Author Topic: Vsync on = sound stuttering, Vsync off = tearing  (Read 4251 times)
RVZ
  • Last login:November 07, 2025, 03:28:50 pm
    • Metal Slug!
« on: September 08, 2010, 02:22:40 am »
I'm using the latest version of mame, and using HyperSpinFE as the frontend.  The graphics card is a Geforce 6600LE, connected to a tv through s-video.  When I turn vsync on I get sound stuttering / echoing.  When I turn it off, the sound is perfect, but then I get tearing.  Anything I can try to fix both?
isucamper
  • Last login:November 25, 2019, 05:13:08 pm
  • I'm a slasher... of prices!!
    • my project arcade blog
Re: Vsync on = sound stuttering, Vsync off = tearing
« Reply #1 on: September 08, 2010, 08:26:05 am »
Only way to get rid of the tearing is to turn vsync on.
You get stuttering with vsync on if the refresh rate for the resolution of your monitor does not match the native refresh rate of the game.  For instance, if your monitor is running at 60Hz, but the native refresh rate is 60.05 or something weird (a lot of old arcade games are weird like that) then the game only runs at 99% speed and the sound stutters.
There are 2 solutions for this that I know of.  If you're fortunate enough to be using a multisync arcade monitor, use Soft15Khz or an ArcadeVGA video card to output the game's native resolution and refresh rate.  This is the best solution.
Alternatively, you can use SailorSat's cabMame (do a google search on cabMame) to run your games.  This version of MAME has a hack in it so the game will slow down just a fraction (imperceptibly) rather than stuttering if your refresh rates don't match.
THE SYSTEM          Popeye
ragnar
  • Last login:August 16, 2022, 10:40:56 am
« Reply #2 on: September 08, 2010, 09:59:29 am »
Wow, I learned something new today.  Thanks isucamper !!!!
« Last Edit: September 08, 2010, 11:00:33 am by ragnar »
MY FIRST BUILD:
RVZ
    • Metal Slug!
« Reply #3 on: September 08, 2010, 10:06:48 am »
Cool, will give this a try, thanks for the advice.  I've been searching for this all day and lot's of people have this same problem.  First solution I've seen so far.  Will cabMame work with HyperspinFE?
RVZ
    • Metal Slug!
« Reply #4 on: September 08, 2010, 02:40:34 pm »
Ok, I downloaded cabmame, but it runs the games in a small window.  Can't seem to find where to make it fullscreen?
isucamper
« Reply #5 on: September 08, 2010, 03:56:06 pm »
Are you running the command line or windows version?  There should be a fullscreen option you can enable.  I'm not having this issue with the cabmame version i'm using but I don't remember the options off the top of my head.
THE SYSTEM          Popeye
RVZ
    • Metal Slug!
« Reply #6 on: September 08, 2010, 04:31:48 pm »
It is running in fullscreen mode, but the image doesn't take up the whole screen, just a small part in the middle.
jtslade
  • Last login:February 13, 2025, 10:06:51 pm
  • Keep it looking originallish!
« Reply #7 on: September 08, 2010, 05:33:23 pm »
Is your triple buffeting on? Check your mame.ini
I have not been able to get frame tearing to stop but my setup is a dual format pal & NTSC tv using svideo Since pal-b is it's best looking format I run that. I was able to Get it to stop by using triple buffeting in NTSC but the video quality was awful so I decided that the frame tearing
« Last Edit: September 08, 2010, 05:36:37 pm by jtslade »
Ms. Pacman Original Cocktail with Non destructive mod to Groovy Arcade Linux with All 4way Vertical Cocktail capable 2 button or less games.
Neo Geo MVS Mame Cab Running Hyperspin, 25" Nanao Arcade Monitor, Mini-pac, ATI Radeon HD 4850 (ATOM-15), IL 8 Way Euro-Sticks from Paradise Arcade, Win XP 64bit, and tons of other junk.
RVZ
    • Metal Slug!
« Reply #8 on: September 08, 2010, 05:39:11 pm »
Played around with the settings in mame.ini and got the screen size sorted, but it feels like the games are running slower than what they're supposed to?  Unless the EmuMovies are playing faster?
I see the numprocessors is set to auto, should I change that?  I'm using a dual core cpu.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #9 on: September 09, 2010, 12:55:06 pm »
The best way to diagnose these problems is to turn off all "effects" and extra video processing, set Vsync on, se if the problem is gone. If so, then you turn on the extras you absolutely need, until the problem comes back. Then you know the limitations of the system.
Another angle to try is reducing sound quality to 22.5
If your machine is Windows based, some options you might turn off will make things worse. In general you want DirectDraw on, and depending on your hardware Direct3D might help or it might hinder.
NO MORE!!
