Author Topic: MAME .140  (Read 9748 times)
Donkbaca
    • Slim built MAME/Xbox cab
MAME .140
« on: October 22, 2010, 01:54:24 pm »
So does this mean I need to update my roms from .139?
Ginsu Victim
  • Comanche, OK -- USA
Re: MAME .140
« Reply #1 on: October 22, 2010, 02:41:53 pm »
Yes, but if you download a torrent of them, you can overwrite only the new and updated files. Much easier.
Donkbaca
Re: MAME .140
« Reply #2 on: October 22, 2010, 02:52:32 pm »
I had Mame .120 and when I went to get the .139 torrent, I thought it would only download the files that I needed, but it ended up downloading all 24 gig.  Did I do something wrong?  Why did it download everything all over again?
OverRide
  • Last login:May 04, 2023, 08:06:52 pm
Re: MAME .140
« Reply #3 on: October 22, 2010, 03:25:46 pm »
Cause your torrent client has no idea what files you need or dont need.
You need to run a rom manger like clrmamepro against the latest MAME exe and your current rom set. It will tell you what roms need updating. Then you need to slect only the roms you want when you start your torrent download.
WhereEaglesDare
    • My HomePage
Re: MAME .140
« Reply #4 on: October 22, 2010, 04:01:03 pm »
Unless you really really want to you do not need to update to 140, you can stay at 139 for years and be happy.
Ginsu Victim
Re: MAME .140
« Reply #5 on: October 22, 2010, 04:26:56 pm »
Just tell the torrent to save where the roms are and it will overwrite only the files that need it, and download any new ones you don't have.
You're making it more difficult than it is...
Donkbaca
Re: MAME .140
« Reply #6 on: October 22, 2010, 04:48:13 pm »
I must be doing something wrong, the torrent I downloaded loos like it had like 50 different .rar files.  Can anyone point me to a simple explanation on how to update roms?  I am not asking for a site to get the roms mind you, just the process of updating.
I had .120, pointed my torrent for .139 to the my roms folder thinking it would just download the files I needed, then I was going to get rid of unneeded files with Clrmamepro.  But the torrent downloaded all 24 gig and now .140 just came out and I just finished getting .139 off my torrent.  So, what should I do to update to .140 to keep me from having to get the whole romset all over again?
THanks you all.
« Last Edit: October 22, 2010, 04:49:58 pm by Donkbaca »
shateredsoul
  • Last login:January 25, 2013, 08:23:51 pm
Re: MAME .140
« Reply #7 on: October 22, 2010, 04:53:47 pm »
I've decided to not update from 135 until there's some major improvement (i.e. naomi or sega model 3). I really see not reason to update.
Ginsu Victim
Re: MAME .140
« Reply #8 on: October 22, 2010, 05:18:56 pm »
It needs to be a torrent that isn't in big rars, just the roms in their standard zipped romsets.
Dazz
  • HyperSpin Team
    • VPUniverse
Re: MAME .140
« Reply #9 on: October 22, 2010, 05:36:57 pm »
The issue with connecting to an existing torrent and overriding your roms is that files that you don't need are still there.  Eventually you'll have a lot of files that you no longer need because they were re-named or added to existing sets.
The correct thing to do is to download the .140 update set.  Then run the set through CLRMamePro, using your MAME .140 exe and use the Re-Builder to merge your updates with your current set.
Donkbaca
Re: MAME .140
« Reply #10 on: October 22, 2010, 06:13:01 pm »
But couldn't you use CLRmamepro to scrub out the unneeded files?
WhereEaglesDare
    • My HomePage
Re: MAME .140
« Reply #11 on: October 24, 2010, 12:24:29 am »
Look you should just download a whole new set and delete your old set, some individual roms have had updates had that is the best way.
Hoopz
  • Last login:November 16, 2025, 09:21:03 am
  • Intellivision Rocks!
Re: MAME .140
« Reply #12 on: October 24, 2010, 07:16:36 am »
That's not the right or non-idiotic way to do it.  As others have said, you can download the new set on top of the old set.  Your torrent program will only download the new/changed files.  This is the easiest and smallest download way to upgrade.  The downside is you do end up with leftover files that aren't used once you upgrade a few times.  Over time, it can become quite a lot of files.  The size of the files may not be important as hard drive space is much larger than a few years ago.
