Author Topic: jpac users I need advice on a dual setup jamma and mame  (Read 1731 times)
gatordad
  • Trade Count: (+11)
  • Last login:November 06, 2025, 10:15:06 am
« on: March 16, 2010, 10:51:43 pm »
I am planning my next cab, jpac users perhaps you can give me some good advice
I have a avga card already
I am going to wire my new cab jamma
I want to be able to easily switch (in under 10 seconds) between mame and jamma game boards by powering down and just swapping the harness connectors off of the jamma board onto the jpac and back and forth as I have several original jamma boards I want to run in this game.
My first question is power related
I want to wire the cab jamma, I would then have power coming through the harness to supply the jamma boards here lies my question
I read the faq's and install guide for the jpac and it states
 "But my JAMMA cabinet DOES have a power supply.
Most cabinet power supplies will not function unless a game board is connected, owing to insufficient load. It is best to remove the power supply completely as the J-PAC does not need any power. All power comes from the keyboard or USB interface"
I don't want to do it that way cause I want to have jamma harness power available when I switch over for a jamma game board
Any suggestions on how to conquer (wire) this? without blowing up or frying the jpac
I really don't want to run 2 separate harness for this set up, neatness counts for this next project :)
gatordad
Re: jpac users I need advice on a dual setup jamma and mame
« Reply #1 on: March 18, 2010, 07:08:17 pm »
Just to finish up the thread and answer my own question
 I spoke with Andy and he said that doing it the way I intend will not cause any issues as long as the jpac and jamma harness is never plugged in backwards.
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #2 on: March 18, 2010, 07:52:19 pm »
I thought I had posted on this, but apparently not.
Only thing to watch is that since some power supplies get rather upset if they are powered up without a load, you may want to use the PS to power, say, coin door lights so that there is always a load.
Or just grab one of Clay's MultiJAMMA kits.
Working: Not Enough
Projects: Too Many
Progress: None
