Author Topic: What are peoples buttons mapped like?  (Read 8386 times)
Don
  • Last login:March 26, 2024, 04:39:03 pm
« on: April 24, 2010, 01:07:44 pm »
Hey,
In a six button layout, what is normally the 1st button - top row or bottom row? Mapping out my controls and not sure!
DJ_Izumi
  • Last login:November 04, 2023, 04:19:22 pm
Re: What are peoples buttons mapped like?
« Reply #1 on: April 24, 2010, 01:24:18 pm »
I uhh, Google up the arcade layout for said game and then match it to the 6 button layout as best I can. o.o
Don
« Reply #2 on: April 24, 2010, 01:36:34 pm »
I'm talking more for console games. I'm making a bezel with controls for each system and am wondering where to map them. For example in a game using only 2 buttons, do you map them to the first 2 on the top or bottom row in a 6 button layout?
WhereEaglesDare
    • My HomePage
« Reply #3 on: April 24, 2010, 01:40:36 pm »
What is comfortable for you?  I would use first bottom two.
bkenobi
« Reply #4 on: April 24, 2010, 01:42:05 pm »
The correct answer is whatever is most comfortable for you.  I find a gamepad is more comfortable personally, but that might just be me.  Games that were designed for an arcade CP do play well with one though (primarily fighting games).
ptinolv
  • Last login:January 20, 2024, 01:37:18 am
« Reply #5 on: April 24, 2010, 01:52:59 pm »
I use the top row. That is mostly because if i use the bottom row, the kicks and punchs are inverted in street fighter (mame default settings).
WhereEaglesDare
    • My HomePage
« Reply #6 on: April 24, 2010, 02:10:09 pm »
you can just program them differently in your emulator
ptinolv
« Reply #7 on: April 24, 2010, 04:53:58 pm »
I know  :) but I would have to change the controls for each capcom fighting game. I also like this setup for neogeo games because i can have 4 buttons under my hand using the top row and the first button of the bottom row (my layout is curved).
« Last Edit: April 24, 2010, 04:55:57 pm by ptinolv »
TOK
  • The Game Always Wins
« Reply #8 on: April 24, 2010, 04:58:07 pm »
 123
 456
7
Bottom row button 7 is positioned like Neo Geo. Also close enough to the stick to be used for Reverse in Defender and Smart Bomb in games like Smash TV and Tutankham. I don't play console games on it... I used to buy consoles because it was the only way to get ports of the arcade games, substandard as they were.  ;)
« Last Edit: April 24, 2010, 04:59:38 pm by TOK »
eclipso
  • Last login:August 21, 2018, 08:51:25 am
« Reply #9 on: April 24, 2010, 07:00:00 pm »
+1
Ginsu Victim
  • Comanche, OK -- USA
« Reply #10 on: April 25, 2010, 11:53:50 am »
+1
+1 as well
Mine is weird.
456
123
    4
I don't care about punches and kicks being swapped, since I didn't play that many Capcom fighting games to begin with.
WhereEaglesDare
    • My HomePage
« Reply #11 on: April 25, 2010, 01:11:04 pm »
Anyone use anything like this?
I was thinking of using it for a 7 button layout, taking out the top left button.  Will it be comfortable?
Ginsu Victim
« Reply #12 on: April 25, 2010, 04:28:09 pm »
No, it wouldn't be a good layout for Capcom fighting that way. You can, however, remove the two right buttons, then use the buttons like so.
Capcom
123
456
Neo Geo
234
1xx
WhereEaglesDare
    • My HomePage
« Reply #13 on: April 25, 2010, 04:38:15 pm »
The only real appeal for 7 button is for Neo Geo right?
I mean there cant be many games that use 7 buttons.
« Last Edit: April 25, 2010, 05:04:48 pm by WhereEaglesDare »
Don
« Reply #14 on: April 25, 2010, 07:19:55 pm »
The mortal kombat games have the 'run' button in a similar place to the 1st neo geo button, but yeah cant even think of any arcade games that use 7 buttons
shateredsoul
  • Last login:January 25, 2013, 08:23:51 pm
« Reply #15 on: April 25, 2010, 10:31:28 pm »
I used something similar to that 7 button layout you are thinking about, but it looks a bit different.
This is my layout
Yes the primary reason is for neo geo gams.. they had 4  buttons in a row (the extra button on the bottom lets you have 4 buttons in a row). Honestly, that button will probably only be used for king of the fighters and other neo geo fighters.
I think most systems will work fine with 6, and the ones that need more than 6 actually work better using a joypad
I'll let you know how it feels, I should have it in a week or two
WhereEaglesDare
    • My HomePage
« Reply #16 on: April 26, 2010, 08:31:44 pm »
what is the joystick on the upper level for?  never understood that.
Hewskie
  • Last login:July 27, 2018, 02:45:42 am
« Reply #17 on: April 26, 2010, 08:52:22 pm »
dedicated 4-way i believe
WhereEaglesDare
    • My HomePage
« Reply #18 on: April 26, 2010, 08:53:30 pm »
so you got a joystick just for 4 way games?  Hmm.. is it comfortable to play with way up there?
shateredsoul
« Reply #19 on: April 26, 2010, 09:03:54 pm »
Yeah I did,
I haven't tried it out yet since I don't have the c panel yet, but I can't imagine it being too bad.  Another alternative is to get those u360 joysticks.. I hear with mame they can automatically switch between 2 way, 4 way, and 8 way depending on the mame game you are playing. You'll be able to use both joysticks for player 1, the only difference is that the 4 ways makes it easier to play some of the older games.
I have a spinner hole too (hey hey, no jokes).. not sure if I'll put that in right away because of the cost of the turbo twist.
WhereEaglesDare
    • My HomePage
« Reply #20 on: April 26, 2010, 09:05:55 pm »
I don't know what it is about your avatar ShateredSoul, it could just be that you go by ShatteredSoul, but that avatar creeps me out.
« Reply #21 on: April 26, 2010, 10:01:45 pm »
Something like this?
I always start on the top left because that's where people's hands automatically go.
I flip the top and bottom rows from the original controller since the bottom buttons on the original controller were used more.
It feels right and isn't as confusing as it sounds.
« Last Edit: April 26, 2010, 10:06:40 pm by BadMouth »
Ginsu Victim
« Reply #22 on: April 26, 2010, 10:20:25 pm »
Really? Everyone I know just assumes the bottom row on mine, and they're right.
Epyx
  • "You're an oddity"
« Reply #23 on: April 26, 2010, 10:34:09 pm »
/shrug if it works...everyone I know assumes top left as well.
Last Project
Epyx Tutorials:
Tutorials
« Reply #24 on: April 27, 2010, 09:15:37 am »
the "7th neogeo button" is also great for most 3 button jamma games (using Neogeo's ABC) especially in games like NBA Jam, NBA HangTime, NHL Open Ice,etc,etc
« Last Edit: April 27, 2010, 10:24:52 am by Malenko »
shateredsoul
« Reply #25 on: April 27, 2010, 07:28:31 pm »
Ha ha, I just caught this. Yeah, I know it's creepy!
I've noticed you are asking a lot of the questions that I have and that I'm thinking about.  When are you thinking of building your cabinet? I was thinking of July or August during the summer.  It might be good for us to share info.  Have you looked into any particular cabinet designs? I'm going for a slim design.
davieboynj
  • Last login:June 16, 2011, 01:32:09 am
  • Eating your legs solves lifes little problems.
« Reply #26 on: April 28, 2010, 12:23:41 pm »
Capcom
123
456
Neo Geo
234
1xx
I know this is an opinion thread, but unless you agree with this, you're DEAD WRONG.  ;)
Ginsu Victim
« Reply #27 on: April 28, 2010, 05:16:49 pm »
Capcom
123
456
Neo Geo
234
1xx
Your wording confuses me. Are you agree or disagreeing with my statement?
Dazz
  • HyperSpin Team
    • VPUniverse
« Reply #28 on: April 28, 2010, 06:58:09 pm »
The control panel that I just finished has this layout.  After playing on it for a while it's very comfortable.
Ginsu Victim
« Reply #29 on: April 28, 2010, 08:39:32 pm »
The angle of the six buttons seems very odd that way.
WhereEaglesDare
    • My HomePage
« Reply #30 on: April 29, 2010, 08:04:09 pm »
maybe i should turn the whole button pad left a few degrees...
shateredsoul
« Reply #31 on: April 30, 2010, 01:23:39 am »
How about snes? gamecube, dreamcast, wii, and nintendo ds all have no more than 7 buttons, which is how many buttons my pane has.
n64, ps1, ps2,sega saturn etc seem to have too many buttons for playing on a cab. If I wanted to use some of these systems for shmups, 2d platformers, and fighters I wonder if it would matter much if I left out L2 and R2 for ps1 and 2, left ouf the shoulder buttons for sega saturn, and n64 has wayy too many buttons.  But for fighters, platformers, and shmups I Imagine I can get away with leaving out Z, up c an dright C
Ginsu Victim
« Reply #32 on: April 30, 2010, 09:19:33 am »
I play plenty of PSX games on my cab. The ones that play well on it don't need more than 6 buttons.
WhereEaglesDare
    • My HomePage
« Reply #33 on: April 30, 2010, 11:24:03 am »
Usually a good fighting PS1 game with have the L1 set to be the same as R1 and the same for L2 and R2.  All you need is R2 and R1.  So you really only need 6 plus a start/select button.
and on the N64 all you will really lack for most games is the C buttons and guess what you have a whole other joystick to your right...  use that for your c buttons.  And if you count the N64 buttons it's only 10 buttons, so if you move the c buttons over then you have enought for 6 button pad.  On good multiplayer games on N64 like Mario Kart, you dont need the c buttons as much.
and about PS2 if you can get that emulator to work on your cab then you are a better man than I.
I still dunno if I should go with 7 buttons or 6 buttons since I will be playing  A LOT of neo geo and a lot of emulators.
Beretta
« Reply #34 on: April 30, 2010, 10:44:22 pm »
my project is far from playable but i will be going with a 6 button layout straight, killer instinct / street fighter (US) basicly.
default will be
123
456
however since i love setting up dip switches and tweaking service menu settings i imagine most games will be reconfigured by hand one the first start up.
example 4 button games will probably be
12
34
instead
a lot of people like the cured layouts these days.. i grew up on straight button layouts so thats what i'll stick with, think it looks better too.
as for the 5,7,8 button debate.. if you're going ot play console emulators 8 buttons would be good, but would rarely be used in mame.. although you could go for a semi authentic neogeo layout.
i think 6 buttons is really probably your best bang for your buck but you gotta decide whats the most important thing to you.. some would say a tasteful 2 or 3 button layout is the way to go, others like to go with the shotgun method.. and tack on about 40 buttons.
WhereEaglesDare
    • My HomePage
« Reply #35 on: May 01, 2010, 10:59:00 am »
Can LED Wiz do 40 buttons  ????   :dunno
Franco B
« Reply #36 on: May 01, 2010, 11:45:26 am »
A LED Wiz can only control 32 outputs.
You could double up some of the buttons if you only wanted to use one LED Wiz.
Personally I would use multiple LED Wiz's. If you want to light 40 buttons individually you could use one LED Wiz and one LED/GP-Wiz for your encoder providing you only needed 16 inputs. Alternatively you could use the encoder etc of your choice and two LED Wiz's
This is presuming we are talking about single colour LEDs. If its RGBs you can multiply the outputs required by 3.
shateredsoul
« Reply #37 on: May 01, 2010, 12:15:54 pm »
I too was considering doing the light up buttons... but after thinking about it, and how much it would cust to get the right buttons, ledwiz, and all that stuff.. I decided to stick with only a light up trackball. People will be impressed with the fact that you have a arcade cabinet... I can't imagine the light up buttons would make it a better experience.
