Author Topic: Coin Mech (two of them) mod US->CDN query  (Read 4775 times)
Epyx
  • "You're an oddity"
« on: March 08, 2010, 09:48:34 pm »
Hi guys,
Hoping someone can help me with these Coin mechs...the metallic one is a Coin Controls (Royton Oldham England) USA .25 mech and the other a plastic CA US .25 mech.  Any idea where the magnets would be (to remove) to make these take Canadian quarters?
Last Project
Epyx Tutorials:
Tutorials
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
Re: Coin Mech (two of them) mod US->CDN query
« Reply #1 on: March 08, 2010, 10:25:44 pm »
Try opening up the plastic mech ("to open squeeze") -- I just opened up one of my Canadian CA mechs and can't tell if there would be space for a magnet in there (mine has a spring), but I would expect it to be right around the area labeled "to open squeeze".
EDIT: Turns out I do have a US CA mech in my box o' mechs -- the magnet is the round cylinder at the bottom when you open the first "door".
« Last Edit: March 08, 2010, 10:30:45 pm by CheffoJeffo »
Working: Not Enough
Projects: Too Many
Progress: None
Epyx
« Reply #2 on: March 08, 2010, 10:31:05 pm »
You are right...little magnetic cylinder which is pretty easy to remove.
Now to figure out the metalic ones!
Last Project
Epyx Tutorials:
Tutorials
  • Last login:January 26, 2026, 07:56:08 pm
« Reply #3 on: March 08, 2010, 10:33:25 pm »
the coin controls metal, is inside the square part.
the plastic one, i'm not sure... i always go with the imonex style and throw these ones out.
http://www.happ.com/cc/42118400.htm
CheffoJeffo
« Reply #4 on: March 08, 2010, 10:36:07 pm »
The metal one looks like a Coin Mechanisms mech that I have in the box o' mechs and the magnet in that one is definitely  behind the tilted rectangle near the centre. It is a pretty strong magnet in mine, so if you pull that arm out and put a Canadian quarter on it, it should stick right away. Getting it open on my mech looks to be a challenge, which is probably why it ended up in the box (and it came there from somebody else's box of unused mechs).
EDIT: I see lilshawn already got this one and should be ashamed of pitching such lovely mechs away and then paying $30 for a replacement!  ;)
Working: Not Enough
Projects: Too Many
Progress: None
« Reply #5 on: March 08, 2010, 10:41:54 pm »
tell everybody what...i'll start saving them... the once i have a box load i'll give them away to someone...hows that sound?
Epyx
« Reply #6 on: March 08, 2010, 10:56:33 pm »
The plastic magnet was held in a little clip and easy to remove so for sure I have the 2 mechs I will need.
On the Metalic ones, the magnet is in the square but seems impossible to remove...almost like they sealed the magnet in?
« Last Edit: March 08, 2010, 11:53:57 pm by Epyx »
Last Project
Epyx Tutorials:
Tutorials
« Reply #7 on: March 09, 2010, 11:56:41 am »
you could always use a propane (and propane accessories) torch to heat up the block... it will destroy the magnetic field within it... it's possible that they just magnetized the block there too. there may be no "magnet" in it.
all the ones like that i've seen have a "door" of such you can pry out or remove in some way.
if there is no other mech, i'd say torch it. (just don't go all funny and heat it up till it warps) prop open the "door" with the block on it with a bit of metal and heat it up until metal doesn't stick anymore.
Epyx
« Reply #8 on: March 09, 2010, 12:36:10 pm »
Im good for now with the 2 plastic mechs..thankfully those magnets were easy...any future mechs, Ill just buy some here in Canada :D
Last Project
Epyx Tutorials:
Tutorials
