Author Topic: How to secure plexi over your cp?  (Read 2796 times)
RandomCitizenX
  • Last login:May 05, 2014, 03:26:34 pm
« on: April 26, 2010, 01:12:41 pm »
I am starting on my cp either today or tomorrow, and I have been trying to figure out that best way to secure the 1/4 plexi onto my 1/2 plywood for cleanest effect. I have seen some cp's using bolts, while others have no visible way of securing the plexi beyond the tension from the buttons. Any insight or suggestions would be greatly appreciated.
DashRendar
Re: How to secure plexi over your cp?
« Reply #1 on: April 26, 2010, 01:18:34 pm »
On mine, the t-molding covers the front edge of the plexi.
The buttons take care of anchoring it down to the surface of the control panel.  It's extremely snug like this and doesn't move at all.
Epyx
  • "You're an oddity"
« Reply #2 on: April 26, 2010, 01:20:21 pm »
Agreed...all you require are the buttons and T Molding overlap to hold them in place.  Just make sure your T Molding sits flush with the Plexi to provide additional grip around the perimeter.
Last Project
Epyx Tutorials:
Tutorials
severdhed
  • RIP Dinosaur Hippo
« Reply #3 on: April 26, 2010, 02:36:59 pm »
+1
that is more than enough to secure the plexi
bkenobi
« Reply #4 on: April 26, 2010, 03:26:58 pm »
I went overboard then.  I installed bolts in the corners to keep the plexi from coming up.  It doesn't move anyway, so I guess it just adds more holes for no reason.   :dunno
Beretta
« Reply #5 on: April 30, 2010, 10:58:18 pm »
i'd say it depends highly on the size of the CP and the thickness of the plexi.
bolts dont bother me known so i'd think carriage bolts along the edges would be the way to go for a larger CP.
Epyx
« Reply #6 on: May 01, 2010, 01:53:19 am »
Then again the larger, the more gravity keeps it in place as well...unless you really like bolts there isn't a need for them from a "keep it down" point of view.
Last Project
Epyx Tutorials:
Tutorials
Beretta
« Reply #7 on: May 01, 2010, 03:13:20 am »
what does gravity have to do with it?
if you've got a large cp and thin plexi it's not going to hold it down as well as a small cp with buttons covering most it's surface.
severdhed
« Reply #8 on: May 01, 2010, 08:23:49 am »
if the edges of the plexi are covered by the Tmolding, then there should not be a need for bolts, regardless of the panel size.    you are laying one flat surface directly against another, and it is secured in the middle and the edges, there is really nothing that is going to cause them to want to separate.
WhereEaglesDare
    • My HomePage
« Reply #9 on: May 01, 2010, 09:38:32 am »
if you are using 3/4 in mdf and you get 3/4 in t molding then it shouldnt cover the plexi at all, right?
Franco B
« Reply #10 on: May 01, 2010, 09:44:09 am »
You can offset the t-moulding and then bevel the bottom edge of the CP. Take a look in [this] thread.
WhereEaglesDare
    • My HomePage
« Reply #11 on: May 01, 2010, 10:55:53 am »
indeed
severdhed
« Reply #12 on: May 01, 2010, 01:22:04 pm »
another good way is to use 5/8" MDF and a 1/8" plexi
WhereEaglesDare
    • My HomePage
« Reply #13 on: May 01, 2010, 01:46:50 pm »
yea, i cant find any around here,  got that 1/2 in though.
Franco B
« Reply #14 on: May 01, 2010, 02:58:54 pm »
1/2" MDF and 1/4" acrylic :)
Seriously though. I always thought a thick acrylic CP may look nice.
Epyx
« Reply #15 on: May 02, 2010, 01:37:09 am »
I mentioned T Molding above and offsetting it so it grips the plexi.
Last Project
Epyx Tutorials:
Tutorials
Blanka
« Reply #16 on: May 02, 2010, 04:03:41 am »
If you are afraid that the plexi gets loose at the corners, maybe it is something to use Plexiphoto for the bezel. They can print your design on the plexi itself.
Beretta
« Reply #17 on: May 02, 2010, 12:27:05 pm »
that would be pretty neat for reproduction monitor artwork.
on a CP though i'd think it would be a down side.. CP is the most used part of the cabinet and will show it's wear first.
if you had the artwork printed on the plexi and it gets scratched up or cracked be harder / more expensive to replace.
