Author Topic: Disable animated avatars  (Read 3064 times)
shmokes
  • Don't tread on me.
    • Jake Moses
« on: February 27, 2010, 04:26:05 pm »
Is it possible to disable animated avatars without disabling all avatars?  Every now and then I see one that is more or less acceptable, but about 95% of the time it's one like ark_ader's current with the scary clown thing that is quite possibly the dorkiest thing I have ever seen and having to see it looped just sort of makes me die a little inside.  Anyway, I don't want to disable avatars altogether, but I wouldn't mind hiding the animated gifs.  Is this possible?
Best Kid iPad Apps
Hoopz
  • Last login:January 24, 2026, 09:24:43 am
  • Intellivision Rocks!
Re: Disable animated avatars
« Reply #1 on: February 27, 2010, 06:01:35 pm »
Just hit the ESC key if it isn't possible to disable them. Short term solution.
shmokes
    • Jake Moses
« Reply #2 on: February 27, 2010, 06:23:35 pm »
That's a neat trick.  Thanks.
Best Kid iPad Apps
saint
  • turned to the Dark Side
  • Supreme Chancellor
  • Last login:Today at 02:55:41 pm
« Reply #3 on: February 27, 2010, 10:56:05 pm »
No way that I know of per individual user, esc is what I usually do.
--- John St.Clair
     Project Arcade 2!
     saint@arcadecontrols.com
Blanka
« Reply #4 on: February 28, 2010, 02:11:50 am »
With adblock you can right-click and disable a specific avatar
With Firefox you can change a setting in about:config that disables looping or playing at all of animated GIFs.
  1.  In the Location Bar type about:config and hit Enter
   2. Type "anim" in the Filter field (to quickly find the needed preference)
   3. Double-click the image.animation_mode line and edit it to one of the following:
        none — will prevent image animation
        once — will let the image animate once
        normal (default) — will allow it to play over and over
shmokes
    • Jake Moses
« Reply #5 on: February 28, 2010, 08:13:24 am »
Now we're talking!  I'm already running adblock.
Best Kid iPad Apps
ark_ader
  • I glow in the dark.
« Reply #6 on: March 07, 2010, 02:10:31 pm »
I should change my current one and replace it with a scarier one,but Saint would just make me delete it.... :cry:
