Author Topic: Suggestions for powering on/off TouchScreen JukeBox  (Read 5694 times)
bsoder52
  • Last login:June 24, 2025, 11:29:40 pm
« on: March 23, 2010, 06:33:21 pm »
I'm doing an ELO touchscreen JukeBox build and plan to have the PC hidden behind a wall in another room (furnace room).  Is there a front-end I can run that will allow me to both power off and power up the pc from the touchscreen somehow?
Crazy question it seems, but thought I'd ask!?!?!?!
 >:D
Space Fractal
  • Space Fractal
    • Space Fractal
Re: Suggestions for powering on/off TouchScreen JukeBox
« Reply #1 on: March 23, 2010, 06:39:13 pm »
property not, not with touchscreen (due as I assume don't drive like a mouse and hence not directly supported by bios). Many apps do can shutdown when they quit.
But get a remote control instead to power on/off and control it that way. Some of them can power on your machine.
« Last Edit: March 23, 2010, 06:45:24 pm by Space Fractal »
bsoder52
« Reply #2 on: March 23, 2010, 07:28:08 pm »
never heard of them, can you point me in the right direction?
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
« Reply #3 on: March 23, 2010, 10:26:44 pm »
The only way that might work is putting it in standby instead of power it off, if it supports wake on moue then it MAY wake on touchscreen but it is not something I have ever tried personally. I just set my bios to boot on power resume s i switch the wall socket on and it powers up, my software powers it down. I still have to pull the plug as the amp and juke lights would stay on otherwise.
« Reply #4 on: March 23, 2010, 10:49:59 pm »
You know what might be cool for something like that?
one of those "touch light" things that you wire up in line with a light, and then connect a wire to a metal object somewhere. When you touch the metal, the light comes on. They have em at home depot.
You'd probably want to rig it so that touching it could ONLY power up, and not power off, but other than that, it could be cool.
then, you'd just have to touch something metal around the screen, maybe a screw or something.
Fordman
  • Last login:September 12, 2021, 11:20:27 am
  • MADE in the USA
« Reply #5 on: March 24, 2010, 04:54:39 am »
I use a regular arcade button to power on my jukebox.
As you can see the button is directly wired to the jukebox motherboard. Also, if you hold the button in for 3-5 seconds it will shut it down, but that isnt a good way to shut it down. To do that, I use Simple Touch Front End. I made a shutdown batch file, converted it to an .exe file and then select it to shutdown.
Fordman
unclet
« Reply #6 on: March 24, 2010, 01:58:18 pm »
Yeah, I used a regular arcade button (as described above) as well.  One push turns off the PC and one more turns it back on.
In my jukebox software, there is a button on the Options\Misc Page4 which allows you to shutdown your computer from within the application, but this will not help you turn ON the computer later    :P
abispac
  • Last login:March 18, 2026, 11:03:14 pm
« Reply #7 on: March 24, 2010, 05:16:39 pm »
thats the way to go...a push  buton  on the motherboard...
bsoder52
« Reply #8 on: March 24, 2010, 06:53:05 pm »
Thanks for all the ideas guys!  Going to go with the pushbuton idea fo shooo!
 :afro:
unclet
« Reply #9 on: March 25, 2010, 07:01:51 am »
if the wire is thin enough then you can most likely slide the molex plug (on your motherboard) over the pin and wire together.
hattrick10
  • Last login:November 13, 2020, 01:46:27 pm
« Reply #10 on: March 25, 2010, 10:46:41 am »
I use a combination of a push button switch (illuminated momentary switch) connected to the mobo header and one of those "smart" power strips.  The pc is plugged in to the "Always on" outlet of the strip and all the rest of my peripherals (both monitors, klipsch pc speakers, lighting, etc) are plugged into the "switched" outlets. When I power on the juke with the push button, the pc fires up and power is switched on the the monitors, speakers, etc.  To shut down I close album player on the touchscreen and shut down windows from the start menu on the touchsreen as well.
Paladin
  • Mmmm llamaburgers!
« Reply #11 on: March 26, 2010, 08:53:08 am »
I bought a pair of remote control power switches from a guy on KLOV.  Check out ebay item 180478216326 for a similar one.  The one I got controls 2 outlets.
I press the power on button and it turns on power to the powerstrip in the jukebox.  This turns on the PC (resume on power BIOS setting), touchscreen and speakers.
I use SimpleTouch FE for a front end, so when I'm done with the jukebox or game or whatever, I use the FE to shutdown the PC.  When the monitor goes blank I press the remote off button to turn off the powerstrip.
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
« Reply #12 on: March 28, 2010, 01:41:10 pm »
Doesn't album player shutdown windows for you on exit? Really I can't imagine you would want to see windows at all once it was all set up.
dafelandry
  • Last login:March 21, 2012, 12:08:40 pm
« Reply #13 on: March 30, 2010, 12:15:55 pm »
i use this http://www.mnpctech.com/Vandal_Resistant_Switch.html with the mobo cable
and my ELo turns off when no signal is sent to it
bsoder52
« Reply #14 on: March 30, 2010, 10:03:58 pm »
So I picked up the SimpleTouch Front End, looks pretty good.  How do I write the PC Shutdown Executable and load it up in the SimpleTouchFE as an option?
 :dunno
bsoder52
« Reply #15 on: March 30, 2010, 10:05:43 pm »
 :dunno
UPDATE:  Found the Shutdown option on theFront End so don't really need to konw this now.
bsoder52
« Reply #16 on: March 30, 2010, 10:06:36 pm »
I guess what I need to know is how do I tell the PC to auto start the SimpeTouchFE when the PC is started?
Fordman
  • MADE in the USA
« Reply #17 on: March 30, 2010, 11:06:33 pm »
Place a shortcut in the 'Startup' folder or use Instantsheller and use STFE as the bootable.exe file.
Fordman
arno
  • Last login:August 03, 2016, 12:27:22 pm
  • ArcadeWinkel.nl
    • ArcadeWinkel.nl
« Reply #18 on: April 01, 2010, 05:13:03 am »
Fordman
I also use the startup folder, works great  :)
hattrick10
« Reply #19 on: April 01, 2010, 10:13:01 am »
There is probably an option to have it do that but to be honest I haven't had the need.  Unfortunately, until I buy a new home, I don't have a resting place for my juke.  As it stands now its out in the garage and only comes out for special occasions.  I have it set up with dual monitors (only 1 touch) so a lot of the times I have other programs running for the other screen (videos, visualizations, etc.) so getting back to the windows desktop isnt all that bad as it allows me to kill the other running processes.
bsoder52
« Reply #20 on: April 02, 2010, 12:30:26 am »
Ok, I'll give the Start-Up folder a shot!  Learn something new everyday on here.
Thanks a bunch!
bsoder52
« Reply #21 on: April 04, 2010, 01:36:51 pm »
Ok, a little more help please, where do I find the start folder in Windows?
 :dunno
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
« Reply #22 on: April 04, 2010, 02:28:31 pm »
 :dunno
Right click the start button and selected explore all users.
Expand the programs folder and you should see a folder named STARTUP just copy the shortcut into that.
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
« Reply #23 on: April 04, 2010, 02:29:35 pm »
Doesn't album player handle the videos and vis on the second screen? Just seems like you could have things running a little more smoothly than you do at present.
bsoder52
« Reply #24 on: April 09, 2010, 05:21:59 pm »
update - got it working in the start-up folder, thanks!
