Author Topic: Any reason why Popeye (Revision F) runs so slow???  (Read 1736 times)
  • Last login:Yesterday at 04:57:25 pm
« on: April 14, 2010, 09:40:52 am »
I can't seem to figure it out... everything else I am running is smooth as hell EXCEPT for Popeye.  The audio stutters like crazy (everything does, actually).  Has anyone else run into this problem?  Would going to a different version (revision) fix the problem?  My computer specs are pretty good and it runs Killer Instinct, SFIII and pretty much everything within reason with no trouble.
  • Last login:Yesterday at 10:50:22 am
Re: Any reason why Popeye (Revision F) runs so slow???
« Reply #1 on: April 14, 2010, 11:09:11 am »
Sounds like you're running a newer MAME.  Try stepping back to an older version.
Hoopz
  • Intellivision Rocks!
« Reply #2 on: April 14, 2010, 11:37:38 am »
There are two bugs with Popeye.
http://www.mametesters.org/view.php?id=3726
http://www.mametesters.org/view.php?id=3725
One is sound based and the other is a sprite issue.  I'm not sure if they would cause this problem or not.
« Reply #3 on: April 15, 2010, 12:17:59 pm »
I'm running MAME .119 something...  Popeye is the only game I've tried that doesn't work!  Maybe they haven't got all the kinks worked out?  Is anyone else having problems with it?
JODY
  • Last login:June 08, 2025, 11:26:01 pm
  • After a long delay...the arcade is underway!
« Reply #4 on: April 15, 2010, 09:07:57 pm »
My PC is slow and it runs fine on it using the newest Mame.
