Author Topic: minijuke problem  (Read 2982 times)
hall99m
  • Last login:November 14, 2011, 04:19:41 am
minijuke problem
« on: October 11, 2010, 01:16:22 pm »
I have a problem with a minijuke 30 cd sound leisure system.
It seems to sometimes have difficulty reading tracks on CD's, even though the cd's are clean.  I have tried cleaning the laser but it doesn't make much difference.
Any help would be much appreciated.
  • Last login:Today at 11:45:41 am
Re: minijuke problem
« Reply #1 on: October 12, 2010, 07:45:17 pm »
you should have a focus adjustment somewhere on the main board.
load up a cd and while it's skipping give it a slight tweak and it will probably smarten up. if it gets worse, your turning the wrong way.  :lol
if it's still bad, your whole "sled" might be sitting low. check to make sure theres no wore out parts where it glides. cd sleds usually have a rod on one side where it rides, but it's just plastic on plastic on the other.
the "sled" is the laser/lens/pickup assembly
hall99m
« Reply #2 on: October 13, 2010, 01:20:11 pm »
Ok I'll try that.  Is the adjustment on the same moving part as the laser itself?
« Reply #3 on: October 14, 2010, 12:49:10 am »
not likely, usually its near the ribbon cable that comes from the sled down to the board...but it may be anywhere... it should be labeled somehow (either "focus" or "F" or something like that)
the small one on the sled is the laser power adjustment... just leave that for the time being.
hall99m
« Reply #4 on: October 28, 2010, 01:22:56 pm »
The machine also sometimes has a problem of coins jamming in the coin mechanism, which is a coin controls C220B 8 coin validator.  Can it be cleaned/repaired or does it need to be replaced?
« Reply #5 on: October 28, 2010, 09:55:24 pm »
its a really simple mech. the top portion opens up. check and see if there is anything causing it to jam. otherwise if it's just dirty just use a damp cloth to clean it.
