »
Encryptor
  • Trade Count: (+34)
Re: Galaga Bartop (98 percent done with pics) Update 11/15/2010
« Reply #64 on: November 15, 2010, 05:41:25 pm »
Very nice machine Bob.  :notworthy:
Encryptor
IG-88
« Reply #65 on: November 15, 2010, 06:47:51 pm »
Never thought about reversing the PSU fan. How hard was that to do?
-HarumaN
BobA
  • What Me Worry?
« Reply #66 on: November 15, 2010, 06:51:23 pm »
It only takes a few minutes.  The fan is held in by self tapping screws from the outside.  Remove those and the top and sides (1 piece) of the power supply.  Usually you can slide the fan around and reattach using the self tapping screws.
IG-88
« Reply #67 on: November 15, 2010, 06:53:18 pm »
Brilliant!!   :cheers:  :applaud:
-HarumaN
jmike
« Reply #68 on: November 16, 2010, 07:01:33 am »
 :notworthy:  :notworthy:
Amazing work as always BobA! What front end are you using?
BobA
  • What Me Worry?
« Reply #69 on: November 16, 2010, 08:52:07 am »
There is no front end required as the circuit board has it all built in.
« Last Edit: November 16, 2010, 08:55:40 am by BobA »
BobA
  • What Me Worry?
Re: Galaga Bartop (99.9 percent done with pics) Update 11/16/2010
« Reply #70 on: November 16, 2010, 08:15:19 pm »
Bezel installed. Completed   ;D
Total time elapsed 12 days
Thanks for all the comments!
« Last Edit: November 16, 2010, 08:20:58 pm by BobA »
Termin8tor
  • Last login:August 04, 2020, 01:54:23 am
« Reply #71 on: November 17, 2010, 04:02:23 am »
Excellent work, congratulations on a stunning bartop. 8)
jipp
« Reply #72 on: November 17, 2010, 02:07:06 pm »
looks great.  keep up the good work :)
chris.
  • Last login:Yesterday at 10:31:51 am
« Reply #73 on: November 17, 2010, 06:20:50 pm »
Are all of these games on that same PCB? I don't really see how Rolling Thunder fits in, as it's horizontal.  ??? Also, do all games run perfect, i.e. is this a recommended product?
BobA
  • What Me Worry?
« Reply #74 on: November 17, 2010, 08:14:20 pm »
That list has not been verified as the actual 30 Anniv cab has not been released as far as I know.  The list was only from the advertising.
« Reply #75 on: November 18, 2010, 08:45:03 am »
Thanks! I totally misread that post and thought that it was describing the PCB that you've used in your bartop. Would be really sweet to buy an official JAMMA multi-PCB with those titles running perfectly. *drools*
