Author Topic: How to poewr the light bulb on my Happ Track Ball?  (Read 3571 times)
shateredsoul
  • Last login:January 25, 2013, 08:23:51 pm
« on: September 02, 2010, 08:25:59 pm »
Sooo my trackball has a lightbulb underneath, how do I light it?  Is there any best way? Is there a way to light it via usb?
bkenobi
Re: How to poewr the light bulb on my Happ Track Ball?
« Reply #1 on: September 02, 2010, 08:40:26 pm »
I'd plug it in.
shateredsoul
« Reply #2 on: September 02, 2010, 08:49:28 pm »
with what?.... there's no plug
bkenobi
« Reply #3 on: September 02, 2010, 11:18:18 pm »
I'd use power.   :cheers:
EvilNuff
« Reply #4 on: September 02, 2010, 11:41:34 pm »
I believe 12v dc and ground should work for the two connectors.
« Reply #5 on: September 03, 2010, 12:11:43 am »
If you want to go usb, I picked up a couple of these USB snake lights for dirt cheap and used them.
They're very bright and pretty much the easiest thing you can do to light a trackball.
Although, hooking up 12v isn't terribly difficult either.
shateredsoul
« Reply #6 on: September 03, 2010, 02:32:42 am »
the light bulb isalready attached under the trackball, it's not connected to a power source as far as I can tell
surface tension
  • Last login:July 01, 2018, 08:45:48 am
  • feel the tension...
    • surface tension tables
« Reply #7 on: September 03, 2010, 02:46:28 am »
I'm not aware of any official Happ illuminated trackballs, so where did the illumination kit come from... or is it really just a bulb poking through the hole? Did it not come with instructions?
By far the cheapest and easiest way to illuminate Happ trackballs is an LED and a resistor, connected to the 5V on the control board.
Smeghead
  • Better Smeg than dead
    • MY MAME BUILDS
« Reply #8 on: September 03, 2010, 09:31:14 am »
12v AC Adapater, 5v USB power isnt good enough to shine through a ball, I tried it
My MAME Build:
bkenobi
« Reply #9 on: September 03, 2010, 11:18:48 am »
See, there's the problem.  You will need to connect the light to power to get anything visible out.
Hoopz
  • Last login:November 16, 2025, 09:21:03 am
  • Intellivision Rocks!
« Reply #10 on: September 03, 2010, 11:48:45 am »
:laugh2:
FrizzleFried
    • Idaho Garagecade
« Reply #11 on: September 03, 2010, 12:02:40 pm »
These guys are just foolin' with ya...
Run a wire from one of the "hard drive" molex connectors from your power supply to the lamp... you want yellow and black I do believe (12v).
shateredsoul
« Reply #12 on: September 03, 2010, 03:34:30 pm »
Thanks! I guess I was just looking for a way to avoid opening up my pc.
 :angry: @ the rest of you!
give a guy a break! Don't have to bust my balls, eesh! ha ha ha ok  :P
atomikbohm
  • Last login:January 22, 2018, 11:33:35 am
« Reply #13 on: September 03, 2010, 05:21:59 pm »
How much power does that take?  ???
Just kidding, it's all in fun, sorry   :angel:
bkenobi
« Reply #14 on: September 03, 2010, 11:35:34 pm »
 :laugh2:
