Author Topic: Hyperspin pre-emulator command line operations?  (Read 3662 times)
DirtyDachshunds
    • First Project: MillerCade
« on: October 19, 2010, 09:47:42 am »
Does anyone know if Hyperspin supports pre/post command line operations, or how to get around this.  I want to set my U360s profiles per game, but I am unsure how to do this automatically in Hyperspin.  If anyone has done this or knows a workaround let me know.
garwil
  • Last login:August 10, 2022, 12:52:30 pm
Re: Hyperspin pre-emulator command line operations?
« Reply #1 on: October 19, 2010, 10:57:02 am »
You can edit the HyperLaunch Autohotkey script (don't forget to recompile). Have a look on the HS forums (or the AutoHotkey website).
DirtyDachshunds
« Reply #2 on: October 19, 2010, 03:00:11 pm »
Is there a way to fix a U360 profile to a game without a massive if statement or is this just the way it needs to be done?
ie
if (rom=frogger, pacman etc etc)
use 4-way
if (rom=street fighter etc etc)
use 8-way
garwil
« Reply #3 on: October 19, 2010, 04:03:15 pm »
I don't own a U360 but I believe there's a program that can do that on the fly. All you'd have to do is put the command in HyperLaunch before it loads MAME and it should do it. I know there's a few posts on the HS forums about getting U360s to work in HS.
brock.sampson
  • Last login:May 31, 2018, 10:11:41 pm
« Reply #4 on: October 19, 2010, 08:52:48 pm »
You can use ledblinky to load u360 maps.  Ledblinky is built into hyperspin already, http://forum.arcadecontrols.com/index.php?topic=87267.0
DOC! YOU HAVE A TABLE OVER THERE WITH A SIGN THAT SAYS, "LASER DEATH RAY BARGAIN BIN!"
DirtyDachshunds
« Reply #5 on: October 21, 2010, 11:47:51 am »
I am having trouble finding CPviewer, more specifically control.ini for LEDblinky.  It seems the website is down, and I can't find it hosted anywhere else.  Does someone e-mail cpviewer to me?
I'd appreciate it!
arzoo
  • Last login:January 26, 2025, 08:51:53 am
  • Robots WILL kill you.
    • LEDBlinky
« Reply #6 on: October 22, 2010, 08:26:47 am »
This thread has links to the controls.dat site (and controls.ini file)...
http://forum.arcadecontrols.com/index.php?topic=91711.msg995170#msg995170
Robots will kill you.
Arcade Addiction
