Author Topic: major led blinky issue, help!  (Read 1310 times)
milkit
  • Last login:June 28, 2014, 09:14:33 pm
« on: May 01, 2010, 05:02:43 pm »
i have a GGG led-wiz running my led buttons with led blinky and maximus arcade FE.
if i just run mame, games work perfect.
if i unplug the led wiz, games run perfect in maximus.
if i use the led wiz + front end, i cant play games properly. after a few seconds the video starts to lag and studder BADLY. even on pacman!
its a dual core athlon II x2 255 with 2gb ram, no reason it should lag on pacman.
I cant seem to figure out the problem. Bad led-wiz maybe? any ideas?
arzoo
  • Last login:January 26, 2025, 08:51:53 am
  • Robots WILL kill you.
    • LEDBlinky
Re: major led blinky issue, help!
« Reply #1 on: May 02, 2010, 09:09:23 am »
Use Windows Taskmanager to check which app/process is using the most CPU cycles - that will help narrow down the problem.
You could also turn on the LEDBlinky Debug and Verbose options and email me the debug.zip file - I'll check if blinky is working as expected.
Robots will kill you.
Arcade Addiction
milkit
« Reply #2 on: May 02, 2010, 09:38:53 am »
it was being caused by the "Front End -> Button Flash" option i discovered. Tried all diff flash speeds. Literally made games unplayable yet there was no bump in cpu usage or anything
arzoo
    • LEDBlinky
« Reply #3 on: May 02, 2010, 10:21:12 am »
Hmm - the button flash feature should only be active when the FE is active - not when playing a game. If you turn on debug and verbose and button flash and send me the debug.zip I should be able to fix the problem.
Arcade Addiction
arzoo
    • LEDBlinky
« Reply #4 on: May 02, 2010, 10:26:50 am »
I just did a quick test with button flash and MA on my rig and it worked as expected - no lag when playing Asteroids. But I'm sure you're using a different combination of settings so I'll need to see the log.
Arcade Addiction
