Author Topic: Switchres: modeline generator engine  (Read 754483 times)
  • Last login:Today at 04:22:12 pm
Re: Switchres arcade monitor modeline generator and mame wrapper
« Reply #800 on: February 03, 2011, 06:21:45 pm »
I'm testing the new one and works perfect here, only tested from live-cd, will probably install this eventually to get a better knowlegde of it. I'm using OSS all the time as ALSA never worked for me (not tested lately), but I remember seeing those ALSA errors VeS has when loading Mame even with OSS selected and fully working. Maybe VeS board only works with OSS as mine? Tomorrow I'll test the network stuff to see if I can put some roms there.
« Last Edit: February 03, 2011, 06:23:27 pm by Calamity »
ves
  • Last login:April 11, 2020, 02:57:49 am
« Reply #801 on: February 03, 2011, 06:35:01 pm »
Hi Calamity, are you saying that you can use the last 2 live versions without problems? I've tried to disable the sound card of the plate and put a sound blaster 128 but there is no way, tomorrow I'll try with 5.1.
Anyway the mounting procedures have you successfully loaded advmenu alone, without having to type in xterm?
That sound card and motherboard have?.
Bitetibe mingetty've tried to use instead of gdm or xdm etc. .. to do single user login and so charged the X from the bashrc? this could save you problems?
Greetings.
Hola Calamity, estas diciendo que puedes usar la ultimas 2 versiones de la live sin problemas? yo he probado a desactivar la tarjeta de sonido de la placa y poner una sound blaster 128 pero no hay manera, maņana lo intentare con una 5.1.
De todas formas las has instaldo, te carga correctamente advmenu solo, sin tener que escribirlo en el xterm?
Que tarjeta de sonido y placa tienes?.
Bitetibe has probado a usar mingetty en lugar de gdm o xdm etc.. para que haga login el usuario solo y asi carge las X desde el bashrc ? esto podria ahorrar problemas?
Saludos.
« Last Edit: February 03, 2011, 06:37:58 pm by ves »
« Reply #802 on: February 03, 2011, 06:44:12 pm »
Yes, these last versions work here flawlessly, but I only use OSS and always run from the live-cd. The audio card is an integrated one, motherboard is an Asrock, will give you the details.
ves
« Reply #803 on: February 04, 2011, 02:21:52 am »
Okay, so oss and alsa not integrate well with my sound card, either because the driver missing or did not correctly identified.
You could try installing to see if you think the same thing to me, you do not load automatically advmenu.
bitbytebit
« Reply #804 on: February 04, 2011, 03:12:57 am »
I tested the GDM boot option tonight and yes I see the problem now.  I will fix that, does look like if fixed, it will boot into advmenu nicely.  At least I see it on the build I made, but still should work fine if you don't choose GDM login on install (will go to the setup menu still, but won't start only an xterm that way).  Are you seeing a login when booting, graphical one, and then an xterm and some other odd apps?
ves
« Reply #805 on: February 04, 2011, 03:19:55 am »
Hi bi, when I boot I have not log in, start automatically, but only loads xterm.
What most worries me is the issue of alsa and oss, you could see something like that? you may be missing the kernel module? or detection fails?
Mingetty
http://dev.gentoo.org/~cardoe/mythtv/autostart.html
Thank
« Last Edit: February 04, 2011, 04:30:54 am by ves »
bitbytebit
« Reply #806 on: February 04, 2011, 03:33:26 am »
Thank
Yeah I have a much better way to login automatically now, like you used, I'm going to use mingetty and setup a test and it worked well.  I could in theory reboot after exit from advmenu too now.  Instead for now I launch gasetup with sudo as root, but that can be changed in the new /home/arcade/.bash_login very easily
Basically:
/etc/inittab: (change)
c1:12345:respawn:/sbin/agetty 38400 tty1 linux
to
c1:12345:respawn:/sbin/mingetty --autologin arcade --noclear tty1
and create a new file /home/arcade/.bash_profile:
#!/bin/bash
export PATH=/usr/games/bin:$PATH
startx
sudo gasetup # could change this to sudo /sbin/poweroff to halt system
So that seems to work here, oh and also run this...
/etc/init.d/xdm stop
and/or
rc-setup del xdm default
I'm not sure why the audio isn't working there, you did have OSS4 audio though before didn't you?  Possibly not touching any of the audio settings on install, see if it works that way.  It may be your setting up Alsa or OSS4 (you don't have to setup OSS4 at all unless you already setup Alsa and rebooted).
Thanks,
Chris
bitbytebit
« Reply #807 on: February 04, 2011, 04:23:04 am »
You're right, my problem is not related to your software, i will try to give as much informations as i can to Alex.
 I've posted a thread on a french forum about your software, seems that you will see more froggies around near  ::)
Something interesting, I have seen the same half screen issue finally.  Well I have a Radeon 5450 CEDAR model card I just got and am testing it.  Well it does the exact same thing in the console, and it's because it won't support interlace. A 320x240 console works and fits but of course the menu system doesn't fit on that at all.  So I suspect it's the same issue in both cards.
Also it's interesting, since these cards don't work at all in Windows with Soft15khz.  They seem to even have probed modelines in Linux too that my methods for the default ones and framebuffer stuff doesn't get rid of.  So that's annoying of them, but besides that it does do 15khz modes so it isn't a dotclock limitation or anything.  Yet it seems they don't have the interrupt/vblank support yet so they don't do vsync and page flipping at all.  I'm sure it's just not been implemented yet by Alex, the ATI developer.  So at least I can recreate your issue, but I also suspect it may be either interlacing problems with both cards, else maybe they can't do interlacing.  I am digging into where these probed modes come from, so I can change the kernel to ignore them on a CGA 15khz output.
« Reply #808 on: February 04, 2011, 05:31:42 am »
So you are not seeing the usual interlace trembling there?
bitbytebit
« Reply #809 on: February 04, 2011, 05:45:44 am »
Nope, it's weird because it's a 15khz display but half the screen is cut off for it at 640x480, yet with 320x240 progression it's perfect.  Also the 15khz modeline setting is perfect in X Windows for games, but they run 400+ percent speed of course because the vblank interrupt isn't working right.  Then you've got the probed modes all there just in the way, although mostly just are going to hit the 320x240 games and such.  So it seems these newer Radeon cards technically can do it, we just have to ignore these probed modes and possibly can't do interlace on them, or it's not implemented yet like the vblank isn't.  It is really new, Alex just got CEDAR chips working at all as of last November.
ves
« Reply #810 on: February 04, 2011, 09:45:49 am »
Hello bitbytebit, unless you want to get out of X by mistake, you can include this option in the bashrc
while true
do
startx
done
As I can reinstall alsa without having to install the kernel?
Thank
bitbytebit
« Reply #811 on: February 04, 2011, 10:17:21 am »
while true
do
startx
done
Thank
Try this ISO LiveCD32-Full-1.400-44b3297.iso
This new version should boot straight into advmenu as the arcade user after install, I removed gdm completely.  Also a improved the way the menu of gasetup does the startup/quit and info messages.  Also I went back to the stripped down version for now, with just what we need for emulation, so not having to upload/download extra.
Do you know about the portage system, how to run emerge?  I have Alsa work when I run the install it option in the menu, so I'm guessing either your sound card isn't compatible or it's for some reason not finding it for the mixer unmute or similar.
What does `aplay -l` show?
what does `ossinfo` show?
ves
« Reply #812 on: February 04, 2011, 10:58:06 am »
Hi, I have the solution for apgar the pc from the user advmenu arcade.
groupadd shutdown
add arcade to the group shutdown
check this created the user group and has arcade
shutdown:x:1002:arcade...
now with the command visudo, add the following lines
%shutdown ALL=(root) NOPASSWD: /sbin/reboot
%shutdown ALL=(root) NOPASSWD: /sbin/halt
%shutdown ALL=(root) NOPASSWD: /sbin/shutdown
And finally create the alias .bashrc
alias shutdown = ' sudo shutdown -h now'
alias shutdown = ' sudo halt '
alias halt = ' sudo halt'
alias halt = ' sudo shutdown -h now'
This all tested from the console, since I have done with a virtual machine, so I need to check that advmenu off the pc.
Thank
ves
« Reply #813 on: February 04, 2011, 04:03:35 pm »
Livecd OSS
aplay -l
ossinfo
Version info: OSS 4.2 (b 2003/201101031428) (0x00040100) GPL
Platform: Linux/i686 2.6.38-rc3+ #1 SMP Thu Feb 3 19:09:24 CST 2011 (GroovyArcade)
Number of audio devices: 1
Number of audio engines: 6
Number of MIDI devices: 0
Number of mixer devices: 1
Device objects
 0: osscore0 OSS core services
 1: oss_ich0 SiS 7012 interrupts=3232 (3232)
 2: oss_usb0 USB audio core services
MIDI devices (/dev/midi*)
Mixer devices
 0: ICH AC97 Mixer (ALC655) (Mixer 0 of device object 1)
Audio devices
SiS 7012                          /dev/oss/oss_ich0/pcm0  (device index 0)
Nodes
  /dev/dsp -> /dev/oss/oss_ich0/pcm0
  /dev/dsp_in -> /dev/oss/oss_ich0/pcm0
  /dev/dsp_out -> /dev/oss/oss_ich0/pcm0
  /dev/dsp_ac3 -> /dev/oss/oss_ich0/pcm0
  /dev/dsp_mmap -> /dev/oss/oss_ich0/pcm0
  /dev/dsp_multich -> /dev/oss/oss_ich0/pcm0
Livecd ALSA
aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: SI7012 [SiS SI7012], device 0: Intel ICH [SiS SI7012]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
ossinfo
Version info:   (0x00000000)
Number of audio devices: 0
Number of audio engines: 0
Number of mixer devices: 0
Device objects
Mixer devices
Audio devices
Nodes
Install OSS
aplay -l
Install OSS
ossinfo
Device objects
 1: oss_ich0 SiS 7012 interrupts=2134 (2134)
Mixer devices
Audio devices
Nodes
Install ALSA
aplay -l
  Subdevices: 1/1
ossinfo
Device objects
Mixer devices
Audio devices
Nodes
Hello, here are the results of alsa and oss, I think as you say the sound is no problem, but the ArcadeVGA, refuses to acknowledge (actualizastes the kernel, right?) and therefore does not load the game, it is possible right? because I've tried other vga ati pci express in other pc's and if the games work.
I could not find the file or radeon.o radeon.ko, only a ati-agp.ko may be missing that module? which is actually charging for the AVGA?
By the way does not create the file bashrc bashr_profile nor with the start command, because you put it in path in bash? should not only recognize all routes?
On the subject of the pc off, advmenu not let you use the command says you need to be root, but if you put the command works fine, no error if this latest version or not, because when I think the aka I always put the leaves alone are eliminated.
Thank
bitbytebit
« Reply #814 on: February 04, 2011, 04:34:02 pm »
Thank
The radeon and drm are built into this kernel, they are not modules, that's how they load the 15khz frame buffer right after grub.
Which ArcadeVGA card version are you using?  In theory it should work, unless it's an AVGA 3000, those need to be flashed into a normal Radeon card in Linux for DRM/KMS and interrupts/vblank to work.
Do you have logs of /var/log/Xorg.0.log when it doesn't work?
The audio looks like it should work, everything is configured right for Alsa and OSS it seems.
the .bash_profile is used in /home/arcade/ , the autologin ignores .bashrc and that isn't really executed.
ves
« Reply #815 on: February 04, 2011, 04:39:01 pm »
Hello AVGA I use is 9250, with the kernel version 2.6.38-rc2+ ,but with the new rc +3 no way it will work, the X function but loading mame not think that's why the error was radeon .....
penGL: PBO not supported
mame: radeon_cs_gem.c:181: cs_gem_write_reloc: Assertion `boi->space_accounted' failed.
Aborted
The bash_profile not believe it has to be done manually.
You could put the old kernel to install it myself, and so that it works or not?
ves
« Reply #816 on: February 04, 2011, 04:40:41 pm »
OpenGL: PBO not supported
Aborted
bitbytebit
« Reply #817 on: February 04, 2011, 04:42:17 pm »
Aborted
Can you get the dmesg log, and also Xorg.0.log for it?  Those logs would be useful to see what is going on.
You can probably take the old installation and use the kernel from there, the /boot/ /lib/modules/ directories,
see if that alone fixes it.
ves
« Reply #818 on: February 04, 2011, 04:43:00 pm »
Ok, I'll try and take the logs to
bitbytebit
« Reply #819 on: February 04, 2011, 04:54:32 pm »
Also output of glxinfo
Also run glxgears and have it go full screen, see if the same thing happens there.
ves
« Reply #820 on: February 04, 2011, 05:15:47 pm »
Hi bit has not put the boot works and modulons new kernel loaded with g2 + but still the same, I put the logs.
Xorg.0.log 1 Part
[   361.720]
X.Org X Server 1.9.2
Release Date: 2010-10-30
[   361.732] X Protocol Version 11, Revision 0
[   361.735] Build Operating System: Linux 2.6.38-rc1 i686 Gentoo
[   361.739] Current Operating System: Linux GroovyArcade 2.6.38-rc2+ #1 SMP Mon Jan 24 22:01:58 CST 2011 i686
[   361.746] Kernel command line: root=/dev/sda1 init=/boot/linuxrc initrd udev nodevfs CGAVGA video=VGA-1:640x480ec
[   361.754] Build Date: 31 January 2011  12:08:30PM
[   361.758]
[   361.762] Current version of pixman: 0.20.0
[   361.765] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[   361.773] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[   361.785] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Feb  4 17:08:24 2011
[   361.789] (==) Using config file: "/etc/X11/xorg.conf"
[   361.792] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[   361.797] (**) Option "defaultserverlayout" "Arcade Cabinet"
[   361.797] (**) ServerLayout "Arcade Cabinet"
[   361.797] (**) |-->Screen "Screen0" (0)
[   361.797] (**) |   |-->Monitor "DVI-0"
[   361.797] (**) |   |-->Device "Card0"
[   361.797] (**) |-->Input Device "Mouse0"
[   361.797] (**) |-->Input Device "Keyboard0"
[   361.797] (**) Option "DontZap" "off"
[   361.797] (**) Option "DontZoom" "on"
[   361.797] (**) Option "AllowMouseOpenFail" "true"
[   361.797] (**) Option "BlankTime" "0"
[   361.797] (**) Option "StandbyTime" "0"
[   361.797] (**) Option "SuspendTime" "0"
[   361.797] (**) Option "OffTime" "0"
[   361.797] (**) Option "NoPM" "True"
[   361.797] (**) Option "AIGLX" "on"
[   361.797] (==) Automatically adding devices
[   361.797] (==) Automatically enabling devices
[   361.798] (==) FontPath set to:
/usr/share/fonts/misc/,
/usr/share/fonts/TTF/,
/usr/share/fonts/OTF/,
/usr/share/fonts/Type1/,
/usr/share/fonts/100dpi/,
/usr/share/fonts/75dpi/
[   361.798] (==) ModulePath set to "/usr/lib/xorg/modules"
[   361.798] (**) Extension "Composite" is enabled
[   361.798] (WW) AllowEmptyInput is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[   361.798] (WW) Disabling Mouse0
[   361.798] (WW) Disabling Keyboard0
[   361.798] (II) Loader magic: 0x81f2d60
[   361.798] (II) Module ABI versions:
[   361.798] X.Org ANSI C Emulation: 0.4
[   361.798] X.Org Video Driver: 8.0
[   361.798] X.Org XInput driver : 11.0
[   361.798] X.Org Server Extension : 4.0
[   361.799] (--) PCI:*(0:1:0:0) 1002:5964:1787:5964 rev 1, Mem @ 0xd0000000/134217728, 0xe5000000/65536, I/O @ 0x00009000/256, BIOS @ 0x????????/131072
[   361.799] (--) PCI: (0:1:0:1) 1002:5d44:1787:5965 rev 1, Mem @ 0xd8000000/134217728, 0xe5010000/65536
[   361.799] (II) LoadModule: "extmod"
[   361.799] (II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
[   361.800] (II) Module extmod: vendor="X.Org Foundation"
[   361.800] compiled for 1.9.2, module version = 1.0.0
[   361.800] Module class: X.Org Server Extension
[   361.800] ABI class: X.Org Server Extension, version 4.0
[   361.800] (II) Loading extension MIT-SCREEN-SAVER
[   361.800] (II) Loading extension XFree86-VidModeExtension
[   361.800] (II) Loading extension XFree86-DGA
[   361.800] (II) Loading extension DPMS
[   361.800] (II) Loading extension XVideo
[   361.800] (II) Loading extension XVideo-MotionCompensation
[   361.800] (II) Loading extension X-Resource
[   361.800] (II) LoadModule: "dbe"
[   361.800] (II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
