Author Topic: Velcro!  (Read 2038 times)
Jawn
  • Last login:July 22, 2010, 10:21:30 am
Velcro!
« on: May 30, 2010, 02:56:55 pm »
Would some strips of heavy duty velcro be suitable for holding a small control panel (it will also have support beams that reach the ground) in place?  I'm working on building a small 2 player panel and would like to be able to have it swappable for one with a trackball and flight joystick. Is velcro sturdy enough? Anyone ever tried using velcro before? What alternatives are available that are cost effective and cheap? Thanks in advance :)
Sir Headless VII
  • Last login:April 30, 2017, 02:04:52 pm
Re: Velcro!
« Reply #1 on: May 30, 2010, 03:05:50 pm »
I use Velcro from a craft store used to hang pictures. It works really well. It is very sturdy but easy enough to move should I want to.  It was a bit more expensive than I thought it would be (although realistically I was comparing it to screws) but it works perfectly so I am happy.
Jawn
Re: Velcro!
« Reply #2 on: May 30, 2010, 03:20:01 pm »
Thanks for the quick reply! I'll most likely be putting it on my to-buy list.
Re: Velcro!
« Reply #3 on: May 30, 2010, 04:21:55 pm »
+1
I use velcro for all kinds of stuff.
SammyWI
Re: Velcro!
« Reply #4 on: May 30, 2010, 04:58:10 pm »
Velcro makes some very strong stuff called Velcro Extreme.  Good strong adhesive and both halves are stiff plastic - no fuzzy loops.  The 'velcro' part is basically stiff little plastic prongs with a flared end.  This may work for you.
jasonbar
  • Last login:September 04, 2025, 11:58:58 pm
  • Dr. Inferno
    • The Infernolab
Re: Velcro!
« Reply #5 on: May 30, 2010, 07:33:54 pm »
Velcro is great & will be plenty strong to hold your panel in place.
There might be difficulty in removing your Velcroed-on panel, however, depending on how you set things up.
Velcro is difficult to pull apart when you're pull the 2 halves straight apart from each other (in a direction normal to the plane of the Velcro).
Velcro comes apart very easily when you peel it (like Velcro sneaker "laces").
If you can remove your panel by a sort of tilting/rolling motion, you'll have better luck.
But, just go ahead & try it & find out--it's easy to test it out!
Good luck--sounds like a great idea.
-Jason
delta88
  • Last login:May 20, 2025, 08:21:05 am
  • This place is still here?
Re: Velcro!
« Reply #6 on: May 31, 2010, 12:16:13 am »
Do it says this old timer.
If you dont like the results it was less destructive then mounting clamps and such.
Epyx
  • "You're an oddity"
Re: Velcro!
« Reply #7 on: May 31, 2010, 04:33:28 pm »
Velcro works just fine.  To assist you in remove a velcro'd CP...use a credit card to slide between the layers and detach, works quick that way.
Last Project
Epyx Tutorials:
Tutorials
Jawn
Re: Velcro!
« Reply #8 on: June 02, 2010, 12:32:20 pm »
Just wanted to say thanks to all who responded. Definitely gonna try some different set ups with it to see which works best.
nick3092
  • Last login:March 22, 2022, 03:57:28 pm
Re: Velcro!
« Reply #9 on: June 02, 2010, 02:56:00 pm »
Velcro works very well for mounting a cp. I'm building a modular panel like Doc's, but didn't want the hassel of aligning dowl pins and holes. I went into it thinking it might not work, but all the panels hold securely. Just make sure you prime/paint the MDF where the Velcro will stick to.
notaburger
  • Last login:April 16, 2021, 03:38:49 pm
Re: Velcro!
« Reply #10 on: June 03, 2010, 06:48:42 pm »
I went the velcro route too.
Works like a charm.
gwjrabbit
  • Last login:January 13, 2014, 02:43:00 pm
Re: Velcro!
« Reply #11 on: June 03, 2010, 10:36:30 pm »
Yep, I used the heavy-duty velcro off the rack from Home Depot for my Doc's-like modular, and there's very very little rocking on the joysticks, unless you're REALLY going to town in smash TV. I also used it to mount my admin panel, my bezel, my speakers, my speaker grills, my powerstrip, and my iPac.  Wondertwin Powers Activate!