You can use clrmamepro to "fix" your set if you want.  People that are serious about rom management should learn clrmamepro.  There are a number of tutorials that can be watched to help you through it.  It's gotta a learning curve, but once you do it once or twice, it's pretty easy.
Personally, I don't upgrade (anymore) once a new set comes out.  If there is something specific that I want, I will either download and upgrade OR download the rom in question and the new version of Mame.  It's almost easier to setup a different version of Mame in your front end for one or two games than upgrading your rom set.
There are really just a few reasons that roms change or get added in Mame.  One is a new rom for a new game is added.  The other is that a rom changes to fix a bug, create better emulation, etc.  Sometimes this slows down Mame so a game that ran fine before on an older system, will run more slowly.  The other thing that occurs is that Mamedevs make changes to the sound or video structure that affects how Mame works on older PCs.  I'm not bitching though, just stating what's happened in the past.
I would ask what's your reason to upgrade.  If it's just to get the newest and best set, then take the time to do it the right way.  If you are going to be doing this every time Mame changes, do it the right way. It will quickly become the easiest way.  If you're just upgrading to get a new game, download the rom(s) needed for that game and the new version of Mame.  Add it as another emulator in Mame and you're set.
huygens
  • Last login:October 31, 2011, 01:33:08 am
Re: MAME .140
« Reply #13 on: October 24, 2010, 01:52:01 pm »
At least on my client uTorrent, just pointing to your current directory will result in all your files being overwriten.
You need to:
Run old set through clrmamepro with .140 dat to rename files
download torrent file and point it to rom directory (but deselect "start torrent" checkbox)
now select "force recheck" and the client will compare the directory files to the torrent content.
If all is well and it says above 90% completion, start the torrent downloading.
WhereEaglesDare
    • My HomePage
Re: MAME .140
« Reply #14 on: October 24, 2010, 03:01:31 pm »
Yo momma
Donkbaca
Re: MAME .140
« Reply #15 on: October 24, 2010, 03:33:04 pm »
FYI - situation is this:
I am building a cab, and the version of mame u was running before was .120. I have want lightguns ( already built aimtraks in shells) so I need to run a version higher than .130 so I can have lightgun support. I figured th easiest way to do this would be to just upgrade to .139, the newest build at that time. Problem is a bunch of rims from .120 don't work on .139. Do I downloaded the romset from .139.
Next I used clrmamepro to scan my .120 romset using the .139 profile.
Finally I used the rebuilder, pointing at the new romset with my old romset being the destination.
Does this make sense?
Also if anyone can help. When I scan and try to fix unneeded files, I get an error and clrmamepro shuts down.
The goal us to have a working romset with lightgun support. Once that us set up I will never upgrade unless something phenomenal changes (like
Time crisis being playable) and in that case I would just build a new system .
Anyhow, any help:advice is mist appreciated
Dazz
  • HyperSpin Team
    • VPUniverse
Re: MAME .140
« Reply #16 on: October 24, 2010, 09:39:11 pm »
What kind of error are you getting in CMP?
I updated my .139 set to .140 today and this is how it went:
1.  Compiled MAME .140 via MC64 using hi-score .diff - 10 minutes
2.  Created new profile for MAME .140 in CMP, pointed to the MAME .140 .exe - 1 minutes
3.  Downloaded MAME update .139 to .140 via torrent - 5 minutes
4.  Used CMP, Re-Builder, pointed Source to my newly downloaded Roms .139 to .140 update, and the Destination to my existing .139 ROM set and hit Re-Build. - 20-25 minutes
Total time to update from .139 to .140 = ~45 minutes
With my 50mbps connection at home I could have just downloaded the full .140 torrent in the same time it took to scan, but I still run a scan/re-build after I download the full torrent anyway.
Hoopz
Re: MAME .140
« Reply #17 on: October 24, 2010, 10:01:25 pm »
You need to:
utorrent will scan the roms already there and only download what's missing.  Most of the time, you'll start somewhere around 90% or so of the files already downloaded with only a few percent needed.
At least that's how it works if you get your torrent from the normal place.   :dunno
Dazz
  • HyperSpin Team
    • VPUniverse
Re: MAME .140
« Reply #18 on: October 24, 2010, 10:48:34 pm »
You need to:
It will, but it will also leave old files and renamed files behind.  Nothing a CMP re-scan wouldn't clean up though.  I guess it's all about personal preference.  I'm old school when it comes to MAME, so I always just download the update sets and audit.  Once I've updated and audited then I'll connect to the full torrents to share.