[   361.800] (II) Module dbe: vendor="X.Org Foundation"
[   361.800] (II) Loading extension DOUBLE-BUFFER
[   361.800] (II) LoadModule: "glx"
[   361.800] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[   361.800] (II) Module glx: vendor="X.Org Foundation"
[   361.800] (**) AIGLX enabled
[   361.800] (II) Loading extension GLX
[   361.801] (II) LoadModule: "record"
[   361.801] (II) Loading /usr/lib/xorg/modules/extensions/librecord.so
[   361.801] (II) Module record: vendor="X.Org Foundation"
[   361.801] compiled for 1.9.2, module version = 1.13.0
[   361.801] Module class: X.Org Server Extension
[   361.801] ABI class: X.Org Server Extension, version 4.0
[   361.801] (II) Loading extension RECORD
[   361.801] (II) LoadModule: "dri"
[   361.801] (II) Loading /usr/lib/xorg/modules/extensions/libdri.so
[   361.801] (II) Module dri: vendor="X.Org Foundation"
[   361.801] compiled for 1.9.2, module version = 1.0.0
[   361.801] (II) Loading extension XFree86-DRI
[   361.801] (II) LoadModule: "dri2"
[   361.801] (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
[   361.802] (II) Module dri2: vendor="X.Org Foundation"
[   361.802] compiled for 1.9.2, module version = 1.2.0
[   361.802] ABI class: X.Org Server Extension, version 4.0
[   361.802] (II) Loading extension DRI2
[   361.802] (II) LoadModule: "radeon"
[   361.802] (II) Loading /usr/lib/xorg/modules/drivers/radeon_drv.so
[   361.802] (II) Module radeon: vendor="X.Org Foundation"
[   361.802] compiled for 1.9.2, module version = 6.13.99
[   361.802] Module class: X.Org Video Driver
[   361.802] ABI class: X.Org Video Driver, version 8.0
[   361.802] (II) RADEON: Driver for ATI Radeon chipsets:
ATI Radeon Mobility X600 (M24) 3150 (PCIE), ATI FireMV 2400 (PCI),
ATI Radeon Mobility X300 (M24) 3152 (PCIE),
ATI FireGL M24 GL 3154 (PCIE), ATI FireMV 2400 3155 (PCI),
ATI Radeon X600 (RV380) 3E50 (PCIE),
ATI FireGL V3200 (RV380) 3E54 (PCIE), ATI Radeon IGP320 (A3) 4136,
ATI Radeon IGP330/340/350 (A4) 4137, ATI Radeon 9500 AD (AGP),
ATI Radeon 9500 AE (AGP), ATI Radeon 9600TX AF (AGP),
ATI FireGL Z1 AG (AGP), ATI Radeon 9800SE AH (AGP),
ATI Radeon 9800 AI (AGP), ATI Radeon 9800 AJ (AGP),
ATI FireGL X2 AK (AGP), ATI Radeon 9600 AP (AGP),
ATI Radeon 9600SE AQ (AGP), ATI Radeon 9600XT AR (AGP),
ATI Radeon 9600 AS (AGP), ATI FireGL T2 AT (AGP), ATI Radeon 9650,
ATI FireGL RV360 AV (AGP), ATI Radeon 7000 IGP (A4+) 4237,
ATI Radeon 8500 AIW BB (AGP), ATI Radeon 8500 AIW BC (AGP),
ATI Radeon IGP320M (U1) 4336, ATI Radeon IGP330M/340M/350M (U2) 4337,
ATI Radeon Mobility 7000 IGP 4437, ATI Radeon 9000/PRO If (AGP/PCI),
ATI Radeon 9000 Ig (AGP/PCI), ATI Radeon X800 (R420) JH (AGP),
ATI Radeon X800PRO (R420) JI (AGP),
ATI Radeon X800SE (R420) JJ (AGP), ATI Radeon X800 (R420) JK (AGP),
ATI Radeon X800 (R420) JL (AGP), ATI FireGL X3 (R420) JM (AGP),
ATI Radeon Mobility 9800 (M18) JN (AGP),
ATI Radeon X800 SE (R420) (AGP), ATI Radeon X800XT (R420) JP (AGP),
ATI Radeon X800 VE (R420) JT (AGP), ATI Radeon X850 (R480) (AGP),
ATI Radeon X850 XT (R480) (AGP), ATI Radeon X850 SE (R480) (AGP),
ATI Radeon X850 PRO (R480) (AGP), ATI Radeon X850 XT PE (R480) (AGP),
ATI Radeon Mobility M7 LW (AGP),
ATI Mobility FireGL 7800 M7 LX (AGP),
ATI Radeon Mobility M6 LY (AGP), ATI Radeon Mobility M6 LZ (AGP),
ATI FireGL Mobility 9000 (M9) Ld (AGP),
ATI Radeon Mobility 9000 (M9) Lf (AGP),
ATI Radeon Mobility 9000 (M9) Lg (AGP), ATI Radeon 9700 Pro ND (AGP),
ATI Radeon 9700/9500Pro NE (AGP), ATI Radeon 9600TX NF (AGP),
ATI FireGL X1 NG (AGP), ATI Radeon 9800PRO NH (AGP),
ATI Radeon 9800 NI (AGP), ATI FireGL X2 NK (AGP),
ATI Radeon 9800XT NJ (AGP),
ATI Radeon Mobility 9600/9700 (M10/M11) NP (AGP),
ATI Radeon Mobility 9600 (M10) NQ (AGP),
ATI Radeon Mobility 9600 (M11) NR (AGP),
ATI Radeon Mobility 9600 (M10) NS (AGP),
ATI FireGL Mobility T2 (M10) NT (AGP),
ATI FireGL Mobility T2e (M11) NV (AGP), ATI Radeon QD (AGP),
ATI Radeon QE (AGP), ATI Radeon QF (AGP), ATI Radeon QG (AGP),
ATI FireGL 8700/8800 QH (AGP), ATI Radeon 8500 QL (AGP),
ATI Radeon 9100 QM (AGP), ATI Radeon 7500 QW (AGP/PCI),
ATI Radeon 7500 QX (AGP/PCI), ATI Radeon VE/7000 QY (AGP/PCI),
ATI Radeon VE/7000 QZ (AGP/PCI), ATI ES1000 515E (PCI),
ATI Radeon Mobility X300 (M22) 5460 (PCIE),
ATI Radeon Mobility X600 SE (M24C) 5462 (PCIE),
ATI FireGL M22 GL 5464 (PCIE), ATI Radeon X800 (R423) UH (PCIE),
ATI Radeon X800PRO (R423) UI (PCIE),
ATI Radeon X800LE (R423) UJ (PCIE),
ATI Radeon X800SE (R423) UK (PCIE),
ATI Radeon X800 XTP (R430) (PCIE), ATI Radeon X800 XL (R430) (PCIE),
ATI Radeon X800 SE (R430) (PCIE), ATI Radeon X800 (R430) (PCIE),
ATI FireGL V7100 (R423) (PCIE), ATI FireGL V5100 (R423) UQ (PCIE),
ATI FireGL unknown (R423) UR (PCIE),
ATI FireGL unknown (R423) UT (PCIE),
ATI Mobility FireGL V5000 (M26) (PCIE),
ATI Mobility Radeon X700 XL (M26) (PCIE),
ATI Mobility Radeon X700 (M26) (PCIE),
ATI Radeon X550XTX 5657 (PCIE), ATI Radeon 9100 IGP (A5) 5834,
ATI Radeon Mobility 9100 IGP (U3) 5835,
ATI Radeon XPRESS 200 5954 (PCIE),
ATI Radeon XPRESS 200M 5955 (PCIE), ATI Radeon 9250 5960 (AGP),
ATI Radeon 9200 5961 (AGP), ATI Radeon 9200 5962 (AGP),
ATI Radeon 9200SE 5964 (AGP), ATI FireMV 2200 (PCI),
ATI ES1000 5969 (PCI), ATI Radeon XPRESS 200 5974 (PCIE),
ATI Radeon XPRESS 200M 5975 (PCIE),
ATI Radeon XPRESS 200 5A41 (PCIE),
ATI Radeon XPRESS 200M 5A42 (PCIE),
ATI Radeon XPRESS 200 5A61 (PCIE),
ATI Radeon XPRESS 200M 5A62 (PCIE),
ATI Radeon X300 (RV370) 5B60 (PCIE),
ATI Radeon X600 (RV370) 5B62 (PCIE),
ATI Radeon X550 (RV370) 5B63 (PCIE),
ATI FireGL V3100 (RV370) 5B64 (PCIE),
ATI FireMV 2200 PCIE (RV370) 5B65 (PCIE),
ATI Radeon Mobility 9200 (M9+) 5C61 (AGP),
ATI Radeon Mobility 9200 (M9+) 5C63 (AGP),
ATI Mobility Radeon X800 XT (M28) (PCIE),
ATI Mobility FireGL V5100 (M28) (PCIE),
ATI Mobility Radeon X800 (M28) (PCIE), ATI Radeon X850 5D4C (PCIE),
ATI Radeon X850 XT PE (R480) (PCIE),
ATI Radeon X850 SE (R480) (PCIE), ATI Radeon X850 PRO (R480) (PCIE),
ATI unknown Radeon / FireGL (R480) 5D50 (PCIE),
ATI Radeon X850 XT (R480) (PCIE),
ATI Radeon X800XT (R423) 5D57 (PCIE),
ATI FireGL V5000 (RV410) (PCIE), ATI Radeon X700 XT (RV410) (PCIE),
ATI Radeon X700 PRO (RV410) (PCIE),
ATI Radeon X700 SE (RV410) (PCIE), ATI Radeon X700 (RV410) (PCIE),
ATI Radeon X700 SE (RV410) (PCIE), ATI Radeon X1800,
ATI Mobility Radeon X1800 XT, ATI Mobility Radeon X1800,
ATI Mobility FireGL V7200, ATI FireGL V7200, ATI FireGL V5300,
ATI Mobility FireGL V7100, ATI Radeon X1800, ATI Radeon X1800,
ATI Radeon X1800, ATI Radeon X1800, ATI Radeon X1800,
ATI FireGL V7300, ATI FireGL V7350, ATI Radeon X1600, ATI RV505,
ATI Radeon X1300/X1550, ATI Radeon X1550, ATI M54-GL,
ATI Mobility Radeon X1400, ATI Radeon X1300/X1550,
ATI Radeon X1550 64-bit, ATI Mobility Radeon X1300,
ATI Mobility Radeon X1300, ATI Mobility Radeon X1300,
ATI Mobility Radeon X1300, ATI Radeon X1300, ATI Radeon X1300,
ATI RV505, ATI RV505, ATI FireGL V3300, ATI FireGL V3350,
ATI Radeon X1300, ATI Radeon X1550 64-bit, ATI Radeon X1300/X1550,
ATI Radeon X1600, ATI Radeon X1300/X1550, ATI Mobility Radeon X1450,
ATI Radeon X1300/X1550, ATI Mobility Radeon X2300,
ATI Mobility Radeon X2300, ATI Mobility Radeon X1350,
ATI Mobility Radeon X1350, ATI Mobility Radeon X1450,
ATI Radeon X1300, ATI Radeon X1550, ATI Mobility Radeon X1350,
ATI FireMV 2250, ATI Radeon X1550 64-bit, ATI Radeon X1600,
ATI Radeon X1650, ATI Radeon X1600, ATI Radeon X1600,
ATI Mobility FireGL V5200, ATI Mobility Radeon X1600,
ATI Radeon X1650, ATI Radeon X1650, ATI Radeon X1600,
ATI Radeon X1300 XT/X1600 Pro, ATI FireGL V3400,
ATI Mobility FireGL V5250, ATI Mobility Radeon X1700,
ATI Mobility Radeon X1700 XT, ATI FireGL V5200,
ATI Mobility Radeon X1700, ATI Radeon X2300HD,
ATI Mobility Radeon HD 2300, ATI Mobility Radeon HD 2300,
ATI Radeon X1950, ATI Radeon X1900, ATI Radeon X1950,
ATI Radeon X1900, ATI Radeon X1900, ATI Radeon X1900,
ATI AMD Stream Processor, ATI Radeon X1900, ATI Radeon X1950,
ATI RV560, ATI RV560, ATI Mobility Radeon X1900, ATI RV560,
ATI Radeon X1950 GT, ATI RV570, ATI RV570, ATI FireGL V7400,
ATI RV560, ATI Radeon X1650, ATI Radeon X1650, ATI RV560,
ATI Radeon 9100 PRO IGP 7834, ATI Radeon Mobility 9200 IGP 7835,
ATI Radeon X1200, ATI Radeon X1200, ATI Radeon X1200,
ATI Radeon X1200, ATI Radeon X1200, ATI RS740, ATI RS740M, ATI RS740,
ATI RS740M, ATI Radeon HD 2900 XT, ATI Radeon HD 2900 XT,
ATI Radeon HD 2900 XT, ATI Radeon HD 2900 Pro, ATI Radeon HD 2900 GT,
ATI FireGL V8650, ATI FireGL V8600, ATI FireGL V7600,
ATI Radeon 4800 Series, ATI Radeon HD 4870 x2,
ATI Radeon 4800 Series, ATI Radeon HD 4850 x2,
ATI FirePro V8750 (FireGL), ATI FirePro V7760 (FireGL),
ATI Mobility RADEON HD 4850, ATI Mobility RADEON HD 4850 X2,
ATI Radeon 4800 Series, ATI FirePro RV770, AMD FireStream 9270,
AMD FireStream 9250, ATI FirePro V8700 (FireGL),
ATI Mobility RADEON HD 4870, ATI Mobility RADEON M98,
ATI Mobility RADEON HD 4870, ATI Radeon 4800 Series,
ATI Radeon 4800 Series, ATI FirePro M7750, ATI M98, ATI M98, ATI M98,
ATI Mobility Radeon HD 4650, ATI Radeon RV730 (AGP),
ATI Mobility Radeon HD 4670, ATI FirePro M5750,
ATI Mobility Radeon HD 4670, ATI Radeon RV730 (AGP),
ATI RV730XT [Radeon HD 4670], ATI RADEON E4600,
ATI Radeon HD 4600 Series, ATI RV730 PRO [Radeon HD 4650],
ATI FirePro V7750 (FireGL), ATI FirePro V5700 (FireGL),
ATI FirePro V3750 (FireGL), ATI Mobility Radeon HD 4830,
ATI Mobility Radeon HD 4850, ATI FirePro M7740, ATI RV740,
ATI Radeon HD 4770, ATI Radeon HD 4700 Series, ATI Radeon HD 4770,
ATI FirePro M5750, ATI RV610, ATI Radeon HD 2400 XT,
ATI Radeon HD 2400 Pro, ATI Radeon HD 2400 PRO AGP, ATI FireGL V4000,
ATI RV610, ATI Radeon HD 2350, ATI Mobility Radeon HD 2400 XT,
ATI Mobility Radeon HD 2400, ATI RADEON E2400, ATI RV610,
ATI FireMV 2260, ATI RV670, ATI Radeon HD3870,
ATI Mobility Radeon HD 3850, ATI Radeon HD3850,
ATI Mobility Radeon HD 3850 X2, ATI RV670,
ATI Mobility Radeon HD 3870, ATI Mobility Radeon HD 3870 X2,
ATI Radeon HD3870 X2, ATI FireGL V7700, ATI Radeon HD3850,
ATI Radeon HD3690, AMD Firestream 9170, ATI Radeon HD 4550,
ATI Radeon RV710, ATI Radeon RV710, ATI Radeon RV710,
ATI Radeon HD 4350, ATI Mobility Radeon 4300 Series,
ATI Mobility Radeon 4500 Series, ATI Mobility Radeon 4500 Series,
ATI FirePro RG220, ATI Mobility Radeon 4330, ATI RV630,
ATI Mobility Radeon HD 2600, ATI Mobility Radeon HD 2600 XT,
ATI Radeon HD 2600 XT AGP, ATI Radeon HD 2600 Pro AGP,
ATI Radeon HD 2600 XT, ATI Radeon HD 2600 Pro, ATI Gemini RV630,
ATI Gemini Mobility Radeon HD 2600 XT, ATI FireGL V5600,
ATI FireGL V3600, ATI Radeon HD 2600 LE,
ATI Mobility FireGL Graphics Processor, ATI Radeon HD 3470,
ATI Mobility Radeon HD 3430, ATI Mobility Radeon HD 3400 Series,
ATI Radeon HD 3450, ATI Radeon HD 3450, ATI Radeon HD 3430,
ATI Radeon HD 3450, ATI FirePro V3700, ATI FireMV 2450,
ATI FireMV 2260, ATI FireMV 2260, ATI Radeon HD 3600 Series,
ATI Radeon HD 3650 AGP, ATI Radeon HD 3600 PRO,
ATI Radeon HD 3600 XT, ATI Radeon HD 3600 PRO,
ATI Mobility Radeon HD 3650, ATI Mobility Radeon HD 3670,
ATI Mobility FireGL V5700, ATI Mobility FireGL V5725,
ATI Radeon HD 3200 Graphics, ATI Radeon 3100 Graphics,
ATI Radeon HD 3300 Graphics, ATI Radeon HD 3200 Graphics,
ATI Radeon 3000 Graphics, ATI Radeon HD 4200, ATI Radeon 4100,
ATI Mobility Radeon HD 4200, ATI Mobility Radeon 4100,
ATI Radeon HD 4290, ATI Radeon HD 4250, AMD Radeon HD 6310 Graphics,
AMD Radeon HD 6310 Graphics, AMD Radeon HD 6250 Graphics,
AMD Radeon HD 6250 Graphics, CYPRESS,
ATI FirePro (FireGL) Graphics Adapter,
ATI FirePro (FireGL) Graphics Adapter, AMD Firestream 9370,
AMD Firestream 9350, ATI Radeon HD 5800 Series,
ATI Radeon HD 5800 Series, ATI Radeon HD 5800 Series,
ATI Radeon HD 5900 Series, ATI Radeon HD 5900 Series,
ATI Mobility Radeon HD 5800 Series,
ATI Mobility Radeon HD 5800 Series, ATI Radeon HD 5700 Series,
ATI Radeon HD 5700 Series, ATI Radeon HD 5700 Series,
ATI Mobility Radeon HD 5000 Series,
ATI Mobility Radeon HD 5000 Series, ATI Mobility Radeon HD 5570,
ATI FirePro (FireGL) Graphics Adapter, ATI Radeon HD 5670,
ATI Radeon HD 5570, ATI Radeon HD 5500 Series, REDWOOD,
ATI Mobility Radeon HD 5000 Series, ATI Mobility Radeon Graphics,
ATI Mobility Radeon Graphics, CEDAR,
ATI FirePro (FireGL) Graphics Adapter, ATI FirePro 2270, CEDAR,
ATI Radeon HD 5450, CEDAR, AMD Radeon HD 6900M Series,
Mobility Radeon HD 6000 Series, BARTS, BARTS,
Mobility Radeon HD 6000 Series, Mobility Radeon HD 6000 Series,
BARTS, BARTS, BARTS, BARTS, AMD Radeon HD 6800 Series,
AMD Radeon HD 6800 Series, TURKS, TURKS, TURKS, TURKS, TURKS, TURKS,
TURKS, TURKS, TURKS, TURKS, TURKS, TURKS, TURKS, CAICOS, CAICOS,
CAICOS, CAICOS, CAICOS, CAICOS, CAICOS, CAICOS, CAICOS, CAICOS,
CAICOS
[   361.811] (--) using VT number 7
ves
« Reply #821 on: February 04, 2011, 05:16:40 pm »
Xorg.0.log 2 Part
[   361.817] (II) [KMS] Kernel modesetting enabled.
[   361.817] (**) RADEON(0): Depth 24, (--) framebuffer bpp 32
[   361.817] (II) RADEON(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[   361.817] (==) RADEON(0): Default visual is TrueColor
[   361.817] (**) RADEON(0): Option "EnablePageFlip" "on"
[   361.817] (==) RADEON(0): RGB weight 888
[   361.817] (II) RADEON(0): Using 8 bits per RGB (8 bit DAC)
[   361.818] (--) RADEON(0): Chipset: "ATI Radeon 9200SE 5964 (AGP)" (ChipID = 0x5964)
[   361.818] (II) RADEON(0): AGP card detected
[   361.818] drmOpenDevice: node name is /dev/dri/card0
[   361.818] drmOpenDevice: open result is 8, (OK)
[   361.818] drmOpenByBusid: Searching for BusID pci:0000:01:00.0
[   361.818] drmOpenByBusid: drmOpenMinor returns 8
[   361.818] drmOpenByBusid: drmGetBusid reports pci:0000:01:00.0
[   361.818] (II) RADEON(0): KMS Color Tiling: disabled
[   361.818] (II) RADEON(0): KMS Pageflipping: enabled
[   361.818] (II) RADEON(0): SwapBuffers wait for vsync: enabled
[   361.818] (II) RADEON(0): Output VGA-0 using monitor section DVI-0
[   361.818] (**) RADEON(0): Option "Primary" "True"
[   361.818] (**) RADEON(0): Option "DefaultModes" "False"
[   361.842] (II) RADEON(0): Output VGA-1 has no monitor section
[   361.848] (II) RADEON(0): Output S-video has no monitor section
[   361.848] (**) RADEON(0): Option "ModeDebug" "true"
[   361.848] (II) RADEON(0): EDID for output VGA-0
[   361.848] (II) RADEON(0): Printing probed modes for output VGA-0
[   361.848] (II) RADEON(0): Modeline "648x480x60.00"x60.0   13.13  648 672 736 840  480 482 487 521 interlace -hsync -vsync (15.6 kHz)
[   361.872] (II) RADEON(0): EDID for output VGA-1
[   361.878] (II) RADEON(0): EDID for output S-video
[   361.878] (II) RADEON(0): Output VGA-0 connected
[   361.878] (II) RADEON(0): Output VGA-1 disconnected
[   361.878] (II) RADEON(0): Output S-video disconnected
[   361.878] (II) RADEON(0): Using fuzzy aspect match for initial modes
[   361.878] (II) RADEON(0): Output VGA-0 using initial mode 648x480x60.00
[   361.878] (II) RADEON(0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
[   361.878] (II) RADEON(0): mem size init: gart size :1fdff000 vram size: s:8000000 visible:7e94000
[   361.879] (II) RADEON(0): EXA: Driver will allow EXA pixmaps in VRAM
[   361.879] (==) RADEON(0): DPI set to (96, 96)
[   361.879] (II) Loading sub module "fb"
[   361.879] (II) LoadModule: "fb"
[   361.879] (II) Loading /usr/lib/xorg/modules/libfb.so
[   361.879] (II) Module fb: vendor="X.Org Foundation"
[   361.879] compiled for 1.9.2, module version = 1.0.0
[   361.879] ABI class: X.Org ANSI C Emulation, version 0.4
[   361.879] (II) Loading sub module "ramdac"
[   361.879] (II) LoadModule: "ramdac"
[   361.879] (II) Module "ramdac" already built-in
[   361.879] (II) Loading sub module "exa"
[   361.879] (II) LoadModule: "exa"
[   361.879] (II) Loading /usr/lib/xorg/modules/libexa.so
[   361.880] (II) Module exa: vendor="X.Org Foundation"
[   361.880] compiled for 1.9.2, module version = 2.5.0
[   361.880] ABI class: X.Org Video Driver, version 8.0
[   361.880] (--) Depth 24 pixmap format is 32 bpp
[   361.880] (II) RADEON(0): [DRI2] Setup complete
[   361.880] (II) RADEON(0): [DRI2]   DRI driver: r200
[   361.880] (II) RADEON(0): Front buffer size: 1320K
[   361.880] (II) RADEON(0): VRAM usage limit set to 115466K
[   361.880] (==) RADEON(0): Backing store disabled
[   361.880] (II) RADEON(0): Direct rendering enabled
[   361.880] (II) RADEON(0): Render acceleration enabled for R200 type cards.
