Author Topic: Possible defective I-pac?  (Read 2148 times)
wescotte
  • Last login:September 15, 2004, 01:16:15 am
  • I'm a llama! I didn't want to change it
« on: August 07, 2003, 01:40:28 am »
I just got around to wiring my Ipac 4. The jumper is set to MAME/PS2. However quite a few buttons appear to have no been correctly assigned to the default settings and some have no assignment whatsoever. Has anyone else run into this? Is there a walk around to force reprogram the default mame settings? Or am I out of luck and most likely going to have to send it back for a new unit?
Eric
2slk
  • Last login:February 27, 2004, 11:38:09 pm
  • Fascinating, Captain.
Re:Possible defective I-pac?
« Reply #1 on: August 07, 2003, 01:43:24 am »
Try emailing Andy. Excellent customer service.
wescotte
« Reply #2 on: August 07, 2003, 02:29:14 am »
I did just before I posted here.. Figure can't hurt to ask more people :)
Eric
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #3 on: August 07, 2003, 02:47:44 am »
Yeah, I had one where player 2 button 5 didn't work.  It happens,  but his customer support rules.
wescotte
« Reply #4 on: August 07, 2003, 03:28:14 am »
What did he end up doing for you? just swap it with a new one?
Mike
  • Last login:September 22, 2005, 01:22:14 pm
  • Umm, yea about the TPS report
« Reply #5 on: August 07, 2003, 03:34:41 pm »
Check your wiring. Especially if you have coin switches and make sure they are wired correctly. Run the test with the multimeter that andy mentions on his site it is quick and you will likely find the problem. http://www.ultimarc.com/ipac2.html
wescotte
« Reply #6 on: August 07, 2003, 07:35:59 pm »
OK, here's what I found. The MAME jumper set. buttons 5 and up on players 3 and 4 do not function. The WinIPAC program also doesn't register they're being pressed. When that happened I assumed it was the ipac or a wiring issue. I set the config to ALT and reprogramed it with the default mame settings + players 3/4 buttons 5-8 configed. Which appeared to fix the problem. However I also noted in the WinIPAC program if you do not have the same config loaded or something with those buttons defined it still does not register a button push even in debug mode. They buttons still function but the program doesn't appear to notice they do.
Eric
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #7 on: August 07, 2003, 08:49:13 pm »
It's working correctly. Those buttons are not assigned to anything in MAME mode, you need to program them. The reason they are not assigned is that there is no standard MAME setting for them. To program a 4 player panle with 6 buttons for all 4 players needs care, and you generally have to change some of the player 1 and 2 settings (eg for buttons 7 and 8) to avoid conflicts. So it was not really practical to have every single input assigned a setting in MAME mode. All of the keycode settings are in the table on the web page mentioned in an earlier post and it clearly shows these as being blank.
Andy
