Author Topic: U360 Issue  (Read 1554 times)
bmac300
  • Last login:June 29, 2013, 06:56:28 pm
U360 Issue
« on: June 08, 2010, 07:59:53 pm »
I just plugged in my Ultrastik 360 and I've run into a problem with the left and right being reversed.  If i rotate the joystick my up and down is reversed.  This has to be something simple but i can't figure out why it is doing this.  Could it be that the board with the usb connector and LED light was put on upside down?  I can't find a good picture but my LED light and USB is on the bottom of the joystick.  From the pic on the website it looks as if this should be on the inside of the joystick if you know what i mean.  Does this make sense to anyone?  Also, i see some text on the board that says up and again this is on the bottom of the joystick.  If this is the case can i just unscrew and flip it around?
SammyWI
Re: U360 Issue
« Reply #1 on: June 08, 2010, 08:10:13 pm »
Yes, the LED and USB port should be upward or 'inside' on the joystick.  Unscrew the board and flip it over and you should be fine.