[   361.880] (II) RADEON(0): Setting EXA maxPitchBytes
[   361.880] (II) EXA(0): Driver allocated offscreen pixmaps
[   361.880] (II) EXA(0): Driver registered support for the following operations:
[   361.880] (II)         Solid
[   361.880] (II)         Copy
[   361.880] (II)         Composite (RENDER acceleration)
[   361.880] (II)         UploadToScreen
[   361.880] (II)         DownloadFromScreen
[   361.881] (II) RADEON(0): Acceleration enabled
[   361.881] (==) RADEON(0): Silken mouse enabled
[   361.881] (II) RADEON(0): Set up textured video
[   361.881] (II) RADEON(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[   361.881] (WW) RADEON(0): Option "ForceMinDotClock" is not used
[   361.881] (WW) RADEON(0): Option "monitor-DVI-0" is not used
[   361.881] (WW) RADEON(0): Option "Primary" is not used
[   361.881] (WW) RADEON(0): Option "DefaultModes" is not used
[   361.881] (--) RandR disabled
[   361.881] (II) Initializing built-in extension Generic Event Extension
[   361.881] (II) Initializing built-in extension SHAPE
[   361.881] (II) Initializing built-in extension MIT-SHM
[   361.881] (II) Initializing built-in extension XInputExtension
[   361.881] (II) Initializing built-in extension XTEST
[   361.881] (II) Initializing built-in extension BIG-REQUESTS
[   361.881] (II) Initializing built-in extension SYNC
[   361.881] (II) Initializing built-in extension XKEYBOARD
[   361.881] (II) Initializing built-in extension XC-MISC
[   361.881] (II) Initializing built-in extension XINERAMA
[   361.881] (II) Initializing built-in extension XFIXES
[   361.881] (II) Initializing built-in extension RENDER
[   361.881] (II) Initializing built-in extension RANDR
[   361.881] (II) Initializing built-in extension COMPOSITE
[   361.881] (II) Initializing built-in extension DAMAGE
[   361.899] (II) AIGLX: enabled GLX_MESA_copy_sub_buffer
[   361.899] (II) AIGLX: enabled GLX_INTEL_swap_event
[   361.899] (II) AIGLX: enabled GLX_SGI_swap_control and GLX_MESA_swap_control
[   361.899] (II) AIGLX: enabled GLX_SGI_make_current_read
[   361.899] (II) AIGLX: GLX_EXT_texture_from_pixmap backed by buffer objects
[   361.900] (II) AIGLX: Loaded and initialized /usr/lib/dri/r200_dri.so
[   361.900] (II) GLX: Initialized DRI2 GL provider for screen 0
[   361.951] (II) RADEON(0): Setting screen physical size to 171 x 126
[   362.087] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[   362.087] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[   362.087] (II) LoadModule: "evdev"
[   362.087] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[   362.088] (II) Module evdev: vendor="X.Org Foundation"
[   362.088] compiled for 1.9.2, module version = 2.5.0
[   362.088] Module class: X.Org XInput Driver
[   362.088] ABI class: X.Org XInput driver, version 11.0
[   362.088] (**) Power Button: always reports core events
[   362.088] (**) Power Button: Device: "/dev/input/event1"
[   362.120] (--) Power Button: Found keys
[   362.120] (II) Power Button: Configuring as keyboard
[   362.120] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD)
[   362.120] (**) Option "xkb_rules" "evdev"
[   362.120] (**) Option "xkb_model" "evdev"
[   362.120] (**) Option "xkb_layout" "us"
[   362.154] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[   362.154] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[   362.154] (**) Power Button: always reports core events
[   362.154] (**) Power Button: Device: "/dev/input/event0"
[   362.190] (--) Power Button: Found keys
[   362.190] (II) Power Button: Configuring as keyboard
[   362.190] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD)
[   362.190] (**) Option "xkb_rules" "evdev"
[   362.190] (**) Option "xkb_model" "evdev"
[   362.190] (**) Option "xkb_layout" "us"
[   362.198] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event2)
[   362.198] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[   362.198] (**) AT Translated Set 2 keyboard: always reports core events
[   362.198] (**) AT Translated Set 2 keyboard: Device: "/dev/input/event2"
[   362.230] (--) AT Translated Set 2 keyboard: Found keys
[   362.230] (II) AT Translated Set 2 keyboard: Configuring as keyboard
[   362.230] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD)
[   362.230] (**) Option "xkb_rules" "evdev"
[   362.230] (**) Option "xkb_model" "evdev"
[   362.230] (**) Option "xkb_layout" "us"
[   362.230] (II) config/udev: Adding input device PC Speaker (/dev/input/event3)
[   362.231] (II) No input driver/identifier specified (ignoring)
[   379.552] (II) RADEON(0): EDID for output VGA-0
[   379.552] (II) RADEON(0): Printing probed modes for output VGA-0
[   379.552] (II) RADEON(0): Modeline "648x480x60.00"x60.0   13.13  648 672 736 840  480 482 487 521 interlace -hsync -vsync (15.6 kHz)
[   379.576] (II) RADEON(0): EDID for output VGA-1
[   379.582] (II) RADEON(0): EDID for output S-video
[   382.552] (II) RADEON(0): EDID for output VGA-0
[   382.553] (II) RADEON(0): Printing probed modes for output VGA-0
[   382.553] (II) RADEON(0): Modeline "648x480x60.00"x60.0   13.13  648 672 736 840  480 482 487 521 interlace -hsync -vsync (15.6 kHz)
[   382.577] (II) RADEON(0): EDID for output VGA-1
[   382.583] (II) RADEON(0): EDID for output S-video
[   387.371] (II) RADEON(0): EDID for output VGA-0
[   387.371] (II) RADEON(0): Printing probed modes for output VGA-0
[   387.371] (II) RADEON(0): Modeline "648x480x60.00"x60.0   13.13  648 672 736 840  480 482 487 521 interlace -hsync -vsync (15.6 kHz)
[   387.395] (II) RADEON(0): EDID for output VGA-1
[   387.401] (II) RADEON(0): EDID for output S-video
[   392.120] (II) RADEON(0): EDID for output VGA-0
[   392.120] (II) RADEON(0): Printing probed modes for output VGA-0
[   392.120] (II) RADEON(0): Modeline "648x480x60.00"x60.0   13.13  648 672 736 840  480 482 487 521 interlace -hsync -vsync (15.6 kHz)
[   392.144] (II) RADEON(0): EDID for output VGA-1
[   392.150] (II) RADEON(0): EDID for output S-video
[   392.156] (II) RADEON(0): EDID for output VGA-0
[   392.156] (II) RADEON(0): Printing probed modes for output VGA-0
[   392.156] (II) RADEON(0): Modeline "648x480x60.00"x60.0   13.13  648 672 736 840  480 482 487 521 interlace -hsync -vsync (15.6 kHz)
[   392.180] (II) RADEON(0): EDID for output VGA-1
[   392.186] (II) RADEON(0): EDID for output S-video
[   392.259] (II) RADEON(0): EDID for output VGA-0
[   392.259] (II) RADEON(0): Printing probed modes for output VGA-0
[   392.259] (II) RADEON(0): Modeline "648x480x60.00"x60.0   13.13  648 672 736 840  480 482 487 521 interlace -hsync -vsync (15.6 kHz)
[   392.283] (II) RADEON(0): EDID for output VGA-1
[   392.289] (II) RADEON(0): EDID for output S-video
[   392.324] (II) RADEON(0): Allocate new frame buffer 368x232 stride 384
[   392.324] (II) RADEON(0): VRAM usage limit set to 116341K
[   392.620] (II) RADEON(0): EDID for output VGA-0
[   392.620] (II) RADEON(0): Printing probed modes for output VGA-0
[   392.620] (II) RADEON(0): Modeline "648x480x60.00"x60.0   13.13  648 672 736 840  480 482 487 521 interlace -hsync -vsync (15.6 kHz)
[   392.644] (II) RADEON(0): EDID for output VGA-1
[   392.650] (II) RADEON(0): EDID for output S-video
[   392.651] (II) RADEON(0): Allocate new frame buffer 648x480 stride 704
[   392.651] (II) RADEON(0): VRAM usage limit set to 115466K
[   392.712] (II) RADEON(0): EDID for output VGA-0
[   392.712] (II) RADEON(0): Printing probed modes for output VGA-0
[   392.712] (II) RADEON(0): Modeline "648x480x60.00"x60.0   13.13  648 672 736 840  480 482 487 521 interlace -hsync -vsync (15.6 kHz)
[   392.736] (II) RADEON(0): EDID for output VGA-1
[   392.742] (II) RADEON(0): EDID for output S-video
[   392.748] (II) RADEON(0): EDID for output VGA-0
[   392.748] (II) RADEON(0): Printing probed modes for output VGA-0
[   392.748] (II) RADEON(0): Modeline "648x480x60.00"x60.0   13.13  648 672 736 840  480 482 487 521 interlace -hsync -vsync (15.6 kHz)
[   392.772] (II) RADEON(0): EDID for output VGA-1
[   392.778] (II) RADEON(0): EDID for output S-video
[   392.831] (II) RADEON(0): EDID for output VGA-0
[   392.831] (II) RADEON(0): Printing probed modes for output VGA-0
[   392.831] (II) RADEON(0): Modeline "648x480x60.00"x60.0   13.13  648 672 736 840  480 482 487 521 interlace -hsync -vsync (15.6 kHz)
[   392.855] (II) RADEON(0): EDID for output VGA-1
[   392.861] (II) RADEON(0): EDID for output S-video
[   394.878] (II) RADEON(0): EDID for output VGA-0
[   394.878] (II) RADEON(0): Printing probed modes for output VGA-0
[   394.878] (II) RADEON(0): Modeline "648x480x60.00"x60.0   13.13  648 672 736 840  480 482 487 521 interlace -hsync -vsync (15.6 kHz)
[   394.902] (II) RADEON(0): EDID for output VGA-1
[   394.908] (II) RADEON(0): EDID for output S-video
[   394.914] (II) RADEON(0): EDID for output VGA-0
[   394.914] (II) RADEON(0): Printing probed modes for output VGA-0
[   394.914] (II) RADEON(0): Modeline "648x480x60.00"x60.0   13.13  648 672 736 840  480 482 487 521 interlace -hsync -vsync (15.6 kHz)
[   394.938] (II) RADEON(0): EDID for output VGA-1
[   394.944] (II) RADEON(0): EDID for output S-video
[   395.021] (II) RADEON(0): EDID for output VGA-0
[   395.021] (II) RADEON(0): Printing probed modes for output VGA-0
[   395.021] (II) RADEON(0): Modeline "648x480x60.00"x60.0   13.13  648 672 736 840  480 482 487 521 interlace -hsync -vsync (15.6 kHz)
[   395.045] (II) RADEON(0): EDID for output VGA-1
[   395.051] (II) RADEON(0): EDID for output S-video
[   395.088] (II) RADEON(0): Allocate new frame buffer 256x256 stride 256
[   395.088] (II) RADEON(0): VRAM usage limit set to 116424K
[   395.245] (II) RADEON(0): EDID for output VGA-0
[   395.245] (II) RADEON(0): Printing probed modes for output VGA-0
[   395.245] (II) RADEON(0): Modeline "648x480x60.00"x60.0   13.13  648 672 736 840  480 482 487 521 interlace -hsync -vsync (15.6 kHz)
[   395.269] (II) RADEON(0): EDID for output VGA-1
[   395.275] (II) RADEON(0): EDID for output S-video
[   395.276] (II) RADEON(0): Allocate new frame buffer 648x480 stride 704
[   395.276] (II) RADEON(0): VRAM usage limit set to 115466K
[   395.337] (II) RADEON(0): EDID for output VGA-0
[   395.337] (II) RADEON(0): Printing probed modes for output VGA-0
[   395.337] (II) RADEON(0): Modeline "648x480x60.00"x60.0   13.13  648 672 736 840  480 482 487 521 interlace -hsync -vsync (15.6 kHz)
[   395.361] (II) RADEON(0): EDID for output VGA-1
[   395.367] (II) RADEON(0): EDID for output S-video
[   395.373] (II) RADEON(0): EDID for output VGA-0
[   395.373] (II) RADEON(0): Printing probed modes for output VGA-0
[   395.373] (II) RADEON(0): Modeline "648x480x60.00"x60.0   13.13  648 672 736 840  480 482 487 521 interlace -hsync -vsync (15.6 kHz)
[   395.397] (II) RADEON(0): EDID for output VGA-1
[   395.403] (II) RADEON(0): EDID for output S-video
[   395.507] (II) RADEON(0): EDID for output VGA-0
[   395.507] (II) RADEON(0): Printing probed modes for output VGA-0
[   395.507] (II) RADEON(0): Modeline "648x480x60.00"x60.0   13.13  648 672 736 840  480 482 487 521 interlace -hsync -vsync (15.6 kHz)
[   395.531] (II) RADEON(0): EDID for output VGA-1
[   395.537] (II) RADEON(0): EDID for output S-video
[   396.912] (II) RADEON(0): EDID for output VGA-0
[   396.912] (II) RADEON(0): Printing probed modes for output VGA-0
[   396.912] (II) RADEON(0): Modeline "648x480x60.00"x60.0   13.13  648 672 736 840  480 482 487 521 interlace -hsync -vsync (15.6 kHz)
[   396.936] (II) RADEON(0): EDID for output VGA-1
[   396.942] (II) RADEON(0): EDID for output S-video
[   396.948] (II) RADEON(0): EDID for output VGA-0
[   396.949] (II) RADEON(0): Printing probed modes for output VGA-0
[   396.949] (II) RADEON(0): Modeline "648x480x60.00"x60.0   13.13  648 672 736 840  480 482 487 521 interlace -hsync -vsync (15.6 kHz)
[   396.973] (II) RADEON(0): EDID for output VGA-1
[   396.979] (II) RADEON(0): EDID for output S-video
[   397.050] (II) RADEON(0): EDID for output VGA-0
[   397.050] (II) RADEON(0): Printing probed modes for output VGA-0
[   397.050] (II) RADEON(0): Modeline "648x480x60.00"x60.0   13.13  648 672 736 840  480 482 487 521 interlace -hsync -vsync (15.6 kHz)
[   397.074] (II) RADEON(0): EDID for output VGA-1
[   397.080] (II) RADEON(0): EDID for output S-video
[   397.116] (II) RADEON(0): Allocate new frame buffer 248x256 stride 256
[   397.116] (II) RADEON(0): VRAM usage limit set to 116424K
[   397.262] (II) RADEON(0): EDID for output VGA-0
[   397.262] (II) RADEON(0): Printing probed modes for output VGA-0
[   397.262] (II) RADEON(0): Modeline "648x480x60.00"x60.0   13.13  648 672 736 840  480 482 487 521 interlace -hsync -vsync (15.6 kHz)
[   397.286] (II) RADEON(0): EDID for output VGA-1
[   397.292] (II) RADEON(0): EDID for output S-video
[   397.293] (II) RADEON(0): Allocate new frame buffer 648x480 stride 704
[   397.293] (II) RADEON(0): VRAM usage limit set to 115466K
[   397.354] (II) RADEON(0): EDID for output VGA-0
[   397.355] (II) RADEON(0): Printing probed modes for output VGA-0
[   397.355] (II) RADEON(0): Modeline "648x480x60.00"x60.0   13.13  648 672 736 840  480 482 487 521 interlace -hsync -vsync (15.6 kHz)
[   397.378] (II) RADEON(0): EDID for output VGA-1
[   397.385] (II) RADEON(0): EDID for output S-video
[   397.390] (II) RADEON(0): EDID for output VGA-0
[   397.391] (II) RADEON(0): Printing probed modes for output VGA-0
[   397.391] (II) RADEON(0): Modeline "648x480x60.00"x60.0   13.13  648 672 736 840  480 482 487 521 interlace -hsync -vsync (15.6 kHz)
[   397.414] (II) RADEON(0): EDID for output VGA-1
[   397.421] (II) RADEON(0): EDID for output S-video
[   397.535] (II) RADEON(0): EDID for output VGA-0
[   397.535] (II) RADEON(0): Printing probed modes for output VGA-0
[   397.535] (II) RADEON(0): Modeline "648x480x60.00"x60.0   13.13  648 672 736 840  480 482 487 521 interlace -hsync -vsync (15.6 kHz)
[   397.559] (II) RADEON(0): EDID for output VGA-1
[   397.565] (II) RADEON(0): EDID for output S-video
[   399.853] (II) RADEON(0): EDID for output VGA-0
[   399.853] (II) RADEON(0): Printing probed modes for output VGA-0
[   399.853] (II) RADEON(0): Modeline "648x480x60.00"x60.0   13.13  648 672 736 840  480 482 487 521 interlace -hsync -vsync (15.6 kHz)
[   399.877] (II) RADEON(0): EDID for output VGA-1
[   399.883] (II) RADEON(0): EDID for output S-video
[   399.889] (II) RADEON(0): EDID for output VGA-0
[   399.889] (II) RADEON(0): Printing probed modes for output VGA-0
[   399.889] (II) RADEON(0): Modeline "648x480x60.00"x60.0   13.13  648 672 736 840  480 482 487 521 interlace -hsync -vsync (15.6 kHz)
[   399.913] (II) RADEON(0): EDID for output VGA-1
[   399.919] (II) RADEON(0): EDID for output S-video
[   399.989] (II) RADEON(0): EDID for output VGA-0
[   399.989] (II) RADEON(0): Printing probed modes for output VGA-0
[   399.989] (II) RADEON(0): Modeline "648x480x60.00"x60.0   13.13  648 672 736 840  480 482 487 521 interlace -hsync -vsync (15.6 kHz)
[   400.013] (II) RADEON(0): EDID for output VGA-1
[   400.019] (II) RADEON(0): EDID for output S-video
[   400.056] (II) RADEON(0): Allocate new frame buffer 512x256 stride 512
[   400.056] (II) RADEON(0): VRAM usage limit set to 116193K
[   400.266] (II) RADEON(0): EDID for output VGA-0
[   400.266] (II) RADEON(0): Printing probed modes for output VGA-0
[   400.266] (II) RADEON(0): Modeline "648x480x60.00"x60.0   13.13  648 672 736 840  480 482 487 521 interlace -hsync -vsync (15.6 kHz)
[   400.290] (II) RADEON(0): EDID for output VGA-1
[   400.296] (II) RADEON(0): EDID for output S-video
[   400.297] (II) RADEON(0): Allocate new frame buffer 648x480 stride 704
[   400.297] (II) RADEON(0): VRAM usage limit set to 115466K
[   400.358] (II) RADEON(0): EDID for output VGA-0
[   400.358] (II) RADEON(0): Printing probed modes for output VGA-0
[   400.358] (II) RADEON(0): Modeline "648x480x60.00"x60.0   13.13  648 672 736 840  480 482 487 521 interlace -hsync -vsync (15.6 kHz)
[   400.382] (II) RADEON(0): EDID for output VGA-1
[   400.388] (II) RADEON(0): EDID for output S-video
[   400.394] (II) RADEON(0): EDID for output VGA-0
[   400.394] (II) RADEON(0): Printing probed modes for output VGA-0
[   400.394] (II) RADEON(0): Modeline "648x480x60.00"x60.0   13.13  648 672 736 840  480 482 487 521 interlace -hsync -vsync (15.6 kHz)
[   400.418] (II) RADEON(0): EDID for output VGA-1
[   400.424] (II) RADEON(0): EDID for output S-video
[   400.519] (II) RADEON(0): EDID for output VGA-0
[   400.519] (II) RADEON(0): Printing probed modes for output VGA-0
[   400.519] (II) RADEON(0): Modeline "648x480x60.00"x60.0   13.13  648 672 736 840  480 482 487 521 interlace -hsync -vsync (15.6 kHz)
[   400.543] (II) RADEON(0): EDID for output VGA-1
[   400.549] (II) RADEON(0): EDID for output S-video
[   403.718] (II) RADEON(0): EDID for output VGA-0
[   403.718] (II) RADEON(0): Printing probed modes for output VGA-0
[   403.718] (II) RADEON(0): Modeline "648x480x60.00"x60.0   13.13  648 672 736 840  480 482 487 521 interlace -hsync -vsync (15.6 kHz)
[   403.742] (II) RADEON(0): EDID for output VGA-1
[   403.748] (II) RADEON(0): EDID for output S-video
[   403.754] (II) RADEON(0): EDID for output VGA-0
[   403.754] (II) RADEON(0): Printing probed modes for output VGA-0
[   403.754] (II) RADEON(0): Modeline "648x480x60.00"x60.0   13.13  648 672 736 840  480 482 487 521 interlace -hsync -vsync (15.6 kHz)
[   403.778] (II) RADEON(0): EDID for output VGA-1
[   403.784] (II) RADEON(0): EDID for output S-video
[   403.870] (II) RADEON(0): EDID for output VGA-0
[   403.871] (II) RADEON(0): Printing probed modes for output VGA-0
[   403.871] (II) RADEON(0): Modeline "648x480x60.00"x60.0   13.13  648 672 736 840  480 482 487 521 interlace -hsync -vsync (15.6 kHz)
[   403.895] (II) RADEON(0): EDID for output VGA-1
[   403.901] (II) RADEON(0): EDID for output S-video
[   403.938] (II) RADEON(0): Allocate new frame buffer 704x528 stride 704
[   403.939] (II) RADEON(0): VRAM usage limit set to 115347K
[   415.723] (II) AIGLX: Suspending AIGLX clients for VT switch
ves
« Reply #822 on: February 04, 2011, 05:17:43 pm »
Xorg.0.log.old 1 Part
[b]Xorg.0.log.old[/b]
[code][   103.768]
[   103.772] X Protocol Version 11, Revision 0
[   103.773] Build Operating System: Linux 2.6.38-rc1 i686 Gentoo
