Author Topic: THE MULTI VIDEO GAMES SYSTEM (MVGS): Play with All your retro-Gamepads on the pc  (Read 10693 times)
pat47200
  • Last login:December 15, 2010, 06:31:54 am
  • My first Mame-Cab since already 9 years....
    • ULTIMATE-ARCADE-STATION
Hello men,
I return to see you after his a few times to speak about my last creation , the Multi-Video-Games-System:
Thanks to this adapter which connects on USB port of your PC, you can play for the moment with the emulators Atari2600, Atari7800, Master-System, Nes, Megadrive, super-Nintendo, Gx4000, PC-Engine, supergameboy with their original gamepads.
The original gamepads are modified, their cable are replaced by a HD-15 connector and their printed circuits was modified too.
Indeed, each pads will have a single and same HD-15 cable to connect to the MVGS.
The first pack:
-The box:
-Inside the box:
-The instruction book:
-First you must connect the MVGS on your pc:
-First, the MVGS is detected as a gamepad:
-Second, the MVGS is detected as a usb key:
-In the usb key you have a .exe, when you click on, a menu appear and you can select your video games system:
-Now to play you must connect the HD-15 cable on the MVGS and to the gamepad:
-Now you can play for example to Wonderboy3 on master system, to megaman on nes, etc....:
And  2 videos here:
And Here you can find all explications:
http://pagesperso-orange.fr/ultimate.arcade/tuto14.htm
See you later. ;)
PS: sorry for my english, i'm french....
« Last Edit: April 26, 2010, 04:55:27 am by pat47200 »
MY WEB PAGE:
crashwg
I have to find one of those Super Gameboy Commanders.  I didn't know they existed before now.  What a cool accessory!
I like the project.  The only part I would try and fix is the use of the DB15 cable.  I've actually tried to do a similar project myself involving interchangeable classic controllers for use with the XBOX and was put off by the stiffness and weight of DB15 cables.  I was able to find "ultra-thin" ones that were much better than the usual but even then the issue of the stiffness still detracted from the experience so I scrapped the project.
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
Yeah, I have to agree about the cable comment. Looks way to clunky and stiff. My first thought was an ethernet cable, but that wouldn't get you quite enough wires, I'm guessing.
  • Last login:July 23, 2025, 07:04:20 pm
I've done this same thing for the Xbox as well, and yep, the DB-15 cables are stiffer than the OEM.  Unfortunately, you need all those wires.
Ginsu Victim
  • Comanche, OK -- USA
Found one place so far that has them
http://www.gamebaz.com/?a=i&i=33960
Everywhere else has said out of stock.
pat47200
Update:
New HD15 cable, smaller and more flexible, made with a Microsoft Sidewinders DB15 cable.
Before:
And now:
And the pack MVGS2P,
With it we two players can play now:
- A personal box.
- The Multi Video Games System Second Player (MVGS-2P).
- A HD15 flexible cable.
- A Amstrad GX4000 pad.
- A Nec Pc Engine pad.
-The box:
-Inside the box:
-To play you must connect the MVGS-2P on the usb port of the MVGS:
-The MVGS-2P is detected as a second gamepad:
-Now you connect the hd-15 cable on the MVGS-2P and on the second gamepad:
-Now two players can play together on the MVGS:
You can find all explications here:
http://pagesperso-orange.fr/ultimate.arcade/tuto15.htm
See you soon. ;)
« Last Edit: March 15, 2010, 05:41:00 am by pat47200 »
MY WEB PAGE:
crashwg
Ooohh, that does look much more flexible! I'm going to have to pick up a few of those.  I curious as to why they are DB15 though...  What would you plug that into?
Lemme say it again
Gameport?
DillonFoulds
Ground
Up
Down
Left
Right
Select
Start
A
B
X
Y
L1
L2
R1
R2
15 Wires (14 signals, and a ground), 15 pins, db15, would be my guess. Any controller with more buttons than these are SOL, but probably pretty rare. My guess is the controllers are just wired up to skip the IC, and the db15 carries wires to an encoder-type device (like an i-pac or keywiz, for the BYOAC'ers). Not really rocket science considering the audience...
pat47200
Ground
Up
Down
Left
Right
Select
Start
A
B
X
Y
L1
L2
R1
R2
exactly,
1 ground, 4 directions and 10 buttons. ;)
MY WEB PAGE:
crashwg
I wasn't wondering about this guys hack...  If you read my post before that one you'll see that I've done a similar hack.  I was referring to the M$ Sidewinder.  I must not be old enough to remember when computers had DB15 connectors for gaming inputs.
Lemme say it again
Ginsu Victim
They were MIDI ports on sound cards. More people used them for game controllers than MIDI.
I've been proven wrong.
« Last Edit: March 12, 2010, 11:10:45 am by Ginsu Victim »
DillonFoulds
I had a DB15 gamepad that had another db15 on the other end, and you could stack them up, and have multiple controllers on the port. There was a switch on the bottom of the controller to select the controller number.
versapak
  • I am t3h GAY!!!
Actually...
They were game ports, and their primary use was always game controllers.
MIDI abilities came later, and they required adapters.
Ginsu Victim
Ahhhhh....
I have a MIDI keyboard with an adapter and didn't understand why it needed one. Now I know.
Thanks.
crashwg
OK, I understand now...  Should have CHECKED THE WIKI.  According to it, the "game port" is DA-15 and a VGA, SVGA & XVGA port is DE-15.
Looks like I have something new to look out for when I go to the Goodwill.
Lemme say it again
daywane
  • Last login:August 29, 2025, 03:53:34 pm
  • GRRRR!
:bat
the goodwill is my haunt.
move along nothing to see here.
MINE, MINE,
Nope the Goodwill is mine...  check out what I found at Goodwill:
http://forum.arcadecontrols.com/index.php?topic=94443.0
daywane
  • GRRRR!
:cry:
I am green.
pat47200
Update: A photo of the MVGS with 14 Compatibles Gamepads:
See you soon ;)
« Last Edit: December 15, 2010, 06:31:54 am by pat47200 »
MY WEB PAGE:
solidteezme
  • Last login:January 28, 2014, 08:01:48 am
  • Awesome!
This looks amazing,
I WANT ONE!!!  :applaud:
R0UNDEYEZ
  • Last login:March 16, 2015, 03:39:15 am
very nice collection you have there!   :applaud:  Only a couple I don't recognize in there,the one under the megadrive and the one on the top far right.
I'm actually in the process of doing something similar,except I didnt want to modify old gamepads ,so picked up a couple usb adapters for snes and n64 and plan to use the schematics here: http://www.raphnet.net/electronique/atari_usb/index_en.php to try and make the usb adapters for nes,atari 2600 and sega.
pat47200
Little Up!!!
Now 22 pads are compatible to the MVGS:
See you soon. ;)
MY WEB PAGE:
