Author Topic: (SOLVED) Need AC Adapter To Connect WG K7400 To MK1 Cabinet  (Read 12986 times)
MKFan4Life
  • Last login:July 24, 2023, 08:18:00 am
  • My arcade machines...
« on: October 04, 2010, 02:36:33 am »
I have just installed a Wells Gardner K7400 into my Mortal Kombat 1 cabinet and noticed the chassis has a different AC power connection than my old WG K7197.  The old connector is a female 3-conductor connection (coming from a source with an isolation transformer).  I know the K7400 doesn't require the isolation transformer but will run fine with it, so I'm leaving it in there.  Can someone point me to a listing with the exact adapter I can order to make this connection?  I don't want to hack it, though I know it would be easy to do so.  Here are pics of the two connectors I need to mate:
From MK1 Cabinet (circled connector):
On The K7400 Chassis:
Thanks for any help!
« Last Edit: October 22, 2010, 06:03:57 pm by MKFan4Life »
smartbomb2084
  • Last login:January 13, 2021, 03:14:53 pm
  • Having a SMART phone will make you DUMB.
Re: Need AC Adapter To Connect WG K7400 To MK1 Cabinet
« Reply #1 on: October 04, 2010, 08:14:22 am »
  I beleive that this is the animal you are looking for.  AMP part number  1-480700-00
  Of course you will need the correct crimping tool for the pins.
 http://www.newark.com/tyco-electronics-amp/1-480700-0/pin-socket-connector/dp/46F206
 It is also available from Happ Controls.   Happ part numbers:  43-0779-00 for the connector,  43-0778-00 for the male pins.
 Enjoy.
« Last Edit: October 04, 2010, 08:18:35 am by smartbomb2084 »
MKFan4Life
« Reply #2 on: October 04, 2010, 05:24:04 pm »
     I can't find it in the first link (first product looks almost same, but has perfectly round connections, & second one has the "D" shaped connections but has 4 conductors instead of 3).  I think you have the right one with the HAPP part #, but that looks like still just one of the ends I am looking for.  Does someone make a pre-made cable a few inches long just to interface between these 2 connections?  That is what I'd like to find.  (Though I know it's going to cost more than making one.)
     Thanks for your help just the same!
MonMotha
« Reply #3 on: October 04, 2010, 05:38:11 pm »
Yes, Happ sells a pre-made adapter to do this.  Wells-Gardner actually has a part number for it.  I can't seem to find it right now (grr).  Ask DiveMaster127 on here.  He's a Happ distributor, and he can get that stuff for you cheaper than ordering off the website (especially w/ shipping!).
  • Last login:Today at 01:40:05 pm
« Reply #4 on: October 04, 2010, 09:07:31 pm »
why not chop the old connector off the monitor and remove the socket off the new one and solder the wire onto the board?!
the wiring scheme is the same as the plug (ac) (gnd) (ac)
MKFan4Life
« Reply #5 on: October 04, 2010, 09:26:40 pm »
Sent him a personal message MonMotha.  Thanks!
MKFan4Life
« Reply #6 on: October 04, 2010, 09:34:17 pm »
So ya mean chop the pigtail in my first pic from my old K7197 and solder it onto my K7400 chassis in place of the connector in the second pic?  Yeah that would work, but the K7197 chassis is still in great shape, and I didn't really want to butcher it.  But that is something to think about.  I could at least temporarily do that.  I could just desolder the pigtail from the K7197 and the connector from the K7400 and resolder them later if I finally get the adapter I need.  Thanks for the idea.  I would have to remove the chassis from each mounting plate to desolder/solder those points properly though.
« Last Edit: October 04, 2010, 09:36:07 pm by MKFan4Life »
MKFan4Life
« Reply #7 on: October 06, 2010, 07:34:14 pm »
Don't guess anyone ever found an EXACT adpater to do this did they?  I found a part number on the HAPP site and sent it to DiveMaster127 (haven't heard back from him yet), but wasn't positive it's what I need 'cause they have NO PICS of the parts, lol!  Said "3-pin power connector for Wells Gardner monitors".  Not sure what the other end looks like, so would hate to order one from there (about $14).  Any help still greatly appreciated.
BTW, I did go ahead and simply strip a standard pc/monitor power cord end and make a temporary connection to test the monitor with, but I still want to get a permanent connector.
Ken Layton
  • Guru
  • Technician
« Reply #8 on: October 06, 2010, 10:43:45 pm »
Wells-Gardner part # 038A8059-000 power cord adapter.
« Reply #9 on: October 06, 2010, 11:08:50 pm »
that looks like a two pronger for the u2000... he needs the 3 prong with the ground in the middle
the WG side is right, but the other isnt
MKFan4Life
« Reply #10 on: October 06, 2010, 11:13:39 pm »
Yep, that's unfortunately true.  I figured this was something used enough that a lot of people would tell me right off hand what I needed.  At least since MK1 and Wells Gardner are both so popular.  Keep coming across the correct end for the monitor side, but can't find the right end for the cab's connector.
Thanks just the same.
smartbomb2084
« Reply #11 on: October 07, 2010, 09:10:29 am »
The more I look at this the more I think this could be a MIDWAY/ATARI cabinet part.
I have one of these adaptors in my adaptor cord collection on my bench that I gaffled from a converted MIDWAY cabinet, K2 I think, that had a different monitor in it than the original.
I wish I had a part number for you, sorry.
MKFan4Life
« Reply #12 on: October 07, 2010, 06:35:52 pm »
Well, the cabinet is definitely a Midway cabinet, being MK1.  The original monitor was a WG K7197.  It appeared to be the real original monitor, because the serial numbers on the frame matched the others on stickers in the cabinet and on the circuit boards, but I guess someone could have swapped in a different chassis and kept same tube and frame or etc.  This same type of connection (like in the first pic in my original post) is used right before the marquee light AND right before AC power goes into the power supply.  These are all in a bundle for the AC power in the cabinet coming from the isolation transformer.  If these pics are not good enough, I can take a few more.  These were just on hand from some pics I took while installing the monitor.
Kevin Mullins
    • Me on Myspace
« Reply #13 on: October 07, 2010, 10:36:06 pm »
That two pin end is what is "normally" on a K7000. (i.e a K7197)
The three pin setup like he has is a Midway thing. (two purple wires, one green, etc)
« Reply #14 on: October 08, 2010, 12:42:40 pm »
"prongers" "thingies" "dohickeys" i love our adopted techno babble  :lol
Kevin Mullins
    • Me on Myspace
« Reply #15 on: October 09, 2010, 11:20:26 am »
And we understand eachother.... that's the scary part.  ;D
smartbomb2084
« Reply #16 on: October 09, 2010, 07:16:53 pm »
I have been checking this thing out and I think that there is some kind of part number/picture ID error here. If you look at this MOUSER catalog page you can see that connector configuration 'B' shows flat polarizing sides on a TWO PIN connector. Surely there has to be polarizing flats on a THREE PIN connector.
I am going to place an order from MOUSER on Monday or Tuesday anyway.  I will order some of these AMP connectors and pins and I will make one of these adaptors for you FREE OF CHARGE if these parts are correct.
Just sit back and watch this thread for further updates.
http://www.mouser.com/catalog/catalogUSD/642/1452.pdf
MKFan4Life
« Reply #17 on: October 09, 2010, 07:45:53 pm »
I am not completely sure what you mean.  Are you talking about on my monitor chassis AC connector, or a part someone else in these replies spoke of?  On my chassis, it has the flat areas on the AC lines (neutral and hot) with the center (ground) round.  My pic is not as detailed as it could be.  Basically, the chassis connector looks exactly like "E" in that PDF file if it were the pcb-mount type connector.  And thanks for the offer to do one for free.
smartbomb2084
« Reply #18 on: October 09, 2010, 08:11:11 pm »
We are buying a MALE connector for the cabinet wire harness end which connects to the FEMALE end on the monitor board.  The three pin MOLEX connector is pretty much irrelevent beacause it is so common.  I am swimming in them.
The FLAT POLARIZING aspect is in the AMP MATE-N-LOK connector and is part of the design but it is not accurately shown in the pictures.
MKFan4Life
« Reply #19 on: October 09, 2010, 08:57:59 pm »
Ok.  I understand you completely now.  Sorry for the confusion.  I have never ordered these individual connectors to build an adapter from Mouser.  Sounds like the way to go since they look pretty cheap to buy.  Thanks again for the help!
smartbomb2084
« Reply #20 on: October 11, 2010, 08:41:31 am »
Sent out my order today. It takes about 4 or 5 days by the UPS Ground Burro Service to get to me.
Watch this thread for further updates.
MKFan4Life
« Reply #21 on: October 11, 2010, 05:05:41 pm »
Thanks.  I REALLY appreciate your kindness!
smartbomb2084
« Reply #22 on: October 11, 2010, 05:11:26 pm »
You're welcome.
smartbomb2084
« Reply #23 on: October 15, 2010, 08:19:07 pm »
Adaptor is done. Kid tested and mother approved.  I tried to get a picture for you but I can't seem to get a clear one. Anyway, I am sure it is what you need.
Send me an address where you want it to go in a personal message through the forum and I'll ship it out USPS on Monday.
Just in case the lawyers are watching... Please use at your own risk.
MKFan4Life
« Reply #24 on: October 15, 2010, 11:17:45 pm »
THANKS!  You're so nice to have made this for me man!  Sending the PM now.
smartbomb2084
« Reply #25 on: October 18, 2010, 07:51:02 pm »
The check, I mean the adapter, is in the mail.
The above part numbers are correct in spite of what the drawings show.
They are:
1-480700-0     AMP Universal MATE-N-LOK plug housing  (1 required)
350547-1        AMP Universal MATE-N-LOK male pin   (3 required)
03-09-2032     MOLEX .093 Free Hanging Plug   (1 required)
02-09-2103     MOLEX .093  male pin  (3 required)
63811-1000     MOLEX Universal Hand Crimper   Note: This MOLEX crimper was also used on the AMP pins even
        though it is not the crimper designed for them. The correct
        AMP crimper costs $127.34!!!
These are all manufacturer part numbers.
When you get the adapter please post a picture of it as all my attempts to do so have failed miserably.
Thanks and enjoy
MKFan4Life
« Reply #26 on: October 18, 2010, 08:14:48 pm »
Uh... you didn't buy the $49 crimper especially to make this did you?  Lol!
Well, although the individual parts only cost about $1.27, you've saved me the hassle of finding them myself, and likely screwing up 2-3 attempts of making a good one, plus, you paid to ship it to me.  I can drop a few bucks in your PayPal account if you'll send me a PM with your addy in it.
Can't wait to get it.  Have some friends coming over for a LAN party Saturday, and we always play the arcade games, too.  Thanks!!!  ;D
Kevin Mullins
    • Me on Myspace
« Reply #27 on: October 18, 2010, 09:39:04 pm »
The bill and the adapter are in the mail.
Thanks and enjoy
Seriously, let us know how it turns out.  :cheers:
MKFan4Life
« Reply #28 on: October 18, 2010, 10:44:12 pm »
Sure thing.  Pics to come, definitely.   ;)
MKFan4Life
« Reply #29 on: October 20, 2010, 08:19:21 pm »
Got the adapter in the mail today.
Pics as promised:
Old Temporary Connection
Smartbomb2084's Adapter
A Closer Look
Chassis Connection
Molex AC Connection In The Cabinet
Looks Much Better
And It Works, Too
Thanks for an AWESOME job on this for me smartbomb2084!  Drop me your PayPal addy so I can show some appreciation dude!   :applaud:
Kevin Mullins
    • Me on Myspace
« Reply #30 on: October 20, 2010, 08:51:18 pm »
Cool!
Kudos to smartbomb2084 for stepping up and squaring ya away like that.  :cheers:
« Reply #31 on: October 20, 2010, 10:30:14 pm »
aaaaaak! that better not be just STUCK in that connector!!
MKFan4Life
« Reply #32 on: October 20, 2010, 11:42:29 pm »
Well, it WAS... but what you can't see in the pic is the cable going up another inch or so to a stress relief wire-tie attached to the chassis frame.  I would have had to pretty much grab it and pull upwards to dislodge it the way it was, but again, this was temporary and the game wasn't turned on many times with this connection plugged into the wall, lol!
« Reply #33 on: October 21, 2010, 12:35:04 pm »
 :whap
*faints*
smartbomb2084
« Reply #34 on: October 21, 2010, 07:31:13 pm »
Glad it all worked out.  Thanks for the kind words.
MKFan4Life
MKFan4Life
« Reply #36 on: October 21, 2010, 07:41:43 pm »
You deserve them.  Now for the list of all the other cool things you can build for me... #1...  :lol