[   103.774] Current Operating System: Linux GroovyArcade 2.6.38-rc2+ #1 SMP Mon Jan 24 22:01:58 CST 2011 i686
[   103.777] Kernel command line: root=/dev/sda1 init=/boot/linuxrc initrd udev nodevfs CGAVGA video=VGA-1:640x480ec
[   103.781] Build Date: 31 January 2011  12:08:30PM
[   103.783]
[   103.785] Current version of pixman: 0.20.0
[   103.787] Before reporting problems, check http://wiki.x.org
[   103.792] Markers: (--) probed, (**) from config file, (==) default setting,
[   103.801] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Feb  4 17:04:06 2011
[   103.804] (==) Using config file: "/etc/X11/xorg.conf"
[   103.807] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[   103.811] (**) Option "defaultserverlayout" "Arcade Cabinet"
[   103.811] (**) ServerLayout "Arcade Cabinet"
[   103.811] (**) |-->Screen "Screen0" (0)
[   103.811] (**) |   |-->Monitor "DVI-0"
[   103.811] (**) |   |-->Device "Card0"
[   103.811] (**) |-->Input Device "Mouse0"
[   103.811] (**) |-->Input Device "Keyboard0"
[   103.811] (**) Option "DontZap" "off"
[   103.811] (**) Option "DontZoom" "on"
[   103.811] (**) Option "AllowMouseOpenFail" "true"
[   103.812] (**) Option "BlankTime" "0"
[   103.812] (**) Option "StandbyTime" "0"
[   103.812] (**) Option "SuspendTime" "0"
[   103.812] (**) Option "OffTime" "0"
[   103.812] (**) Option "NoPM" "True"
[   103.812] (**) Option "AIGLX" "on"
[   103.812] (==) Automatically adding devices
[   103.812] (==) Automatically enabling devices
[   103.812] (==) FontPath set to:
[   103.812] (==) ModulePath set to "/usr/lib/xorg/modules"
[   103.812] (**) Extension "Composite" is enabled
[   103.812] (WW) AllowEmptyInput is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[   103.812] (WW) Disabling Mouse0
[   103.812] (WW) Disabling Keyboard0
[   103.812] (II) Loader magic: 0x81f2d60
[   103.812] (II) Module ABI versions:
[   103.812] X.Org ANSI C Emulation: 0.4
[   103.812] X.Org Video Driver: 8.0
[   103.812] X.Org XInput driver : 11.0
[   103.812] X.Org Server Extension : 4.0
[   103.813] (--) PCI:*(0:1:0:0) 1002:5964:1787:5964 rev 1, Mem @ 0xd0000000/134217728, 0xe5000000/65536, I/O @ 0x00009000/256, BIOS @ 0x????????/131072
[   103.813] (--) PCI: (0:1:0:1) 1002:5d44:1787:5965 rev 1, Mem @ 0xd8000000/134217728, 0xe5010000/65536
[   103.813] (II) LoadModule: "extmod"
[   103.814] (II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
[   103.814] (II) Module extmod: vendor="X.Org Foundation"
[   103.814] compiled for 1.9.2, module version = 1.0.0
[   103.814] Module class: X.Org Server Extension
[   103.814] ABI class: X.Org Server Extension, version 4.0
[   103.814] (II) Loading extension MIT-SCREEN-SAVER
[   103.814] (II) Loading extension XFree86-VidModeExtension
[   103.814] (II) Loading extension XFree86-DGA
[   103.814] (II) Loading extension DPMS
[   103.814] (II) Loading extension XVideo
[   103.814] (II) Loading extension XVideo-MotionCompensation
[   103.814] (II) Loading extension X-Resource
[   103.814] (II) LoadModule: "dbe"
[   103.814] (II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
[   103.814] (II) Module dbe: vendor="X.Org Foundation"
[   103.814] (II) Loading extension DOUBLE-BUFFER
[   103.814] (II) LoadModule: "glx"
[   103.815] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[   103.815] (II) Module glx: vendor="X.Org Foundation"
[   103.815] compiled for 1.9.2, module version = 1.0.0
[   103.815] ABI class: X.Org Server Extension, version 4.0
[   103.815] (**) AIGLX enabled
[   103.815] (II) Loading extension GLX
[   103.815] (II) LoadModule: "record"
[   103.815] (II) Loading /usr/lib/xorg/modules/extensions/librecord.so
[   103.815] (II) Module record: vendor="X.Org Foundation"
[   103.815] compiled for 1.9.2, module version = 1.13.0
[   103.815] Module class: X.Org Server Extension
[   103.815] (II) Loading extension RECORD
[   103.815] (II) LoadModule: "dri"
[   103.815] (II) Loading /usr/lib/xorg/modules/extensions/libdri.so
[   103.816] (II) Module dri: vendor="X.Org Foundation"
[   103.816] compiled for 1.9.2, module version = 1.0.0
[   103.816] ABI class: X.Org Server Extension, version 4.0
[   103.816] (II) Loading extension XFree86-DRI
[   103.816] (II) LoadModule: "dri2"
[   103.816] (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
[   103.816] (II) Module dri2: vendor="X.Org Foundation"
[   103.816] compiled for 1.9.2, module version = 1.2.0
[   103.816] (II) Loading extension DRI2
[   103.816] (II) LoadModule: "radeon"
[   103.816] (II) Loading /usr/lib/xorg/modules/drivers/radeon_drv.so
[   103.817] (II) Module radeon: vendor="X.Org Foundation"
[   103.817] compiled for 1.9.2, module version = 6.13.99
[   103.817] Module class: X.Org Video Driver
[   103.817] ABI class: X.Org Video Driver, version 8.0
[   103.817] (II) RADEON: Driver for ATI Radeon chipsets:
CAICOS
[   103.825] (--) using VT number 7
[/code]
ves
« Reply #823 on: February 04, 2011, 05:18:51 pm »
Xorg.0.log.old 2 Part
[   103.832] (II) [KMS] Kernel modesetting enabled.
[   103.832] (**) RADEON(0): Depth 24, (--) framebuffer bpp 32
[   103.832] (II) RADEON(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[   103.832] (==) RADEON(0): Default visual is TrueColor
[   103.832] (**) RADEON(0): Option "EnablePageFlip" "on"
[   103.832] (==) RADEON(0): RGB weight 888
[   103.832] (II) RADEON(0): Using 8 bits per RGB (8 bit DAC)
[   103.832] (--) RADEON(0): Chipset: "ATI Radeon 9200SE 5964 (AGP)" (ChipID = 0x5964)
[   103.832] (II) RADEON(0): AGP card detected
[   103.832] drmOpenDevice: node name is /dev/dri/card0
[   103.832] drmOpenDevice: open result is 8, (OK)
[   103.832] drmOpenByBusid: Searching for BusID pci:0000:01:00.0
[   103.832] drmOpenByBusid: drmOpenMinor returns 8
[   103.832] drmOpenByBusid: drmGetBusid reports pci:0000:01:00.0
[   103.832] (II) RADEON(0): KMS Color Tiling: disabled
[   103.832] (II) RADEON(0): KMS Pageflipping: enabled
[   103.832] (II) RADEON(0): SwapBuffers wait for vsync: enabled
[   103.832] (II) RADEON(0): Output VGA-0 using monitor section DVI-0
[   103.833] (**) RADEON(0): Option "Primary" "True"
[   103.833] (**) RADEON(0): Option "DefaultModes" "False"
[   103.856] (II) RADEON(0): Output VGA-1 has no monitor section
[   103.863] (II) RADEON(0): Output S-video has no monitor section
[   103.863] (**) RADEON(0): Option "ModeDebug" "true"
[   103.863] (II) RADEON(0): EDID for output VGA-0
[   103.863] (II) RADEON(0): Printing probed modes for output VGA-0
[   103.863] (II) RADEON(0): Modeline "648x480x60.00"x60.0   13.13  648 672 736 840  480 482 487 521 interlace -hsync -vsync (15.6 kHz)
[   103.887] (II) RADEON(0): EDID for output VGA-1
[   103.893] (II) RADEON(0): EDID for output S-video
[   103.893] (II) RADEON(0): Output VGA-0 connected
[   103.893] (II) RADEON(0): Output VGA-1 disconnected
[   103.893] (II) RADEON(0): Output S-video disconnected
[   103.893] (II) RADEON(0): Using fuzzy aspect match for initial modes
[   103.893] (II) RADEON(0): Output VGA-0 using initial mode 648x480x60.00
[   103.893] (II) RADEON(0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
[   103.893] (II) RADEON(0): mem size init: gart size :1fdff000 vram size: s:8000000 visible:7e94000
[   103.893] (II) RADEON(0): EXA: Driver will allow EXA pixmaps in VRAM
[   103.893] (==) RADEON(0): DPI set to (96, 96)
[   103.893] (II) Loading sub module "fb"
[   103.893] (II) LoadModule: "fb"
[   103.893] (II) Loading /usr/lib/xorg/modules/libfb.so
[   103.893] (II) Module fb: vendor="X.Org Foundation"
[   103.893] compiled for 1.9.2, module version = 1.0.0
[   103.893] ABI class: X.Org ANSI C Emulation, version 0.4
[   103.893] (II) Loading sub module "ramdac"
[   103.893] (II) LoadModule: "ramdac"
[   103.894] (II) Module "ramdac" already built-in
[   103.894] (II) Loading sub module "exa"
[   103.894] (II) LoadModule: "exa"
[   103.894] (II) Loading /usr/lib/xorg/modules/libexa.so
[   103.894] (II) Module exa: vendor="X.Org Foundation"
[   103.894] compiled for 1.9.2, module version = 2.5.0
[   103.894] ABI class: X.Org Video Driver, version 8.0
[   103.894] (--) Depth 24 pixmap format is 32 bpp
[   103.894] (II) RADEON(0): [DRI2] Setup complete
[   103.894] (II) RADEON(0): [DRI2]   DRI driver: r200
[   103.894] (II) RADEON(0): Front buffer size: 1320K
[   103.894] (II) RADEON(0): VRAM usage limit set to 115466K
[   103.895] (==) RADEON(0): Backing store disabled
[   103.895] (II) RADEON(0): Direct rendering enabled
[   103.895] (II) RADEON(0): Render acceleration enabled for R200 type cards.
[   103.895] (II) RADEON(0): Setting EXA maxPitchBytes
[   103.895] (II) EXA(0): Driver allocated offscreen pixmaps
[   103.895] (II) EXA(0): Driver registered support for the following operations:
[   103.895] (II)         Solid
[   103.895] (II)         Copy
[   103.895] (II)         Composite (RENDER acceleration)
[   103.895] (II)         UploadToScreen
[   103.895] (II)         DownloadFromScreen
[   103.895] (II) RADEON(0): Acceleration enabled
[   103.895] (==) RADEON(0): Silken mouse enabled
[   103.895] (II) RADEON(0): Set up textured video
[   103.895] (II) RADEON(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[   103.895] (WW) RADEON(0): Option "ForceMinDotClock" is not used
[   103.895] (WW) RADEON(0): Option "monitor-DVI-0" is not used
[   103.895] (WW) RADEON(0): Option "Primary" is not used
[   103.895] (WW) RADEON(0): Option "DefaultModes" is not used
[   103.895] (--) RandR disabled
[   103.896] (II) Initializing built-in extension Generic Event Extension
[   103.896] (II) Initializing built-in extension SHAPE
[   103.896] (II) Initializing built-in extension MIT-SHM
[   103.896] (II) Initializing built-in extension XInputExtension
[   103.896] (II) Initializing built-in extension XTEST
[   103.896] (II) Initializing built-in extension BIG-REQUESTS
[   103.896] (II) Initializing built-in extension SYNC
[   103.896] (II) Initializing built-in extension XKEYBOARD
[   103.896] (II) Initializing built-in extension XC-MISC
[   103.896] (II) Initializing built-in extension XINERAMA
[   103.896] (II) Initializing built-in extension XFIXES
[   103.896] (II) Initializing built-in extension RENDER
[   103.896] (II) Initializing built-in extension RANDR
[   103.896] (II) Initializing built-in extension COMPOSITE
[   103.896] (II) Initializing built-in extension DAMAGE
[   103.913] (II) AIGLX: enabled GLX_MESA_copy_sub_buffer
[   103.913] (II) AIGLX: enabled GLX_INTEL_swap_event
[   103.913] (II) AIGLX: enabled GLX_SGI_swap_control and GLX_MESA_swap_control
[   103.913] (II) AIGLX: enabled GLX_SGI_make_current_read
[   103.913] (II) AIGLX: GLX_EXT_texture_from_pixmap backed by buffer objects
[   103.914] (II) AIGLX: Loaded and initialized /usr/lib/dri/r200_dri.so
[   103.914] (II) GLX: Initialized DRI2 GL provider for screen 0
[   103.966] (II) RADEON(0): Setting screen physical size to 171 x 126
[   104.101] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[   104.102] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[   104.102] (II) LoadModule: "evdev"
[   104.102] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[   104.102] (II) Module evdev: vendor="X.Org Foundation"
[   104.102] compiled for 1.9.2, module version = 2.5.0
[   104.102] Module class: X.Org XInput Driver
[   104.102] ABI class: X.Org XInput driver, version 11.0
[   104.102] (**) Power Button: always reports core events
[   104.102] (**) Power Button: Device: "/dev/input/event1"
[   104.140] (--) Power Button: Found keys
[   104.140] (II) Power Button: Configuring as keyboard
[   104.140] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD)
[   104.140] (**) Option "xkb_rules" "evdev"
[   104.140] (**) Option "xkb_model" "evdev"
[   104.140] (**) Option "xkb_layout" "us"
[   104.175] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[   104.175] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[   104.175] (**) Power Button: always reports core events
[   104.175] (**) Power Button: Device: "/dev/input/event0"
[   104.230] (--) Power Button: Found keys
[   104.230] (II) Power Button: Configuring as keyboard
[   104.230] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD)
[   104.230] (**) Option "xkb_rules" "evdev"
[   104.230] (**) Option "xkb_model" "evdev"
[   104.230] (**) Option "xkb_layout" "us"
[   104.237] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event2)
[   104.237] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[   104.237] (**) AT Translated Set 2 keyboard: always reports core events
[   104.237] (**) AT Translated Set 2 keyboard: Device: "/dev/input/event2"
[   104.270] (--) AT Translated Set 2 keyboard: Found keys
[   104.270] (II) AT Translated Set 2 keyboard: Configuring as keyboard
[   104.270] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD)
[   104.270] (**) Option "xkb_rules" "evdev"
[   104.270] (**) Option "xkb_model" "evdev"
[   104.270] (**) Option "xkb_layout" "us"
[   104.270] (II) config/udev: Adding input device PC Speaker (/dev/input/event3)
[   104.271] (II) No input driver/identifier specified (ignoring)
[   107.730] (II) AIGLX: Suspending AIGLX clients for VT switch
[   134.993] (II) AIGLX: Resuming AIGLX clients after VT switch
[   135.045] (II) RADEON(0): EDID for output VGA-0
[   135.045] (II) RADEON(0): Printing probed modes for output VGA-0
[   135.045] (II) RADEON(0): Modeline "648x480x60.00"x60.0   13.13  648 672 736 840  480 482 487 521 interlace -hsync -vsync (15.6 kHz)
[   135.069] (II) RADEON(0): EDID for output VGA-1
[   135.075] (II) RADEON(0): EDID for output S-video
[   144.210] (II) RADEON(0): EDID for output VGA-0
[   144.210] (II) RADEON(0): Printing probed modes for output VGA-0
[   144.210] (II) RADEON(0): Modeline "648x480x60.00"x60.0   13.13  648 672 736 840  480 482 487 521 interlace -hsync -vsync (15.6 kHz)
[   144.234] (II) RADEON(0): EDID for output VGA-1
[   144.240] (II) RADEON(0): EDID for output S-video
[   172.132] (II) AIGLX: Suspending AIGLX clients for VT switch
[   181.255] (II) AIGLX: Resuming AIGLX clients after VT switch
[   181.306] (II) RADEON(0): EDID for output VGA-0
[   181.306] (II) RADEON(0): Printing probed modes for output VGA-0
[   181.307] (II) RADEON(0): Modeline "648x480x60.00"x60.0   13.13  648 672 736 840  480 482 487 521 interlace -hsync -vsync (15.6 kHz)
[   181.330] (II) RADEON(0): EDID for output VGA-1
[   181.336] (II) RADEON(0): EDID for output S-video
[   204.121] (II) AIGLX: Suspending AIGLX clients for VT switch
[   218.909] (II) AIGLX: Resuming AIGLX clients after VT switch
[   218.960] (II) RADEON(0): EDID for output VGA-0
[   218.960] (II) RADEON(0): Printing probed modes for output VGA-0
[   218.960] (II) RADEON(0): Modeline "648x480x60.00"x60.0   13.13  648 672 736 840  480 482 487 521 interlace -hsync -vsync (15.6 kHz)
[   218.984] (II) RADEON(0): EDID for output VGA-1
[   218.990] (II) RADEON(0): EDID for output S-video
[   222.522] (II) RADEON(0): EDID for output VGA-0
[   222.523] (II) RADEON(0): Printing probed modes for output VGA-0
[   222.523] (II) RADEON(0): Modeline "648x480x60.00"x60.0   13.13  648 672 736 840  480 482 487 521 interlace -hsync -vsync (15.6 kHz)
[   222.547] (II) RADEON(0): EDID for output VGA-1
[   222.553] (II) RADEON(0): EDID for output S-video
[   228.452] (II) RADEON(0): EDID for output VGA-0
[   228.452] (II) RADEON(0): Printing probed modes for output VGA-0
[   228.452] (II) RADEON(0): Modeline "648x480x60.00"x60.0   13.13  648 672 736 840  480 482 487 521 interlace -hsync -vsync (15.6 kHz)
[   228.476] (II) RADEON(0): EDID for output VGA-1
[   228.482] (II) RADEON(0): EDID for output S-video
[   231.560] (II) AIGLX: Suspending AIGLX clients for VT switch
[   301.064] (II) AIGLX: Resuming AIGLX clients after VT switch
[   301.115] (II) RADEON(0): EDID for output VGA-0
[   301.115] (II) RADEON(0): Printing probed modes for output VGA-0
[   301.115] (II) RADEON(0): Modeline "648x480x60.00"x60.0   13.13  648 672 736 840  480 482 487 521 interlace -hsync -vsync (15.6 kHz)
[   301.139] (II) RADEON(0): EDID for output VGA-1
[   301.145] (II) RADEON(0): EDID for output S-video
[   308.033] (II) RADEON(0): EDID for output VGA-0
[   308.033] (II) RADEON(0): Printing probed modes for output VGA-0
[   308.033] (II) RADEON(0): Modeline "648x480x60.00"x60.0   13.13  648 672 736 840  480 482 487 521 interlace -hsync -vsync (15.6 kHz)
[   308.057] (II) RADEON(0): EDID for output VGA-1
[   308.063] (II) RADEON(0): EDID for output S-video
[   331.724] (II) AIGLX: Suspending AIGLX clients for VT switch
[   337.697] (II) AIGLX: Resuming AIGLX clients after VT switch
[   337.748] (II) RADEON(0): EDID for output VGA-0
[   337.748] (II) RADEON(0): Printing probed modes for output VGA-0
[   337.748] (II) RADEON(0): Modeline "648x480x60.00"x60.0   13.13  648 672 736 840  480 482 487 521 interlace -hsync -vsync (15.6 kHz)
[   337.772] (II) RADEON(0): EDID for output VGA-1
[   337.778] (II) RADEON(0): EDID for output S-video
[   357.375] (II) AIGLX: Suspending AIGLX clients for VT switch
[   359.349] (II) AT Translated Set 2 keyboard: Close
[   359.349] (II) UnloadModule: "evdev"
[   359.349] (II) Power Button: Close
[   359.350] (II) UnloadModule: "evdev"
[   359.350] (II) Power Button: Close
« Last Edit: February 04, 2011, 05:21:52 pm by ves »
ves
  • Last login:April 11, 2020, 02:57:49 am
Re: Switchres arcade monitor modeline generator and mame wrapper
« Reply #824 on: February 04, 2011, 05:19:50 pm »
dmesg 1 Part
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Linux version 2.6.38-rc2+ (root@mcp) (gcc version 4.4.4 (Gentoo 4.4.4-r2 p1.3, pie-0.4.5) ) #1 SMP Mon Jan 24 22:01:58 CST 2011
[    0.000000] BIOS-provided physical RAM map:
[    0.000000]  BIOS-e820: 0000000000000000 - 000000000009f800 (usable)
[    0.000000]  BIOS-e820: 000000000009f800 - 00000000000a0000 (reserved)
[    0.000000]  BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[    0.000000]  BIOS-e820: 0000000000100000 - 000000001fff0000 (usable)
[    0.000000]  BIOS-e820: 000000001fff0000 - 000000001fff3000 (ACPI NVS)
[    0.000000]  BIOS-e820: 000000001fff3000 - 0000000020000000 (ACPI data)
[    0.000000]  BIOS-e820: 00000000fec00000 - 0000000100000000 (reserved)
[    0.000000] Notice: NX (Execute Disable) protection missing in CPU!
[    0.000000] DMI 2.3 present.
[    0.000000] DMI: GA-8S661FXM-775/ , BIOS F2 02/25/2005
[    0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[    0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[    0.000000] last_pfn = 0x1fff0 max_arch_pfn = 0x100000
[    0.000000] MTRR default type: uncachable
[    0.000000] MTRR fixed ranges enabled:
[    0.000000]   00000-9FFFF write-back
[    0.000000]   A0000-BFFFF uncachable
[    0.000000]   C0000-CCFFF write-protect
[    0.000000]   CD000-EFFFF uncachable
[    0.000000]   F0000-FFFFF write-through
[    0.000000] MTRR variable ranges enabled:
[    0.000000]   0 base 000000000 mask FE0000000 write-back
[    0.000000]   1 disabled
[    0.000000]   2 disabled
[    0.000000]   3 disabled
[    0.000000]   4 disabled
[    0.000000]   5 disabled
[    0.000000]   6 disabled
[    0.000000]   7 disabled
[    0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[    0.000000] found SMP MP-table at [c00f54f0] f54f0
[    0.000000] Scanning 0 areas for low memory corruption
[    0.000000] initial memory mapped : 0 - 01c00000
[    0.000000] init_memory_mapping: 0000000000000000-000000001fff0000
[    0.000000]  0000000000 - 0000400000 page 4k
[    0.000000]  0000400000 - 001fc00000 page 2M
[    0.000000]  001fc00000 - 001fff0000 page 4k
[    0.000000] kernel direct mapping tables up to 1fff0000 @ 1bfb000-1c00000
[    0.000000] RAMDISK: 1fc3f000 - 1ffe0000
[    0.000000] ACPI: RSDP 000f6e40 00014 (v00 GBT   )
[    0.000000] ACPI: RSDT 1fff3040 00034 (v01 GBT    AWRDACPI 42302E31 AWRD 01010101)
[    0.000000] ACPI: FACP 1fff30c0 00074 (v01 GBT    AWRDACPI 42302E31 AWRD 01010101)
[    0.000000] ACPI: DSDT 1fff3180 034EE (v01 GBT    AWRDACPI 00001000 MSFT 0100000C)
[    0.000000] ACPI: FACS 1fff0000 00040
[    0.000000] ACPI: APIC 1fff66c0 00068 (v01 GBT    AWRDACPI 42302E31 AWRD 01010101)
[    0.000000] ACPI: SSDT 1fff6770 0015C (v01  PmRef  Cpu0Ist 00003000 INTL 20040311)
[    0.000000] ACPI: SSDT 1fff6c00 0014E (v01  PmRef    CpuPm 00003000 INTL 20040311)
[    0.000000] ACPI: Local APIC address 0xfee00000
[    0.000000] 0MB HIGHMEM available.
[    0.000000] 511MB LOWMEM available.
[    0.000000]   mapped low ram: 0 - 1fff0000
[    0.000000]   low ram: 0 - 1fff0000
[    0.000000] Zone PFN ranges:
[    0.000000]   DMA      0x00000010 -> 0x00001000
[    0.000000]   Normal   0x00001000 -> 0x0001fff0
[    0.000000]   HighMem  empty
[    0.000000] Movable zone start PFN for each node
[    0.000000] early_node_map[2] active PFN ranges
[    0.000000]     0: 0x00000010 -> 0x0000009f
[    0.000000]     0: 0x00000100 -> 0x0001fff0
[    0.000000] On node 0 totalpages: 130943
[    0.000000]   DMA zone: 32 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 3951 pages, LIFO batch:0
[    0.000000]   Normal zone: 992 pages used for memmap
[    0.000000]   Normal zone: 125968 pages, LIFO batch:31
[    0.000000] Using APIC driver default
[    0.000000] ACPI: PM-Timer IO Port: 0x1008
[    0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] enabled)
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] dfl dfl lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] dfl dfl lint[0x1])
[    0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
[    0.000000] IOAPIC[0]: apic_id 2, version 20, address 0xfec00000, GSI 0-23
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 dfl dfl)
[    0.000000] ACPI: IRQ0 used by override.
[    0.000000] ACPI: IRQ2 used by override.
[    0.000000] ACPI: IRQ9 used by override.
[    0.000000] Using ACPI (MADT) for SMP configuration information
[    0.000000] SMP: Allowing 2 CPUs, 0 hotplug CPUs
[    0.000000] nr_irqs_gsi: 40
[    0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[    0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000f0000
[    0.000000] PM: Registered nosave memory: 00000000000f0000 - 0000000000100000
[    0.000000] Allocating PCI resources starting at 20000000 (gap: 20000000:dec00000)
[    0.000000] Booting paravirtualized kernel on bare hardware
[    0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:2 nr_node_ids:1
[    0.000000] PERCPU: Embedded 12 pages/cpu @df400000 s27520 r0 d21632 u2097152
[    0.000000] pcpu-alloc: s27520 r0 d21632 u2097152 alloc=1*4194304
[    0.000000] pcpu-alloc: [0] 0 1
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 129919
[    0.000000] Kernel command line: root=/dev/sda1 init=/boot/linuxrc initrd udev nodevfs CGAVGA video=VGA-1:640x480ec
[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Initializing CPU#0
[    0.000000] Initializing HighMem for node 0 (00000000:00000000)
[    0.000000] Memory: 506848k/524224k available (4296k kernel code, 16924k reserved, 2678k data, 556k init, 0k highmem)
[    0.000000] virtual kernel memory layout:
[    0.000000]     fixmap  : 0xfff16000 - 0xfffff000   ( 932 kB)
[    0.000000]     pkmap   : 0xff800000 - 0xffc00000   (4096 kB)
[    0.000000]     vmalloc : 0xe07f0000 - 0xff7fe000   ( 496 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xdfff0000   ( 511 MB)
[    0.000000]       .init : 0xc16d0000 - 0xc175b000   ( 556 kB)
[    0.000000]       .data : 0xc1432280 - 0xc16cfb40   (2678 kB)
[    0.000000]       .text : 0xc1000000 - 0xc1432280   (4296 kB)
[    0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[    0.000000] SLUB: Genslabs=15, HWalign=128, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[    0.000000] RCU-based detection of stalled CPUs is disabled.
[    0.000000] NR_IRQS:2304 nr_irqs:512 16
[    0.000000] CPU 0 irqstacks, hard=df008000 soft=df00a000
[    0.000000] Console: colour VGA+ 80x25
[    0.000000] console [tty0] enabled
[    0.000000] allocated 2621440 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[    0.000000] Fast TSC calibration using PIT
[    0.000000] Detected 3001.013 MHz processor.
[    0.020011] Calibrating delay loop (skipped), value calculated using timer frequency.. 6002.02 BogoMIPS (lpj=30010130)
[    0.020100] pid_max: default: 32768 minimum: 301
[    0.020204] Security Framework initialized
[    0.020299] AppArmor: AppArmor initialized
[    0.020432] Mount-cache hash table entries: 512
[    0.020769] Initializing cgroup subsys ns
[    0.020819] ns_cgroup deprecated: consider using the 'clone_children' flag without the ns_cgroup.
[    0.020874] Initializing cgroup subsys cpuacct
[    0.020921] Initializing cgroup subsys memory
[    0.020976] Initializing cgroup subsys devices
[    0.021019] Initializing cgroup subsys freezer
[    0.021124] CPU: Physical Processor ID: 0
[    0.021166] CPU: Processor Core ID: 0
[    0.021210] mce: CPU supports 4 MCE banks
[    0.021275] CPU0: Thermal monitoring enabled (TM1)
[    0.021325] using mwait in idle threads.
[    0.025883] ACPI: Core revision 20110112
[    0.032687] ftrace: allocating 22184 entries in 44 pages
[    0.040132] Enabling APIC mode:  Flat.  Using 1 I/O APICs
[    0.040444] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.149324] CPU0: Intel(R) Pentium(R) 4 CPU 3.00GHz stepping 03
[    0.150000] Performance Events: Netburst events, Netburst P4/Xeon PMU driver.
[    0.150000] ... version:                0
[    0.150000] ... bit width:              40
[    0.150000] ... generic registers:      18
[    0.150000] ... value mask:             000000ffffffffff
[    0.150000] ... max period:             0000007fffffffff
[    0.150000] ... fixed-purpose events:   0
[    0.150000] ... event mask:             000000000003ffff
[    0.150000] CPU 1 irqstacks, hard=de8a6000 soft=de8b0000
[    0.150000] Booting Node   0, Processors  #1 Ok.
[    0.030000] Initializing CPU#1
[    0.310036] Brought up 2 CPUs
[    0.310126] Total of 2 processors activated (12003.89 BogoMIPS).
[    0.310872] devtmpfs: initialized
[    0.311840] print_constraints: dummy:
[    0.311909] Time: 23:02:22  Date: 02/04/11
[    0.311994] NET: Registered protocol family 16
[    0.312219] ACPI: bus type pci registered
[    0.336060] PCI: PCI BIOS revision 2.10 entry at 0xfb6d0, last bus=1
[    0.336105] PCI: Using configuration type 1 for base access
[    0.337708] bio: create slab <bio-0> at 0
[    0.337708] ACPI: EC: Look up EC in DSDT
[    0.343393] ACPI: SSDT 1fff6b70 00087 (v01  PmRef  Cpu1Ist 00003000 INTL 20040311)
[    0.343724] ACPI: Dynamic OEM Table Load:
[    0.343826] ACPI: SSDT   (null) 00087 (v01  PmRef  Cpu1Ist 00003000 INTL 20040311)
[    0.344113] ACPI: Interpreter enabled
[    0.344161] ACPI: (supports S0 S1 S4 S5)
[    0.344346] ACPI: Using IOAPIC for interrupt routing
[    0.349522] ACPI: No dock devices found.
[    0.349567] HEST: Table not found.
[    0.349610] PCI: Ignoring host bridge windows from ACPI; if necessary, use "pci=use_crs" and report a bug
[    0.349755] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[    0.349987] pci_root PNP0A03:00: host bridge window [io  0x0000-0x047f] (ignored)
[    0.349992] pci_root PNP0A03:00: host bridge window [io  0x0490-0x0cf7] (ignored)
[    0.350006] pci_root PNP0A03:00: host bridge window [io  0x0d00-0x0fff] (ignored)
[    0.350011] pci_root PNP0A03:00: host bridge window [io  0x1100-0xffff] (ignored)
[    0.350015] pci_root PNP0A03:00: host bridge window [mem 0x000a0000-0x000bffff] (ignored)
[    0.350019] pci_root PNP0A03:00: host bridge window [mem 0x20000000-0xfebfffff] (ignored)
[    0.350040] pci 0000:00:00.0: [1039:0661] type 0 class 0x000600
[    0.350053] pci 0000:00:00.0: reg 10: [mem 0xe0000000-0xe3ffffff]
[    0.350135] pci 0000:00:01.0: [1039:0003] type 1 class 0x000604
[    0.350184] pci 0000:00:02.0: [1039:0964] type 0 class 0x000601
[    0.350279] pci 0000:00:02.5: [1039:5513] type 0 class 0x000101
[    0.350299] pci 0000:00:02.5: reg 10: [io  0x0000-0x0007]
[    0.350313] pci 0000:00:02.5: reg 14: [io  0x0000-0x0003]
[    0.350325] pci 0000:00:02.5: reg 18: [io  0x0000-0x0007]
[    0.350337] pci 0000:00:02.5: reg 1c: [io  0x0000-0x0003]
[    0.350349] pci 0000:00:02.5: reg 20: [io  0xf000-0xf00f]
[    0.350398] pci 0000:00:02.7: [1039:7012] type 0 class 0x000401
[    0.350420] pci 0000:00:02.7: reg 10: [io  0xa000-0xa0ff]
[    0.350433] pci 0000:00:02.7: reg 14: [io  0xa400-0xa47f]
[    0.350502] pci 0000:00:02.7: supports D1 D2
[    0.350506] pci 0000:00:02.7: PME# supported from D3hot D3cold
[    0.350511] pci 0000:00:02.7: PME# disabled
[    0.350530] pci 0000:00:03.0: [1039:7001] type 0 class 0x000c03
[    0.350547] pci 0000:00:03.0: reg 10: [mem 0xe7004000-0xe7004fff]
[    0.350621] pci 0000:00:03.1: [1039:7001] type 0 class 0x000c03
[    0.350637] pci 0000:00:03.1: reg 10: [mem 0xe7000000-0xe7000fff]
[    0.350709] pci 0000:00:03.2: [1039:7001] type 0 class 0x000c03
[    0.350725] pci 0000:00:03.2: reg 10: [mem 0xe7001000-0xe7001fff]
[    0.350801] pci 0000:00:03.3: [1039:7002] type 0 class 0x000c03
[    0.350822] pci 0000:00:03.3: reg 10: [mem 0xe7002000-0xe7002fff]
[    0.350896] pci 0000:00:03.3: PME# supported from D0 D3hot D3cold
[    0.350902] pci 0000:00:03.3: PME# disabled
[    0.350930] pci 0000:00:04.0: [1039:0900] type 0 class 0x000200
[    0.350951] pci 0000:00:04.0: reg 10: [io  0xa800-0xa8ff]
[    0.350964] pci 0000:00:04.0: reg 14: [mem 0xe7003000-0xe7003fff]
[    0.351013] pci 0000:00:04.0: reg 30: [mem 0x00000000-0x0001ffff pref]
[    0.351036] pci 0000:00:04.0: supports D1 D2
[    0.351040] pci 0000:00:04.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.351045] pci 0000:00:04.0: PME# disabled
[    0.351069] pci 0000:00:05.0: [1039:0180] type 0 class 0x000101
[    0.351090] pci 0000:00:05.0: reg 10: [io  0xac00-0xac07]
[    0.351102] pci 0000:00:05.0: reg 14: [io  0xb000-0xb003]
[    0.351114] pci 0000:00:05.0: reg 18: [io  0xb400-0xb407]
[    0.351126] pci 0000:00:05.0: reg 1c: [io  0xb800-0xb803]
[    0.351138] pci 0000:00:05.0: reg 20: [io  0xbc00-0xbc0f]
[    0.351150] pci 0000:00:05.0: reg 24: [io  0xc000-0xc07f]
[    0.351183] pci 0000:00:05.0: PME# supported from D3cold
[    0.351189] pci 0000:00:05.0: PME# disabled
[    0.351268] pci 0000:01:00.0: [1002:5964] type 0 class 0x000300
[    0.351289] pci 0000:01:00.0: reg 10: [mem 0xd0000000-0xd7ffffff pref]
[    0.351300] pci 0000:01:00.0: reg 14: [io  0x9000-0x90ff]
[    0.351311] pci 0000:01:00.0: reg 18: [mem 0xe5000000-0xe500ffff]
[    0.351344] pci 0000:01:00.0: reg 30: [mem 0x00000000-0x0001ffff pref]
[    0.351370] pci 0000:01:00.0: supports D1 D2
[    0.351391] pci 0000:01:00.1: [1002:5d44] type 0 class 0x000380
[    0.351408] pci 0000:01:00.1: reg 10: [mem 0xd8000000-0xdfffffff pref]
[    0.351419] pci 0000:01:00.1: reg 14: [mem 0xe5010000-0xe501ffff]
[    0.351475] pci 0000:01:00.1: supports D1 D2
[    0.351527] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[    0.351574] pci 0000:00:01.0:   bridge window [io  0x9000-0x9fff]
[    0.351580] pci 0000:00:01.0:   bridge window [mem 0xe4000000-0xe5ffffff]
[    0.351586] pci 0000:00:01.0:   bridge window [mem 0xd0000000-0xdfffffff pref]
[    0.351597] pci_bus 0000:00: on NUMA node 0
[    0.351602] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[    0.366515] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 10 11 *12 14 15)
[    0.367026] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 9 10 *11 12 14 15)
[    0.367531] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 *5 6 7 9 10 11 12 14 15)
[    0.368038] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 9 *10 11 12 14 15)
[    0.368543] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 9 *10 11 12 14 15)
[    0.369050] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 9 10 *11 12 14 15)
[    0.369560] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 *6 7 9 10 11 12 14 15)
[    0.370080] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 *9 10 11 12 14 15)
[    0.370666] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[    0.370721] vgaarb: loaded
[    0.370976] SCSI subsystem initialized
[    0.371033] libata version 3.00 loaded.
