Author Topic: Cutting MDF  (Read 4867 times)
Darren01274
  • Last login:September 12, 2020, 10:05:08 am
Cutting MDF
« on: June 29, 2010, 01:17:24 pm »
What is the best Saw/Tool to cut out the sides and panels for Arcade Cabs.
Re: Cutting MDF
« Reply #1 on: June 29, 2010, 01:35:05 pm »
Table saw / router / circular saw
Franco B
Re: Cutting MDF
« Reply #2 on: June 29, 2010, 01:36:41 pm »
Personally, jigsaw the bulk of and finish with a router.
Darren01274
Re: Cutting MDF
« Reply #3 on: June 29, 2010, 01:50:04 pm »
Hi used a jigsaw but wasnt getting very good straight edges and was a little jagged
Re: Cutting MDF
« Reply #4 on: June 29, 2010, 02:00:19 pm »
Right, which is why Franco uses a router to finish.  Basically, you get a flush trim bit and a straight edge, and route the MDF for a perfect straight line.
You can also cut one side, and use it as a pattern for the router to cut the other side, that way your 2 sides are identical.
Epyx
  • "You're an oddity"
Re: Cutting MDF
« Reply #5 on: June 29, 2010, 04:03:56 pm »
+1 to both of these
Although I would put router ahead of the table saw. I strongly believe that the router is the single most important/versatile cab building cutting tool.
You could build an entire cab with just a router and drill.
Last Project
Epyx Tutorials:
Tutorials
Darren01274
Re: Cutting MDF
« Reply #6 on: June 29, 2010, 04:46:11 pm »
Thanks guys. I don't have a router I was looking but there are so many which ones would be the best to get. Also how easy are Routers to use to get good straight lines etc.
Marsupial
  • Last login:April 17, 2024, 09:00:56 pm
  • I am teh Mars!
Re: Cutting MDF
« Reply #7 on: June 29, 2010, 09:52:16 pm »
I am new to using a router.
all I can say is this:
GET ONE
It is incredible the things you can do with a router, it opens a new world of woodworking opportunity. Seriously.
-Mars
Darren01274
Re: Cutting MDF
« Reply #8 on: June 30, 2010, 05:32:46 am »
What Router bits do I need to cut out the cab and T-Moulding.
Epyx
Re: Cutting MDF
« Reply #9 on: June 30, 2010, 11:06:21 am »
It is easy to do a straight edge with a router. Router's have bits called flush trim bits. They will have bearings either at the top or bottom of the bit. This means you place a template piece (straight edge, circle, curve etc) above or below and use that as your guide. IE if you use a straight piece of wood as your template, you will get a straight line.
If you go to T Molding.com it will show you what slot cutter size you need (Another router bit) for the selected T Molding.
As for starting bits. Here in Canada we have a store called Canadian Tire that usually has sales on sets of carbide tipped router bits (not sure where you are).  These sets are usually 48/96 pieces etc for obscenely low prices (like $29.99/$49.00).  The set will include a good assortment of flush trim bits and other useful ones but the slot cutter is usually special order but many company's make them (like Freud etc).
Last Project
Epyx Tutorials:
Tutorials
Darren01274
Re: Cutting MDF
« Reply #10 on: June 30, 2010, 04:38:38 pm »
Hi thanks for the info wow this forum is the business. And all you guys are very helpfull!!! many thanks
Ed_McCarron
Re: Cutting MDF
« Reply #11 on: June 30, 2010, 10:16:02 pm »
And, needless to say, when working with MDF wear a decent respirator and safety glasses -- the stuff makes dust like theres no tomorrow.
dawolv
  • Last login:March 25, 2016, 08:23:21 am
Re: Cutting MDF
« Reply #12 on: June 30, 2010, 10:23:47 pm »
ALWAYS
Marsupial
  • I am teh Mars!
Re: Cutting MDF
« Reply #13 on: July 01, 2010, 01:07:04 am »
The magic of a router with shopvac connection is that 95% of that dirt gets sucked in the shopvac before you see it. Its really miraculous!
-Mars
jholman76
Re: Cutting MDF
« Reply #14 on: July 01, 2010, 11:18:48 am »
And as with all tools that can easily take a finger/life...
Respect it.
a bit rotating at 25,000 rpm can be quite the deadly weapon. Make sure the bit is secured. I usually turn my on in pulses to make sure it isnt going to hurl out and put a hole in my temple, but thats just me being way to safe.
besides the special-order slot cutter, I tend to stick to Porter-Cable and Freud bits. After a close call with a cheap carbide circular saw blade (flying carbide bits), I only get the name brand.
And I second that a router will open up your wood-working abilities like Aladdin promised Jasmine on that singing carpet ride.
OH, there are a lot of how-to videos online. Just google router videos and you will find a lot. Watch the safety ones too.
and FWIW, dont hold your mouth open when cutting anything. Especially laminate. I'm still spitting out black bits!  :P
joe
Darren01274
Re: Cutting MDF
« Reply #15 on: July 01, 2010, 03:13:50 pm »
LOL thanks. I think now is the time to watch the videos while the wife watches Emmerdale haha
