Author Topic: Mala Issue  (Read 2192 times)
Taborious
  • Last login:December 29, 2011, 04:55:45 pm
  • Win or go Home!
    • The Way Back Machine
Mala Issue
« on: July 25, 2010, 09:46:25 am »
My sons, while banging on the buttons, freaked Mala out and now I can get a normal game list. When I start Mala i see the screenshot thats attached. I can move around but i cant figure out how to get out of this section and back to the gamelist.
The Way Back Machine - http://www.taborious.com
empardopo
  • Last login:January 18, 2026, 03:32:00 am
    • My personal forum
Re: Mala Issue
« Reply #1 on: July 26, 2010, 04:28:32 am »
I would look my layout with MalaLayout.
Then, you can check the configuration of MALA and If Mala still fails you should configure MALA from the beginning.
These are the steps I would.
Try and comment.
Taborious
  • Win or go Home!
Re: Mala Issue
« Reply #2 on: July 26, 2010, 11:11:30 am »
Well, this was all working fine at one point. So I know that the layout is correct. Whatever my son did it was from the control panel, hitting multiple key combos.
I'll take a look at configuring over, make a backup of the config afterwords in case it happens again.
empardopo
    • My personal forum
Re: Mala Issue
« Reply #3 on: July 27, 2010, 09:15:42 am »
I'm sorry but i don't know where it will be the problem!
If you want you can share your layout and i can take a look at this.
Greetings
Taborious
  • Win or go Home!
Re: Mala Issue
« Reply #4 on: July 30, 2010, 10:09:22 am »
I deleted; actually renamed, my old male.ini file and started over. so something was screwed up in the ini file.