[    0.371033] usbcore: registered new interface driver usbfs
[    0.371033] usbcore: registered new interface driver hub
[    0.371033] usbcore: registered new device driver usb
[    0.371033] wmi: Mapper loaded
[    0.371033] PCI: Using ACPI for IRQ routing
[    0.371033] PCI: pci_cache_line_size set to 64 bytes
[    0.371033] reserve RAM buffer: 000000000009f800 - 000000000009ffff
[    0.371033] reserve RAM buffer: 000000001fff0000 - 000000001fffffff
[    0.383961] AppArmor: AppArmor Filesystem Enabled
[    0.384073] pnp: PnP ACPI init
[    0.384145] ACPI: bus type pnp registered
[    0.384375] pnp 00:00: [bus 00-ff]
[    0.384379] pnp 00:00: [io  0x0cf8-0x0cff]
[    0.384383] pnp 00:00: [io  0x0000-0x047f window]
[    0.384387] pnp 00:00: [io  0x0480-0x048f]
[    0.384390] pnp 00:00: [io  0x0490-0x0cf7 window]
[    0.384393] pnp 00:00: [io  0x0d00-0x0fff window]
[    0.384396] pnp 00:00: [io  0x1000-0x107f]
[    0.384399] pnp 00:00: [io  0x1080-0x10ff]
[    0.384403] pnp 00:00: [io  0x1100-0xffff window]
[    0.384406] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[    0.384410] pnp 00:00: [mem 0x20000000-0xfebfffff window]
[    0.384505] pnp 00:00: Plug and Play ACPI device, IDs PNP0a03 (active)
[    0.384819] pnp 00:01: [io  0x0010-0x001f]
[    0.384823] pnp 00:01: [io  0x0022-0x003f]
[    0.384826] pnp 00:01: [io  0x0044-0x005f]
[    0.384835] pnp 00:01: [io  0x0062-0x0063]
[    0.384838] pnp 00:01: [io  0x0065-0x006f]
[    0.384841] pnp 00:01: [io  0x0074-0x007f]
[    0.384844] pnp 00:01: [io  0x0091-0x0093]
[    0.384847] pnp 00:01: [io  0x00a2-0x00bf]
[    0.384850] pnp 00:01: [io  0x00e0-0x00ef]
[    0.384853] pnp 00:01: [io  0x04d0-0x04d1]
[    0.384856] pnp 00:01: [io  0x0290-0x029f]
[    0.384859] pnp 00:01: [io  0x0800-0x0805]
[    0.384862] pnp 00:01: [io  0x0880-0x088f]
[    0.384959] system 00:01: [io  0x04d0-0x04d1] has been reserved
[    0.385005] system 00:01: [io  0x0290-0x029f] has been reserved
[    0.385050] system 00:01: [io  0x0800-0x0805] has been reserved
[    0.385095] system 00:01: [io  0x0880-0x088f] has been reserved
[    0.385141] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.385163] pnp 00:02: [dma 4]
[    0.385168] pnp 00:02: [io  0x0000-0x000f]
[    0.385172] pnp 00:02: [io  0x0080-0x0090]
[    0.385175] pnp 00:02: [io  0x0094-0x009f]
[    0.385177] pnp 00:02: [io  0x00c0-0x00df]
[    0.385230] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
[    0.385250] pnp 00:03: [io  0x0070-0x0073]
[    0.385276] pnp 00:03: [irq 8]
[    0.385338] pnp 00:03: Plug and Play ACPI device, IDs PNP0b00 (active)
[    0.385354] pnp 00:04: [io  0x0061]
[    0.385408] pnp 00:04: Plug and Play ACPI device, IDs PNP0800 (active)
[    0.385425] pnp 00:05: [io  0x00f0-0x00ff]
[    0.385432] pnp 00:05: [irq 13]
[    0.385488] pnp 00:05: Plug and Play ACPI device, IDs PNP0c04 (active)
[    0.385837] pnp 00:06: [io  0x03f8-0x03ff]
ves
« Reply #825 on: February 04, 2011, 05:20:58 pm »
dmesg 2 Part
[    0.385845] pnp 00:06: [irq 4]
[    0.385944] pnp 00:06: Plug and Play ACPI device, IDs PNP0501 (active)
[    0.386218] pnp 00:07: [io  0x02f8-0x02ff]
[    0.386227] pnp 00:07: [irq 3]
[    0.386323] pnp 00:07: Plug and Play ACPI device, IDs PNP0501 (active)
[    0.386781] pnp 00:08: [io  0x0378-0x037f]
[    0.386785] pnp 00:08: [io  0x0778-0x077b]
[    0.386792] pnp 00:08: [irq 7]
[    0.386795] pnp 00:08: [dma 3]
[    0.386899] pnp 00:08: Plug and Play ACPI device, IDs PNP0401 (active)
[    0.386963] pnp 00:09: [io  0x0060]
[    0.386967] pnp 00:09: [io  0x0064]
[    0.386973] pnp 00:09: [irq 1]
[    0.387030] pnp 00:09: Plug and Play ACPI device, IDs PNP0303 (active)
[    0.387257] pnp 00:0a: [mem 0x000cd000-0x000cffff]
[    0.387261] pnp 00:0a: [mem 0x000f0000-0x000f7fff]
[    0.387264] pnp 00:0a: [mem 0x000f8000-0x000fbfff]
[    0.387267] pnp 00:0a: [mem 0x000fc000-0x000fffff]
[    0.387271] pnp 00:0a: [mem 0x1fff0000-0x1fffffff]
[    0.387279] pnp 00:0a: [mem 0xffff0000-0xffffffff]
[    0.387283] pnp 00:0a: [mem 0x00000000-0x0009ffff]
[    0.387287] pnp 00:0a: [mem 0x00100000-0x1ffeffff]
[    0.387290] pnp 00:0a: [mem 0xffee0000-0xffefffff]
[    0.387293] pnp 00:0a: [mem 0xfffe0000-0xfffeffff]
[    0.387296] pnp 00:0a: [mem 0xfec00000-0xfec00fff]
[    0.387300] pnp 00:0a: [mem 0xfee00000-0xfeefffff]
[    0.387386] system 00:0a: [mem 0x000cd000-0x000cffff] has been reserved
[    0.387434] system 00:0a: [mem 0x000f0000-0x000f7fff] could not be reserved
[    0.387479] system 00:0a: [mem 0x000f8000-0x000fbfff] could not be reserved
[    0.387525] system 00:0a: [mem 0x000fc000-0x000fffff] could not be reserved
[    0.389523] system 00:0a: [mem 0x1fff0000-0x1fffffff] could not be reserved
[    0.389568] system 00:0a: [mem 0xffff0000-0xffffffff] has been reserved
[    0.389614] system 00:0a: [mem 0x00000000-0x0009ffff] could not be reserved
[    0.389659] system 00:0a: [mem 0x00100000-0x1ffeffff] could not be reserved
[    0.389705] system 00:0a: [mem 0xffee0000-0xffefffff] has been reserved
[    0.389750] system 00:0a: [mem 0xfffe0000-0xfffeffff] has been reserved
[    0.389795] system 00:0a: [mem 0xfec00000-0xfec00fff] could not be reserved
[    0.389841] system 00:0a: [mem 0xfee00000-0xfeefffff] has been reserved
[    0.389892] system 00:0a: Plug and Play ACPI device, IDs PNP0c01 (active)
[    0.389906] pnp: PnP ACPI: found 11 devices
[    0.389948] ACPI: ACPI bus type pnp unregistered
[    0.428011] Switching to clocksource acpi_pm
[    0.428112] pci 0000:00:04.0: BAR 6: assigned [mem 0x20000000-0x2001ffff pref]
[    0.428170] pci 0000:01:00.0: BAR 6: assigned [mem 0xe4000000-0xe401ffff pref]
[    0.428223] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[    0.428268] pci 0000:00:01.0:   bridge window [io  0x9000-0x9fff]
[    0.428316] pci 0000:00:01.0:   bridge window [mem 0xe4000000-0xe5ffffff]
[    0.428363] pci 0000:00:01.0:   bridge window [mem 0xd0000000-0xdfffffff pref]
[    0.428434] pci_bus 0000:00: resource 0 [io  0x0000-0xffff]
[    0.428438] pci_bus 0000:00: resource 1 [mem 0x00000000-0xffffffff]
[    0.428442] pci_bus 0000:01: resource 0 [io  0x9000-0x9fff]
[    0.428446] pci_bus 0000:01: resource 1 [mem 0xe4000000-0xe5ffffff]
[    0.428449] pci_bus 0000:01: resource 2 [mem 0xd0000000-0xdfffffff pref]
[    0.428512] NET: Registered protocol family 2
[    0.428644] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[    0.428991] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    0.429241] TCP bind hash table entries: 16384 (order: 5, 131072 bytes)
[    0.429494] TCP: Hash tables configured (established 16384 bind 16384)
[    0.429540] TCP reno registered
[    0.429581] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.429637] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.429772] NET: Registered protocol family 1
[    0.429921] pci 0000:01:00.0: Boot video device
[    0.429929] PCI: CLS 32 bytes, default 64
[    0.429929] Trying to unpack rootfs image as initramfs...
[    0.578920] Freeing initrd memory: 3716k freed
[    0.585680] Scanning for low memory corruption every 60 seconds
[    0.585948] audit: initializing netlink socket (disabled)
[    0.586026] type=2000 audit(1296860542.579:1): initialized
[    0.600878] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[    0.603762] VFS: Disk quotas dquot_6.5.2
[    0.603894] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.604720] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.605185] fuse init (API version 7.16)
[    0.605429] msgmni has been set to 997
[    0.605878] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[    0.605932] io scheduler noop registered
[    0.605973] io scheduler deadline registered
[    0.606036] io scheduler cfq registered (default)
[    0.606293] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[    0.606378] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[    0.606700] input: Power Button as /devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input0
[    0.606761] ACPI: Power Button [PWRB]
[    0.606900] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[    0.606954] ACPI: Power Button [PWRF]
[    0.607244] ACPI: acpi_idle registered with cpuidle
[    0.609060] ERST: Table is not found!
[    0.609202] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.629822] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[    0.710499] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[    0.750951] 00:06: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[    0.771633] 00:07: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[    0.771969] Linux agpgart interface v0.103
[    0.772060] [drm] Initialized drm 1.1.0 20060810
[    0.772136] [drm] radeon defaulting to kernel modesetting.
[    0.772179] [drm] radeon kernel modesetting enabled.
[    0.772297] radeon 0000:01:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[    0.774844] [drm] initializing kernel modesetting (RV280 0x1002:0x5964).
[    0.774957] [drm] register mmio base: 0xE5000000
[    0.774999] [drm] register mmio size: 65536
[    0.775377] [drm:radeon_agp_init] *ERROR* Unable to acquire AGP: -19
[    0.775422] [drm] Forcing AGP to PCI mode
[    0.775465] [drm] Generation 2 PCI interface, using max accessible memory
[    0.775514] radeon 0000:01:00.0: VRAM: 128M 0x00000000D0000000 - 0x00000000D7FFFFFF (128M used)
[    0.775569] radeon 0000:01:00.0: GTT: 512M 0x00000000B0000000 - 0x00000000CFFFFFFF
[    0.775630] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[    0.775674] [drm] Driver supports precise vblank timestamp query.
[    0.775765] [drm] radeon: irq initialized.
[    0.778013] [drm] Detected VRAM RAM=128M, BAR=128M
[    0.778075] [drm] RAM width 64bits DDR
[    0.778248] [TTM] Zone  kernel: Available graphics memory: 255282 kiB.
[    0.778296] [TTM] Initializing pool allocator.
[    0.778371] [drm] radeon: 128M of VRAM memory ready
[    0.778416] [drm] radeon: 512M of GTT memory ready.
[    0.778498] [drm] GART: num cpu pages 131072, num gpu pages 131072
[    0.782167] radeon 0000:01:00.0: WB enabled
[    0.782295] [drm] Loading R200 Microcode
[    0.782576] [drm] radeon: ring at 0x00000000B0001000
[    0.782637] [drm] ring test succeeded in 1 usecs
[    0.782851] [drm] radeon: ib pool ready.
[    0.783008] [drm] ib test succeeded in 0 usecs
[    0.783445] [drm] Radeon Display Connectors
[    0.783488] [drm] Connector 0:
[    0.783528] [drm]   VGA
[    0.783568] [drm]   DDC: 0x60 0x60 0x60 0x60 0x60 0x60 0x60 0x60
[    0.783612] [drm]   Encoders:
[    0.783652] [drm]     CRT1: INTERNAL_DAC1
[    0.783693] [drm] Connector 1:
[    0.783732] [drm]   VGA
[    0.783772] [drm]   DDC: 0x6c 0x6c 0x6c 0x6c 0x6c 0x6c 0x6c 0x6c
[    0.783815] [drm]   Encoders:
[    0.783855] [drm]     CRT2: INTERNAL_DAC2
[    0.783896] [drm] Connector 2:
[    0.783935] [drm]   S-video
[    0.783975] [drm]   Encoders:
[    0.784014] [drm]     TV1: INTERNAL_DAC2
[    0.787930] [drm] forcing VGA-1 connector ON
[    0.802913] No connectors reported connected with modes
[    0.808684] [drm] fb mappable at 0xD0040000
[    0.808726] [drm] vram apper at 0xD0000000
[    0.808767] [drm] size 1228800
[    0.808807] [drm] fb depth is 24
[    0.808847] [drm]    pitch is 2560
[    0.872887] Console: switching to colour frame buffer device 80x30
[    0.880267] fb0: radeondrmfb frame buffer device
[    0.882451] drm: registered panic notifier
[    0.884644] [drm] Initialized radeon 2.8.0 20080528 for 0000:01:00.0 on minor 0
[    0.891396] brd: module loaded
[    0.894768] loop: module loaded
[    0.897251] i2c-core: driver [adp5520] using legacy suspend method
[    0.899733] i2c-core: driver [adp5520] using legacy resume method
[    0.902423] pata_sis 0000:00:02.5: version 0.5.2
[    0.902452] pata_sis 0000:00:02.5: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[    0.905815] scsi0 : pata_sis
[    0.908548] scsi1 : pata_sis
[    0.911930] ata1: PATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0xf000 irq 14
[    0.914611] ata2: PATA max UDMA/133 cmd 0x170 ctl 0x376 bmdma 0xf008 irq 15
[    0.917397] pata_acpi 0000:00:05.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[    0.923065] pata_acpi 0000:00:05.0: PCI INT A disabled
[    0.926575] Fixed MDIO Bus: probed
[    0.929572] PPP generic driver version 2.4.2
[    0.932585] tun: Universal TUN/TAP device driver, 1.6
[    0.935524] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    0.938700] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.941883] ehci_hcd 0000:00:03.3: PCI INT D -> GSI 23 (level, low) -> IRQ 23
[    0.945162] ehci_hcd 0000:00:03.3: EHCI Host Controller
[    0.948513] ehci_hcd 0000:00:03.3: new USB bus registered, assigned bus number 1
[    0.955098] ehci_hcd 0000:00:03.3: irq 23, io mem 0xe7002000
[    0.970043] ehci_hcd 0000:00:03.3: USB 2.0 started, EHCI 1.00
[    0.973515] hub 1-0:1.0: USB hub found
[    0.976682] hub 1-0:1.0: 8 ports detected
[    0.979954] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.983298] ohci_hcd 0000:00:03.0: PCI INT A -> GSI 20 (level, low) -> IRQ 20
[    0.986631] ohci_hcd 0000:00:03.0: OHCI Host Controller
[    0.990048] ohci_hcd 0000:00:03.0: new USB bus registered, assigned bus number 2
[    0.996572] ohci_hcd 0000:00:03.0: irq 20, io mem 0xe7004000
[    1.052232] hub 2-0:1.0: USB hub found
[    1.055582] hub 2-0:1.0: 3 ports detected
[    1.059046] ohci_hcd 0000:00:03.1: PCI INT B -> GSI 21 (level, low) -> IRQ 21
[    1.062525] ohci_hcd 0000:00:03.1: OHCI Host Controller
[    1.065905] ohci_hcd 0000:00:03.1: new USB bus registered, assigned bus number 3
[    1.072631] ohci_hcd 0000:00:03.1: irq 21, io mem 0xe7000000
[    1.090417] ata1.00: HPA detected: current 78163247, native 78165360
[    1.093916] ata1.00: ATA-5: ST340016A, 3.19, max UDMA/100
[    1.097381] ata1.00: 78163247 sectors, multi 16: LBA
[    1.100802] ata1.01: ATAPI: Compaq  DVD-ROM SD-616T, F304, max UDMA/44
[    1.104224] ata1.00: limited to UDMA/33 due to 40-wire cable
[    1.107641] ata1.01: limited to UDMA/33 due to 40-wire cable
[    1.132236] hub 3-0:1.0: USB hub found
[    1.135468] hub 3-0:1.0: 3 ports detected
[    1.138695] ohci_hcd 0000:00:03.2: PCI INT C -> GSI 22 (level, low) -> IRQ 22
[    1.142043] ohci_hcd 0000:00:03.2: OHCI Host Controller
[    1.145360] ohci_hcd 0000:00:03.2: new USB bus registered, assigned bus number 4
[    1.150871] ata1.00: configured for UDMA/33
[    1.155310] ohci_hcd 0000:00:03.2: irq 22, io mem 0xe7001000
[    1.170393] ata1.01: configured for UDMA/33
[    1.174086] scsi 0:0:0:0: Direct-Access     ATA      ST340016A        3.19 PQ: 0 ANSI: 5
[    1.180903] sd 0:0:0:0: [sda] 78163247 512-byte logical blocks: (40.0 GB/37.2 GiB)
[    1.181017] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    1.191531] scsi 0:0:1:0: CD-ROM            Compaq   DVD-ROM SD-616T  F304 PQ: 0 ANSI: 5
[    1.191772] sd 0:0:0:0: [sda] Write Protect is off
[    1.191785] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    1.191941] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    1.212218] hub 4-0:1.0: USB hub found
[    1.215644] hub 4-0:1.0: 2 ports detected
[    1.219219] uhci_hcd: USB Universal Host Controller Interface driver
[    1.222797] Initializing USB Mass Storage driver...
[    1.226302] usbcore: registered new interface driver usb-storage
[    1.229931] USB Mass Storage support registered.
[    1.233587] usbcore: registered new interface driver ums-alauda
[    1.237274] usbcore: registered new interface driver ums-datafab
[    1.240859] usbcore: registered new interface driver ums-freecom
[    1.244337] usbcore: registered new interface driver ums-isd200
[    1.247741] usbcore: registered new interface driver ums-jumpshot
[    1.251019] usbcore: registered new interface driver ums-sddr09
[    1.254205]  sda: sda1 sda2
[    1.254473] usbcore: registered new interface driver ums-sddr55
[    1.254625] usbcore: registered new interface driver ums-usbat
[    1.254927] i8042: PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
[    1.254946] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[    1.255383] serio: i8042 KBD port at 0x60,0x64 irq 1
[    1.256265] mousedev: PS/2 mouse device common for all mice
[    1.257120] rtc_cmos 00:03: RTC can wake from S4
[    1.257174] sr0: scsi3-mmc drive: 0x/40x cd/rw xa/form2 cdda tray
[    1.257216] cdrom: Uniform CD-ROM driver Revision: 3.20
[    1.258073] sr 0:0:1:0: Attached scsi CD-ROM sr0
[    1.258635] sr 0:0:1:0: Attached scsi generic sg1 type 5
[    1.280608] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input2
[    1.297911] sd 0:0:0:0: [sda] Attached SCSI disk
[    1.310115] rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0
[    1.313206] rtc0: alarms up to one year, 242 bytes nvram
[    1.316406] device-mapper: uevent: version 1.0.3
[    1.319529] device-mapper: ioctl: 4.19.1-ioctl (2011-01-07) initialised: dm-devel@redhat.com
[    1.325788] device-mapper: multipath: version 1.2.0 loaded
[    1.329071] device-mapper: multipath round-robin: version 1.0.0 loaded
[    1.332674] cpuidle: using governor ladder
[    1.336099] cpuidle: using governor menu
[    1.339920] TCP cubic registered
[    1.343288] NET: Registered protocol family 17
[    1.346648] Registering the dns_resolver key type
[    1.351031] Using IPI No-Shortcut mode
[    1.354544] PM: Hibernation image not present or could not be loaded.