Re: MAME .140
« Reply #19 on: October 25, 2010, 01:34:02 am »
You left out the time it takes to SEARCH for the torrent.  Easier said than done.   :angel:
JustMichael
  • Mmmmm!! Cheesecake!!
Re: MAME .140
« Reply #20 on: October 25, 2010, 03:01:55 am »
 :soapbox: Looks like none of these young whipper snappers ever heard of newsgroups...
Dazz
  • HyperSpin Team
    • VPUniverse
Re: MAME .140
« Reply #21 on: October 25, 2010, 04:37:56 am »
No need to search when I know exactly where it's located at...
I've been a Diamond Giganews member for years now. I normally pull 5-10mbs via newgroup servers, so I use newsgroups for almost everything, except for MAME, I like keeping a high ratio.
JustMichael
Re: MAME .140
« Reply #22 on: October 25, 2010, 05:24:36 am »
Don't forget their accelerator then ESPECIALLY for the headers!
tommyinajar
  • Last login:November 15, 2023, 12:23:20 pm
  • My other cab is a Cube Quest
Re: MAME .140
« Reply #23 on: October 25, 2010, 10:19:17 am »
Little off topic, are they not doing LD CHDs anymore? Not sure what's missing besides DL and Space Ace, it would be nice not to have to use an extra emulator just for those two...
Donkbaca
Re: MAME .140
« Reply #24 on: October 27, 2010, 04:53:38 pm »
So... What's the big advantage to compiling your own mame?
Hoopz
Re: MAME .140
« Reply #25 on: October 27, 2010, 05:06:55 pm »
You can disable all messages at the beginning of games and enable hi scores is the short answer.  More info here:
http://forum.arcadecontrols.com/index.php?topic=64298.0
smalltownguy
  • Last login:October 07, 2025, 12:45:27 pm
Re: MAME .140
« Reply #26 on: October 27, 2010, 05:30:19 pm »
hypernova
  • Last login:November 25, 2016, 12:52:48 pm
Re: MAME .140
« Reply #27 on: October 27, 2010, 06:19:18 pm »
<saint>
 :soapbox: :soapbox: :soapbox: :angry: :angry: :angry: :soapbox: :soapbox: :soapbox:
</saint>
« Last Edit: October 27, 2010, 06:30:52 pm by saint »
I'll exercise patience when you stop exercising stupidity.
My zazzle page.  I've created T-shirts!
Hoopz
Re: MAME .140
« Reply #28 on: October 27, 2010, 06:22:18 pm »
Seriously Hypernova?  You know better than that!
Dazz
  • HyperSpin Team
    • VPUniverse
Re: MAME .140
« Reply #29 on: October 27, 2010, 06:22:41 pm »
hypernova - With 2000+ posts you should know by now that posting links to ROM sites is against the rules.
FrizzleFried
    • Idaho Garagecade
Re: MAME .140
« Reply #30 on: October 27, 2010, 06:23:27 pm »
http://www.THISISNOTALLOWED.com
This is a ratio site.  An excellent source for keeping up on your arcade roms.  Also some tutorials for everything you need to do.
Really?  2000+ posts and this?
« Last Edit: October 27, 2010, 06:27:12 pm by FrizzleFried »
hypernova
Re: MAME .140
« Reply #31 on: October 29, 2010, 05:57:52 pm »
My fault.  Total lapse in memory. :banghead:
Won't happen again.
« Last Edit: October 29, 2010, 09:07:56 pm by hypernova »
WhereEaglesDare
    • My HomePage
Re: MAME .140
« Reply #32 on: October 29, 2010, 07:25:15 pm »
what processor do you use that lets you compile MAME 140 hi in 10 minutes?  Mine always takes over an hour
southpaw13
  • Last login:August 17, 2025, 03:18:15 pm
  • Whatever!
Re: MAME .140
« Reply #33 on: October 29, 2010, 09:42:39 pm »
Reason to update...
Donkey Kong 2---same one in Misfit Mame...
newmanfamilyvlogs
    • Newman Family Vlogs
Re: MAME .140
« Reply #34 on: October 29, 2010, 10:16:54 pm »
Last time I compiled mame it took 10 min or so.  Athlon 4x.