[    1.354564] registered taskstats version 1
[    1.358114]   Magic number: 15:675:48
[    1.361484] rtc_cmos 00:03: setting system clock to 2011-02-04 23:02:23 UTC (1296860543)
[    1.368050] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[    1.371470] EDD information not available.
[    1.410159] Freeing unused kernel memory: 556k freed
[    1.414274] Write protecting the kernel text: 4300k
[    1.417672] Write protecting the kernel read-only data: 2312k
[    1.580143] Refined TSC clocksource calibration: 3000.852 MHz.
[    1.580153] Switching to clocksource tsc
[    3.852965] sata_sis 0000:00:05.0: version 1.0
[    3.853008] sata_sis 0000:00:05.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[    3.853020] sata_sis 0000:00:05.0: Detected SiS 180/181/964 chipset in SATA mode
[    3.855339] scsi2 : sata_sis
[    3.856075] scsi3 : sata_sis
[    3.856779] ata3: SATA max UDMA/133 cmd 0xac00 ctl 0xb000 bmdma 0xbc00 irq 17
[    3.856784] ata4: SATA max UDMA/133 cmd 0xb400 ctl 0xb800 bmdma 0xbc08 irq 17
[    4.210849] ata3: SATA link down (SStatus 0 SControl 300)
[    4.570840] ata4: SATA link down (SStatus 0 SControl 300)
[    5.471637] scsi: <fdomain> Detection failed (no card)
[    5.561429] GDT-HA: Storage RAID Controller Driver. Version: 3.05
[    5.843805] imm: Version 2.05 (for Linux 2.4.0)
[    6.238045] Fusion MPT base driver 3.04.17
[    6.238051] Copyright (c) 1999-2008 LSI Corporation
[    6.391885] Fusion MPT SPI Host driver 3.04.17
[    6.522415] Fusion MPT FC Host driver 3.04.17
[    6.634231] Fusion MPT SAS Host driver 3.04.17
[    6.705976] 3ware Storage Controller device driver for Linux v1.26.02.003.
[    6.779065] 3ware 9000 Storage Controller device driver for Linux v2.26.02.014.
[    6.851727] Compaq SMART2 Driver (v 2.6.0)
[    6.974222] HP CISS Driver (v 3.6.26)
[    7.200567] Adaptec aacraid driver 1.1-5[26400]-ms
[    7.369931] megaraid cmm: 2.20.2.7 (Release Date: Sun Jul 16 00:01:03 EST 2006)
[    7.374315] megaraid: 2.20.5.1 (Release Date: Thu Nov 16 15:32:35 EST 2006)
[    7.546688] megasas: 00.00.05.29-rc1 Tue. Dec. 7 17:00:00 PDT 2010
[    7.639504] QLogic Fibre Channel HBA Driver: 8.03.05-k0
[    7.738068] Emulex LightPulse Fibre Channel SCSI driver 8.3.20
[    7.738073] Copyright(c) 2004-2009 Emulex.  All rights reserved.
[    7.964979] aic94xx: Adaptec aic94xx SAS/SATA driver version 1.0.3 loaded
[    8.166341] usbcore: registered new interface driver usbhid
[    8.166349] usbhid: USB HID core driver
[    8.248291] sl811: driver sl811-hcd, 19 May 2005
[    8.653906] md: raid0 personality registered for level 0
[    8.738401] md: raid1 personality registered for level 1
[    9.030063] raid6: int32x1    629 MB/s
[    9.200025] raid6: int32x2    824 MB/s
[    9.370011] raid6: int32x4    753 MB/s
[    9.540077] raid6: int32x8    524 MB/s
[    9.710012] raid6: mmxx1     1827 MB/s
[    9.880034] raid6: mmxx2     2150 MB/s
[   10.050050] raid6: sse1x1    1111 MB/s
[   10.220026] raid6: sse1x2    1230 MB/s
[   10.390037] raid6: sse2x1    2223 MB/s
[   10.560034] raid6: sse2x2    1851 MB/s
[   10.560037] raid6: using algorithm sse2x1 (2223 MB/s)
[   10.598870] async_tx: api initialized (async)
[   10.617449] xor: automatically using best checksumming function: pIII_sse
[   10.660012]    pIII_sse  :  4486.800 MB/sec
[   10.660016] xor: using function: pIII_sse (4486.800 MB/sec)
[   10.724016] md: raid6 personality registered for level 6
[   10.724024] md: raid5 personality registered for level 5
[   10.724029] md: raid4 personality registered for level 4
[   10.821498] md: raid10 personality registered for level 10
[   11.021354] JFS: nTxBlock = 3993, nTxLock = 31945
[   11.196128] RPC: Registered udp transport module.
[   11.196135] RPC: Registered tcp transport module.
[   11.196141] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   11.232088] FS-Cache: Loaded
[   11.310969] FS-Cache: Netfs 'nfs' registered for caching
[   11.474903] SGI XFS with ACLs, security attributes, realtime, large block/inode numbers, no debug enabled
[   11.478002] SGI XFS Quota Management subsystem
[   11.581640] e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI
[   11.581648] e1000: Copyright (c) 1999-2006 Intel Corporation.
[   11.784932] Loading iSCSI transport class v2.0-870.
[   12.029268] iscsi: registered transport (tcp)
[   16.225678] EXT3-fs (sda1): error: couldn't mount because of unsupported optional features (240)
[   16.225952] EXT2-fs (sda1): error: couldn't mount because of unsupported optional features (240)
[   16.261509] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[   18.266629] udev: starting version 151
[   18.266772] udevd (10930): /proc/10930/oom_adj is deprecated, please use /proc/10930/oom_score_adj instead.
[   18.441262] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[   18.713187] agpgart-sis 0000:00:00.0: SiS chipset [1039/0661]
[   18.720641] agpgart-sis 0000:00:00.0: AGP aperture is 64M @ 0xe0000000
[   18.744437] parport_pc 00:08: reported by Plug and Play ACPI
[   18.744517] parport0: PC-style at 0x378 (0x778), irq 7, dma 3 [PCSPP,TRISTATE,COMPAT,ECP,DMA]
[   18.849800] input: PC Speaker as /devices/platform/pcspkr/input/input3
[   18.862627] sis900.c: v1.08.10 Apr. 2 2006
[   18.862764] sis900 0000:00:04.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
[   18.863832] 0000:00:04.0: ICS LAN PHY transceiver found at address 1.
[   18.874721] 0000:00:04.0: Using transceiver found at address 1 as default
[   18.876077] eth0: SiS 900 PCI Fast Ethernet at 0xa800, IRQ 19, 00:0f:ea:e3:89:ea
[   18.917304] ppdev: user-space parallel port driver
[   20.074740] EXT4-fs (sda1): re-mounted. Opts: (null)
[   20.785856] Adding 1967956k swap on /dev/sda2.  Priority:-1 extents:1 across:1967956k
ves
« Reply #826 on: February 04, 2011, 05:22:36 pm »
Glxinfo
name of display: :0
display: :0  screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.4
server glx extensions:
    GLX_ARB_multisample, GLX_EXT_import_context, GLX_EXT_texture_from_pixmap,
    GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_copy_sub_buffer,
    GLX_OML_swap_method, GLX_SGI_make_current_read, GLX_SGI_swap_control,
    GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
    GLX_SGIX_visual_select_group, GLX_INTEL_swap_event
client glx vendor string: Mesa Project and SGI
client glx version string: 1.4
client glx extensions:
    GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_import_context,
    GLX_MESA_swap_control, GLX_OML_swap_method, GLX_OML_sync_control,
    GLX_SGI_make_current_read, GLX_SGI_swap_control, GLX_SGI_video_sync,
    GLX_SGIX_visual_select_group, GLX_EXT_texture_from_pixmap,
GLX version: 1.4
GLX extensions:
OpenGL vendor string: Tungsten Graphics, Inc.
OpenGL renderer string: Mesa DRI R200 (RV280 5964) 20090101 x86/MMX/SSE2 TCL DRI2
OpenGL version string: 1.3 Mesa 7.9
OpenGL extensions:
    GL_ARB_draw_buffers, GL_ARB_imaging, GL_ARB_multisample,
    GL_ARB_multitexture, GL_ARB_occlusion_query, GL_ARB_point_parameters,
    GL_ARB_point_sprite, GL_ARB_texture_border_clamp,
    GL_ARB_texture_compression, GL_ARB_texture_cube_map,
    GL_ARB_texture_env_add, GL_ARB_texture_env_combine,
    GL_ARB_texture_env_crossbar, GL_ARB_texture_env_dot3,
    GL_ARB_texture_mirrored_repeat, GL_ARB_texture_rectangle,
    GL_ARB_transpose_matrix, GL_ARB_vertex_buffer_object,
    GL_ARB_vertex_program, GL_ARB_window_pos, GL_EXT_abgr, GL_EXT_bgra,
    GL_EXT_blend_color, GL_EXT_blend_equation_separate,
    GL_EXT_blend_func_separate, GL_EXT_blend_logic_op, GL_EXT_blend_minmax,
    GL_EXT_blend_subtract, GL_EXT_compiled_vertex_array, GL_EXT_convolution,
    GL_EXT_copy_texture, GL_EXT_draw_range_elements,
    GL_EXT_framebuffer_object, GL_EXT_fog_coord, GL_EXT_histogram,
    GL_EXT_multi_draw_arrays, GL_EXT_packed_depth_stencil,
    GL_EXT_packed_pixels, GL_EXT_point_parameters, GL_EXT_polygon_offset,
    GL_EXT_rescale_normal, GL_EXT_secondary_color,
    GL_EXT_separate_specular_color, GL_EXT_stencil_wrap, GL_EXT_subtexture,
    GL_EXT_texture, GL_EXT_texture3D, GL_EXT_texture_cube_map,
    GL_EXT_texture_edge_clamp, GL_EXT_texture_env_add,
    GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3,
    GL_EXT_texture_filter_anisotropic, GL_EXT_texture_lod_bias,
    GL_EXT_texture_mirror_clamp, GL_EXT_texture_object,
    GL_EXT_texture_rectangle, GL_EXT_vertex_array, GL_APPLE_packed_pixels,
    GL_ATI_blend_equation_separate, GL_ATI_texture_env_combine3,
    GL_ATI_texture_mirror_once, GL_ATI_fragment_shader,
    GL_IBM_multimode_draw_arrays, GL_IBM_rasterpos_clip,
    GL_IBM_texture_mirrored_repeat, GL_INGR_blend_func_separate,
    GL_MESA_pack_invert, GL_MESA_ycbcr_texture, GL_MESA_window_pos,
    GL_NV_blend_square, GL_NV_light_max_exponent, GL_NV_packed_depth_stencil,
    GL_NV_texgen_reflection, GL_NV_texture_rectangle, GL_OES_read_format,
    GL_SGI_color_matrix, GL_SGI_color_table, GL_SGIS_generate_mipmap,
    GL_SGIS_texture_border_clamp, GL_SGIS_texture_edge_clamp,
    GL_SGIS_texture_lod, GL_SUN_multi_draw_arrays
64 GLX Visuals
   visual  x  bf lv rg d st colorbuffer ax dp st accumbuffer  ms  cav
 id dep cl sp sz l  ci b ro  r  g  b  a bf th cl  r  g  b  a ns b eat
0x21 24 tc  0 32  0 r  y  .  8  8  8  8  0 24  8  0  0  0  0  0 0 None
0x22 24 dc  0 32  0 r  y  .  8  8  8  8  0 24  8  0  0  0  0  0 0 None
0xb9 24 tc  0 24  0 r  .  .  8  8  8  0  0  0  0  0  0  0  0  0 0 None
0xba 24 tc  0 24  0 r  .  .  8  8  8  0  0  0  0 16 16 16  0  0 0 Slow
0xbb 24 tc  0 24  0 r  y  .  8  8  8  0  0  0  0  0  0  0  0  0 0 None
0xbc 24 tc  0 24  0 r  y  .  8  8  8  0  0  0  0 16 16 16  0  0 0 Slow
0xbd 24 tc  0 24  0 r  .  .  8  8  8  0  0 16  0  0  0  0  0  0 0 None
0xbe 24 tc  0 24  0 r  .  .  8  8  8  0  0 16  0 16 16 16  0  0 0 Slow
0xbf 24 tc  0 24  0 r  y  .  8  8  8  0  0 16  0  0  0  0  0  0 0 None
0xc0 24 tc  0 24  0 r  y  .  8  8  8  0  0 16  0 16 16 16  0  0 0 Slow
0xc1 24 tc  0 24  0 r  .  .  8  8  8  0  0 24  0  0  0  0  0  0 0 None
0xc2 24 tc  0 24  0 r  .  .  8  8  8  0  0 24  0 16 16 16  0  0 0 Slow
0xc3 24 tc  0 24  0 r  y  .  8  8  8  0  0 24  0  0  0  0  0  0 0 None
0xc4 24 tc  0 24  0 r  y  .  8  8  8  0  0 24  0 16 16 16  0  0 0 Slow
0xc5 24 tc  0 24  0 r  .  .  8  8  8  0  0 24  8  0  0  0  0  0 0 None
0xc6 24 tc  0 24  0 r  .  .  8  8  8  0  0 24  8 16 16 16  0  0 0 Slow
0xc7 24 tc  0 24  0 r  y  .  8  8  8  0  0 24  8  0  0  0  0  0 0 None
0xc8 24 tc  0 24  0 r  y  .  8  8  8  0  0 24  8 16 16 16  0  0 0 Slow
0xc9 24 tc  0 32  0 r  .  .  8  8  8  8  0  0  0  0  0  0  0  0 0 None
0xca 24 tc  0 32  0 r  .  .  8  8  8  8  0  0  0 16 16 16 16  0 0 Slow
0xcb 24 tc  0 32  0 r  y  .  8  8  8  8  0  0  0  0  0  0  0  0 0 None
0xcc 24 tc  0 32  0 r  y  .  8  8  8  8  0  0  0 16 16 16 16  0 0 Slow
0xcd 24 tc  0 32  0 r  .  .  8  8  8  8  0 16  0  0  0  0  0  0 0 None
0xce 24 tc  0 32  0 r  .  .  8  8  8  8  0 16  0 16 16 16 16  0 0 Slow
0xcf 24 tc  0 32  0 r  y  .  8  8  8  8  0 16  0 16 16 16 16  0 0 Slow
0xd0 24 tc  0 32  0 r  .  .  8  8  8  8  0 24  0  0  0  0  0  0 0 None
0xd1 24 tc  0 32  0 r  .  .  8  8  8  8  0 24  0 16 16 16 16  0 0 Slow
0xd2 24 tc  0 32  0 r  y  .  8  8  8  8  0 24  0  0  0  0  0  0 0 None
0xd3 24 tc  0 32  0 r  y  .  8  8  8  8  0 24  0 16 16 16 16  0 0 Slow
0xd4 24 tc  0 32  0 r  .  .  8  8  8  8  0 24  8  0  0  0  0  0 0 None
0xd5 24 tc  0 32  0 r  .  .  8  8  8  8  0 24  8 16 16 16 16  0 0 Slow
0xd6 24 tc  0 32  0 r  y  .  8  8  8  8  0 24  8 16 16 16 16  0 0 Slow
0xd7 24 dc  0 24  0 r  .  .  8  8  8  0  0  0  0  0  0  0  0  0 0 None
0xd8 24 dc  0 24  0 r  .  .  8  8  8  0  0  0  0 16 16 16  0  0 0 Slow
0xd9 24 dc  0 24  0 r  y  .  8  8  8  0  0  0  0  0  0  0  0  0 0 None
0xda 24 dc  0 24  0 r  y  .  8  8  8  0  0  0  0 16 16 16  0  0 0 Slow
0xdb 24 dc  0 24  0 r  .  .  8  8  8  0  0 16  0  0  0  0  0  0 0 None
0xdc 24 dc  0 24  0 r  .  .  8  8  8  0  0 16  0 16 16 16  0  0 0 Slow
0xdd 24 dc  0 24  0 r  y  .  8  8  8  0  0 16  0  0  0  0  0  0 0 None
0xde 24 dc  0 24  0 r  y  .  8  8  8  0  0 16  0 16 16 16  0  0 0 Slow
0xdf 24 dc  0 24  0 r  .  .  8  8  8  0  0 24  0  0  0  0  0  0 0 None
0xe0 24 dc  0 24  0 r  .  .  8  8  8  0  0 24  0 16 16 16  0  0 0 Slow
0xe1 24 dc  0 24  0 r  y  .  8  8  8  0  0 24  0  0  0  0  0  0 0 None
0xe2 24 dc  0 24  0 r  y  .  8  8  8  0  0 24  0 16 16 16  0  0 0 Slow
0xe3 24 dc  0 24  0 r  .  .  8  8  8  0  0 24  8  0  0  0  0  0 0 None
0xe4 24 dc  0 24  0 r  .  .  8  8  8  0  0 24  8 16 16 16  0  0 0 Slow
0xe5 24 dc  0 24  0 r  y  .  8  8  8  0  0 24  8  0  0  0  0  0 0 None
0xe6 24 dc  0 24  0 r  y  .  8  8  8  0  0 24  8 16 16 16  0  0 0 Slow
0xe7 24 dc  0 32  0 r  .  .  8  8  8  8  0  0  0  0  0  0  0  0 0 None
0xe8 24 dc  0 32  0 r  .  .  8  8  8  8  0  0  0 16 16 16 16  0 0 Slow
0xe9 24 dc  0 32  0 r  y  .  8  8  8  8  0  0  0  0  0  0  0  0 0 None
0xea 24 dc  0 32  0 r  y  .  8  8  8  8  0  0  0 16 16 16 16  0 0 Slow
0xeb 24 dc  0 32  0 r  .  .  8  8  8  8  0 16  0  0  0  0  0  0 0 None
0xec 24 dc  0 32  0 r  .  .  8  8  8  8  0 16  0 16 16 16 16  0 0 Slow
0xed 24 dc  0 32  0 r  y  .  8  8  8  8  0 16  0  0  0  0  0  0 0 None
0xee 24 dc  0 32  0 r  y  .  8  8  8  8  0 16  0 16 16 16 16  0 0 Slow
0xef 24 dc  0 32  0 r  .  .  8  8  8  8  0 24  0  0  0  0  0  0 0 None
0xf0 24 dc  0 32  0 r  .  .  8  8  8  8  0 24  0 16 16 16 16  0 0 Slow
0xf1 24 dc  0 32  0 r  y  .  8  8  8  8  0 24  0  0  0  0  0  0 0 None
0xf2 24 dc  0 32  0 r  y  .  8  8  8  8  0 24  0 16 16 16 16  0 0 Slow
0xf3 24 dc  0 32  0 r  .  .  8  8  8  8  0 24  8  0  0  0  0  0 0 None
0xf4 24 dc  0 32  0 r  .  .  8  8  8  8  0 24  8 16 16 16 16  0 0 Slow
0xf5 24 dc  0 32  0 r  y  .  8  8  8  8  0 24  8 16 16 16 16  0 0 Slow
0x58 32 tc  0 32  0 r  y  .  8  8  8  8  0 16  0  0  0  0  0  0 0 None
96 GLXFBConfigs:
0x59  0 tc  0 16  0 r  .  .  5  6  5  0  0  0  0  0  0  0  0  0 0 None
0x5a  0 tc  0 16  0 r  .  .  5  6  5  0  0  0  0 16 16 16  0  0 0 Slow
0x5b  0 tc  0 16  0 r  y  .  5  6  5  0  0  0  0  0  0  0  0  0 0 None
0x5c  0 tc  0 16  0 r  y  .  5  6  5  0  0  0  0 16 16 16  0  0 0 Slow
0x5d  0 tc  0 16  0 r  .  .  5  6  5  0  0 16  0  0  0  0  0  0 0 None
0x5e  0 tc  0 16  0 r  .  .  5  6  5  0  0 16  0 16 16 16  0  0 0 Slow
0x5f  0 tc  0 16  0 r  y  .  5  6  5  0  0 16  0  0  0  0  0  0 0 None
0x60  0 tc  0 16  0 r  y  .  5  6  5  0  0 16  0 16 16 16  0  0 0 Slow
0x61  0 tc  0 16  0 r  .  .  5  6  5  0  0 24  0  0  0  0  0  0 0 None
0x62  0 tc  0 16  0 r  .  .  5  6  5  0  0 24  0 16 16 16  0  0 0 Slow
0x63  0 tc  0 16  0 r  y  .  5  6  5  0  0 24  0  0  0  0  0  0 0 None
0x64  0 tc  0 16  0 r  y  .  5  6  5  0  0 24  0 16 16 16  0  0 0 Slow
0x65  0 tc  0 16  0 r  .  .  5  6  5  0  0 24  8  0  0  0  0  0 0 None
0x66  0 tc  0 16  0 r  .  .  5  6  5  0  0 24  8 16 16 16  0  0 0 Slow
0x67  0 tc  0 16  0 r  y  .  5  6  5  0  0 24  8  0  0  0  0  0 0 None
0x68  0 tc  0 16  0 r  y  .  5  6  5  0  0 24  8 16 16 16  0  0 0 Slow
0x69  0 tc  0 24  0 r  .  .  8  8  8  0  0  0  0  0  0  0  0  0 0 None
0x6a  0 tc  0 24  0 r  .  .  8  8  8  0  0  0  0 16 16 16  0  0 0 Slow
0x6b  0 tc  0 24  0 r  y  .  8  8  8  0  0  0  0  0  0  0  0  0 0 None
0x6c  0 tc  0 24  0 r  y  .  8  8  8  0  0  0  0 16 16 16  0  0 0 Slow
0x6d  0 tc  0 24  0 r  .  .  8  8  8  0  0 16  0  0  0  0  0  0 0 None
0x6e  0 tc  0 24  0 r  .  .  8  8  8  0  0 16  0 16 16 16  0  0 0 Slow
0x6f  0 tc  0 24  0 r  y  .  8  8  8  0  0 16  0  0  0  0  0  0 0 None
0x70  0 tc  0 24  0 r  y  .  8  8  8  0  0 16  0 16 16 16  0  0 0 Slow
0x71  0 tc  0 24  0 r  .  .  8  8  8  0  0 24  0  0  0  0  0  0 0 None
0x72  0 tc  0 24  0 r  .  .  8  8  8  0  0 24  0 16 16 16  0  0 0 Slow
0x73  0 tc  0 24  0 r  y  .  8  8  8  0  0 24  0  0  0  0  0  0 0 None
0x74  0 tc  0 24  0 r  y  .  8  8  8  0  0 24  0 16 16 16  0  0 0 Slow
0x75  0 tc  0 24  0 r  .  .  8  8  8  0  0 24  8  0  0  0  0  0 0 None
0x76  0 tc  0 24  0 r  .  .  8  8  8  0  0 24  8 16 16 16  0  0 0 Slow
0x77  0 tc  0 24  0 r  y  .  8  8  8  0  0 24  8  0  0  0  0  0 0 None
0x78  0 tc  0 24  0 r  y  .  8  8  8  0  0 24  8 16 16 16  0  0 0 Slow
0x79  0 tc  0 32  0 r  .  .  8  8  8  8  0  0  0  0  0  0  0  0 0 None
0x7a  0 tc  0 32  0 r  .  .  8  8  8  8  0  0  0 16 16 16 16  0 0 Slow
0x7b  0 tc  0 32  0 r  y  .  8  8  8  8  0  0  0  0  0  0  0  0 0 None
0x7c  0 tc  0 32  0 r  y  .  8  8  8  8  0  0  0 16 16 16 16  0 0 Slow
0x7d  0 tc  0 32  0 r  .  .  8  8  8  8  0 16  0  0  0  0  0  0 0 None
0x7e  0 tc  0 32  0 r  .  .  8  8  8  8  0 16  0 16 16 16 16  0 0 Slow
0x7f  0 tc  0 32  0 r  y  .  8  8  8  8  0 16  0  0  0  0  0  0 0 None
0x80  0 tc  0 32  0 r  y  .  8  8  8  8  0 16  0 16 16 16 16  0 0 Slow
0x81  0 tc  0 32  0 r  .  .  8  8  8  8  0 24  0  0  0  0  0  0 0 None
0x82  0 tc  0 32  0 r  .  .  8  8  8  8  0 24  0 16 16 16 16  0 0 Slow
0x83  0 tc  0 32  0 r  y  .  8  8  8  8  0 24  0  0  0  0  0  0 0 None
0x84  0 tc  0 32  0 r  y  .  8  8  8  8  0 24  0 16 16 16 16  0 0 Slow
0x85  0 tc  0 32  0 r  .  .  8  8  8  8  0 24  8  0  0  0  0  0 0 None
0x86  0 tc  0 32  0 r  .  .  8  8  8  8  0 24  8 16 16 16 16  0 0 Slow
0x87  0 tc  0 32  0 r  y  .  8  8  8  8  0 24  8  0  0  0  0  0 0 None
0x88  0 tc  0 32  0 r  y  .  8  8  8  8  0 24  8 16 16 16 16  0 0 Slow
0x89  0 dc  0 16  0 r  .  .  5  6  5  0  0  0  0  0  0  0  0  0 0 None
0x8a  0 dc  0 16  0 r  .  .  5  6  5  0  0  0  0 16 16 16  0  0 0 Slow
0x8b  0 dc  0 16  0 r  y  .  5  6  5  0  0  0  0  0  0  0  0  0 0 None
0x8c  0 dc  0 16  0 r  y  .  5  6  5  0  0  0  0 16 16 16  0  0 0 Slow
0x8d  0 dc  0 16  0 r  .  .  5  6  5  0  0 16  0  0  0  0  0  0 0 None
0x8e  0 dc  0 16  0 r  .  .  5  6  5  0  0 16  0 16 16 16  0  0 0 Slow
0x8f  0 dc  0 16  0 r  y  .  5  6  5  0  0 16  0  0  0  0  0  0 0 None
0x90  0 dc  0 16  0 r  y  .  5  6  5  0  0 16  0 16 16 16  0  0 0 Slow
0x91  0 dc  0 16  0 r  .  .  5  6  5  0  0 24  0  0  0  0  0  0 0 None
0x92  0 dc  0 16  0 r  .  .  5  6  5  0  0 24  0 16 16 16  0  0 0 Slow
0x93  0 dc  0 16  0 r  y  .  5  6  5  0  0 24  0  0  0  0  0  0 0 None
0x94  0 dc  0 16  0 r  y  .  5  6  5  0  0 24  0 16 16 16  0  0 0 Slow
0x95  0 dc  0 16  0 r  .  .  5  6  5  0  0 24  8  0  0  0  0  0 0 None
0x96  0 dc  0 16  0 r  .  .  5  6  5  0  0 24  8 16 16 16  0  0 0 Slow
0x97  0 dc  0 16  0 r  y  .  5  6  5  0  0 24  8  0  0  0  0  0 0 None
0x98  0 dc  0 16  0 r  y  .  5  6  5  0  0 24  8 16 16 16  0  0 0 Slow
0x99  0 dc  0 24  0 r  .  .  8  8  8  0  0  0  0  0  0  0  0  0 0 None
0x9a  0 dc  0 24  0 r  .  .  8  8  8  0  0  0  0 16 16 16  0  0 0 Slow
0x9b  0 dc  0 24  0 r  y  .  8  8  8  0  0  0  0  0  0  0  0  0 0 None
0x9c  0 dc  0 24  0 r  y  .  8  8  8  0  0  0  0 16 16 16  0  0 0 Slow
0x9d  0 dc  0 24  0 r  .  .  8  8  8  0  0 16  0  0  0  0  0  0 0 None
0x9e  0 dc  0 24  0 r  .  .  8  8  8  0  0 16  0 16 16 16  0  0 0 Slow
0x9f  0 dc  0 24  0 r  y  .  8  8  8  0  0 16  0  0  0  0  0  0 0 None
0xa0  0 dc  0 24  0 r  y  .  8  8  8  0  0 16  0 16 16 16  0  0 0 Slow
0xa1  0 dc  0 24  0 r  .  .  8  8  8  0  0 24  0  0  0  0  0  0 0 None
0xa2  0 dc  0 24  0 r  .  .  8  8  8  0  0 24  0 16 16 16  0  0 0 Slow
0xa3  0 dc  0 24  0 r  y  .  8  8  8  0  0 24  0  0  0  0  0  0 0 None
0xa4  0 dc  0 24  0 r  y  .  8  8  8  0  0 24  0 16 16 16  0  0 0 Slow
0xa5  0 dc  0 24  0 r  .  .  8  8  8  0  0 24  8  0  0  0  0  0 0 None
0xa6  0 dc  0 24  0 r  .  .  8  8  8  0  0 24  8 16 16 16  0  0 0 Slow
0xa7  0 dc  0 24  0 r  y  .  8  8  8  0  0 24  8  0  0  0  0  0 0 None
0xa8  0 dc  0 24  0 r  y  .  8  8  8  0  0 24  8 16 16 16  0  0 0 Slow
0xa9  0 dc  0 32  0 r  .  .  8  8  8  8  0  0  0  0  0  0  0  0 0 None
0xaa  0 dc  0 32  0 r  .  .  8  8  8  8  0  0  0 16 16 16 16  0 0 Slow
0xab  0 dc  0 32  0 r  y  .  8  8  8  8  0  0  0  0  0  0  0  0 0 None
0xac  0 dc  0 32  0 r  y  .  8  8  8  8  0  0  0 16 16 16 16  0 0 Slow
0xad  0 dc  0 32  0 r  .  .  8  8  8  8  0 16  0  0  0  0  0  0 0 None
0xae  0 dc  0 32  0 r  .  .  8  8  8  8  0 16  0 16 16 16 16  0 0 Slow
0xaf  0 dc  0 32  0 r  y  .  8  8  8  8  0 16  0  0  0  0  0  0 0 None
0xb0  0 dc  0 32  0 r  y  .  8  8  8  8  0 16  0 16 16 16 16  0 0 Slow
0xb1  0 dc  0 32  0 r  .  .  8  8  8  8  0 24  0  0  0  0  0  0 0 None
0xb2  0 dc  0 32  0 r  .  .  8  8  8  8  0 24  0 16 16 16 16  0 0 Slow
0xb3  0 dc  0 32  0 r  y  .  8  8  8  8  0 24  0  0  0  0  0  0 0 None
0xb4  0 dc  0 32  0 r  y  .  8  8  8  8  0 24  0 16 16 16 16  0 0 Slow
0xb5  0 dc  0 32  0 r  .  .  8  8  8  8  0 24  8  0  0  0  0  0 0 None
0xb6  0 dc  0 32  0 r  .  .  8  8  8  8  0 24  8 16 16 16 16  0 0 Slow
0xb7  0 dc  0 32  0 r  y  .  8  8  8  8  0 24  8  0  0  0  0  0 0 None
0xb8  0 dc  0 32  0 r  y  .  8  8  8  8  0 24  8 16 16 16 16  0 0 Slow
bitbytebit
« Reply #827 on: February 04, 2011, 05:27:03 pm »
mame: radeon_cs_gem.c:181: cs_gem_write_reloc: Assertion `boi->space_accounted' failed.
The mame error that you see, it seems to have to do with mesa and opengl somehow.  When did that error start exactly, it's odd because there have not been any changes to opengl recently and the old kernel doesn't fix it either so that's not the issue then.  Isn't Calamity using the same card too, it seemed to work on his, so definitely strange.  All the logs look good, like things *should* work, but somehow it's hitting that issue and it's an old issue it seems...
https://bugs.launchpad.net/ubuntu/+source/mesa/+bug/656100
So doesn't seem like it should be happening anymore, or if it had it should have always been doing that.
Also the audio warnings are easy to get rid of with 'audiodriver dsp', it's choosing that after trying alsa basically but it is cleaner to add that to the mame.ini.  I probably will add that.
« Last Edit: February 04, 2011, 05:28:36 pm by bitbytebit »
ves
« Reply #828 on: February 04, 2011, 05:36:36 pm »
Hello bitbytebit tests with LiveCD32-Full-1.368-33e345e.iso
Grub still fails, you can make a solution a bit sloppy as to create initrd vmlinuz symlinks in /
I think you should warn for newbies to choose the home directory is to put it on a partition other than the installation because it can not be installed, as well as data.
Here I have my doubts if you choose a partition to install the live and another to take home, which creates data?
Do not think it is best to default data within the home? Sorry for insisting on this, but I think it would be as easy for any newbies.
For xterm loads. xinitrc? If you hide the mouse, remove gdm etc. .. is to make it look as possible to the system, no? to me it has worked well without putting advmenu xterm.
After installation, the boot does not directly load X, it waits console login.
What application do you use to autologin? mingetty ...?
I tried mame and mess, but I can not always run the libraries fail with Alsa, but alsa or oss configure the installation, always the same error of libraries alsa, and I can not run any game.
I do not think that imaging can be corrupt, and I set advmenu to sound a mp3 while you're on the list of games working well, so it can be a bad compilation, right?
Another thing that would be interesting is that the arcade user can use the shutdown command to turn off the machine from a key or key combination, I was wearing with 2 +5 key in msdos, but in linux I have not been able to do not function to run shutdown from regular user.
Thank you and Goodnight today.
I think it was from here, no update Xorg? then there is no solution for AVGA 9250? I can do?
  • Last login:Today at 04:22:12 pm
« Reply #829 on: February 04, 2011, 05:55:40 pm »
I'm testing the webmin thing right now and it is absolutely amazing how easy it's everything now. Still exploring it and finding out stuff. I've managed to put some roms thanks to the network folders now available as /home and /roms (shouldn't be any for snaps?) and finally been able to play 'normal' roms on this system, it's really awesome.
I'm having an issue however when trying to mount my ntfs partition, I'm doing it like this:
It actually gets mounted and I'm able to browse the file system with the file manager provided in webmin. So that drive is mounted as /calamity and I can see it also in lxde, but when I try to get into it it says "permission denied". Then I'm trying to use it to point its rom directory as /calamity/Roms/Mame, either in advmenu.rc and mame.ini, but AdvMenu complains something like "no Mame game found to match the filter selected" so it seems it can't use that folder for the same reason. Do you have any clue why this could happen?
bitbytebit
« Reply #830 on: February 04, 2011, 06:04:12 pm »
It sounds like a permissions issue, I am thinking possibly the unix permissions it's getting are disallowing you from reading it.  check the 'ls -altr' output, see what the permissions are, try to access it after doing 'sudo -s' with ls and see what it does then.  It can only do read only for ntfs, so can't change or hurt anything, might have to do some trick with root access I guess to be able to utilize them (or become root, and copy them over, at least to test).
« Reply #831 on: February 04, 2011, 06:17:39 pm »
Yes, I could get in there from the xterm by doing sudo -s and then cd /calamity, so it seems permision related. Problem is I can't invoke Switchres (doesn't find Mame) or AdvMenu from there...
bitbytebit
« Reply #832 on: February 04, 2011, 06:19:40 pm »
Hello AVGA I use is 9250, with the kernel version 2.6.38-rc2+ ,but with the new rc +3 no way it will work, the X function but loading mame not think that's why the error was radeon .....
penGL: PBO not supported
Aborted
The bash_profile not believe it has to be done manually.
You could put the old kernel to install it myself, and so that it works or not?
I am pretty sure I can fix this bug, I found that it seems the version of Mesa 7.9 we are using needs to be upgraded to 7.9.1 and that is where the fix is for your radeon card with the r200 chip in it.
I should have this fixed in the next ISO image, you can run this on an install and test this fix right now...
autounmask media-libs/mesa-7.9.1
emerge -av mesa
That should update your Mesa, and fix it hopefully.
Thanks,
Chris
bitbytebit
« Reply #833 on: February 04, 2011, 06:21:52 pm »
Right, you won't want to run mame or switchres as root like that, but check the 'ls -altr' output of the files/directories under there and let me see that part (send me a msg w/it attached).  We'll have to look into what people normally do with NTFS file systems, although I *think* the way would be by specifying a user as the files permissions at the mount command line.  That's what you have to do with windows shares and NFS shares sometimes.
Ahha, you probably just have to specify in that menu setup in webmin the user as arcade and group arcade, maybe even let users mount the drive too.
« Last Edit: February 04, 2011, 06:34:10 pm by bitbytebit »
« Reply #834 on: February 04, 2011, 06:33:04 pm »
Here it goes...
BTW previously in Windows I had changed the properties of the drive to share all of it.
« Last Edit: February 04, 2011, 06:35:42 pm by Calamity »
bitbytebit
« Reply #835 on: February 04, 2011, 06:35:27 pm »
Here it goes...
Yeah, I updated the last post, I think you'll just need to say it's owned by the arcade user in those options in the webmin setup for the drive, and maybe set it so users can mount it too.
bitbytebit
« Reply #836 on: February 04, 2011, 06:43:27 pm »
Hi, I have the solution for apgar the pc from the user advmenu arcade.
groupadd shutdown
add arcade to the group shutdown
check this created the user group and has arcade
shutdown:x:1002:arcade...
now with the command visudo, add the following lines
%shutdown ALL=(root) NOPASSWD: /sbin/reboot
%shutdown ALL=(root) NOPASSWD: /sbin/halt
%shutdown ALL=(root) NOPASSWD: /sbin/shutdown
And finally create the alias .bashrc
alias shutdown = ' sudo shutdown -h now'
alias shutdown = ' sudo halt '
alias halt = ' sudo halt'
alias halt = ' sudo shutdown -h now'
This all tested from the console, since I have done with a virtual machine, so I need to check that advmenu off the pc.
Thank
Actually just doing this..
alias poweroff='sudo halt'
At the top of /home/arcade/.bash_profile
Should allow advmenu to halt the machine and shutdown basically.  The arcade user already can run sudo without a password and advmame calls poweroff to shutdown the machine :).
Or actually just this in .xinitrc...
export PATH=/usr/local/bin:/usr/games/bin:$PATH
xhost +
xsetroot -cursor .emptycursor .emptycursor
advmenu
Test that and see if it works
Update: Actually you'll probably have to do this, it probably is the only way:
rm /sbin/poweroff
touch /sbin/poweroff
chmod 755 /sbin/poweroff
echo '#!/bin/bash' > /sbin/poweroff
echo "sudo halt" >> /sbin/poweroff
poweroff is normally a symlink to /sbin/halt, that is what advmenu calls.  The aliases won't work because advmenu calls the full path to poweroff as /sbin/poweroff and an alias can't have a path.
« Last Edit: February 04, 2011, 07:06:46 pm by bitbytebit »
« Reply #837 on: February 04, 2011, 06:47:53 pm »
That was it! It's working! I can access all my games and snaps from AdvMenu now.
ves
« Reply #838 on: February 04, 2011, 07:31:33 pm »
Hello, I do not feel the eyes and I'm a little crazy  :'(
It works well, and you can configure a key or key combination to turn off the machine.
rm /sbin/poweroff
And now the most important, I think some had taken me as a bit  :angry: :banghead: But I have to say I am ..........
emerge -av mesa
But now if you suck and everything is working properly
Thank you very much, now you can get a final version, to new updates.
So if I have 2 days I will not stop testing versions and versions  :banghead: :banghead:, and you made me no error case OpneGL  ;)
bitbytebit
« Reply #839 on: February 04, 2011, 07:38:17 pm »
rm /sbin/poweroff
emerge -av mesa
Sounds good, yeah I am building ISO's right now, looks like there's a lot of good fixes including mame 0141u1 fixed discrete audio too so mario and asteroids galaxian sounds work right again.  I guess they posted the fix a few hours after the release, so that is really cool since the mario issue was a bummer, now everything is working correctly with mario and even sounds nicer than in the past I think.
Also there's a fix for the console not interlacing for the 5450 radeon boards, or probably all the newer ones basically, I think it might do vblanking actually (need to test it more).  So we may just have support for newer Radeon cards now too in the 5xxx series.
Also that patch, I'm not sure, but it may fix that rs690 issue, will have to see with the next ISO and test it for me.  If not it's close, I haven't been able to test the patch with my 5450 yet but I get the feeling it's good there.  It at least could help Alex see how to fix the rs690, I'm guessing it's a similar issue in that part of the driver.
