Author Topic: Anyone use 1/2" thick sides on fullsize cab?  (Read 4285 times)
Erik
« on: February 21, 2010, 08:16:01 pm »
Seen a few bartops but wondering if anyone has made a big cab with 1/2" plywood or mdf on the sides.  Thanks  :cheers:
t3design
  • Last login:January 02, 2026, 12:17:49 pm
  • Orange Power! Go Pokes!
    • Cowboy Arcade Project
Re: Anyone use 1/2" thick sides on fullsize cab?
« Reply #1 on: February 21, 2010, 08:30:40 pm »
I'm using 5/8" birch ply. Haven't built it yet though. I have a friend who is a cabinet maker and he is sure it is enough.
Cowboy Arcade Project ThreadCowboy Arcade Project Website
If you are an obsessive/compulsive pyromaniac, you better make sure you wear flame retardant pajamas.
Erik
« Reply #2 on: February 21, 2010, 09:15:02 pm »
I'm not so much concerned about the strength, just wondering if 1/2" looks odd
Epyx
  • "You're an oddity"
« Reply #3 on: February 21, 2010, 10:26:29 pm »
I have used 1/2" for certain parts of the cab but I wouldn't recommend it for the sides of a full upright.   You won't have as many choices for T Molding for one and you don't have as much depth for mounting your strips via screws.  1/2" works great for Bezels, Coin Doors, speaker shelves, back panels etc.
Last Project
Epyx Tutorials:
Tutorials
  • Last login:Yesterday at 12:10:15 pm
« Reply #4 on: February 22, 2010, 05:16:37 pm »
I would think that it would look disproportionate.  5/8" looks OK though (my DK is 5/8" and it looks great) but I like 3/4" best.
katrah
  • Last login:July 06, 2010, 12:07:20 am
« Reply #5 on: March 06, 2010, 10:49:32 pm »
Yeah ill be honest and say it will look cheap, the thicker the wood the more solid it will look, build it to last and it will bud  :cheers:
WhereEaglesDare
    • My HomePage
« Reply #6 on: March 09, 2010, 06:07:08 pm »
What size kind wood would you use for a bartop?  all I can find for MDF around here is the 3/4".  I think that it would be too heavy if portablity is what I want, and it is.
Epyx
« Reply #7 on: March 09, 2010, 06:55:49 pm »
For a bartop...5/8" for sides and 1/2" for back/speaker shelf/CP.  If you aren't going to laminate then go for 3/4" sides or 5/8" with appropriate T Molding size (5/8").
Most Home Depots carry 1/2", 5/8" and 3/4" MDF...have you tried them?
Last Project
Epyx Tutorials:
Tutorials
FlatEarth
  • Last login:September 14, 2021, 05:58:04 pm
« Reply #8 on: March 18, 2010, 03:10:34 pm »
You must have a lot better Home Depots around you.  In the northwest US (Seattle area, anyway) 5/8" is REALLY hard to come by.
Epyx
« Reply #9 on: March 18, 2010, 03:54:25 pm »
That is odd, considering im in the Pacific Northwest as well...albeit just above you in Vancouver, Canada :)
Every HD here has the 5/8"...its black laminate that HD here has discontinued :(
Last Project
Epyx Tutorials:
Tutorials
FlatEarth
« Reply #10 on: March 18, 2010, 04:02:08 pm »
You lucky Canadians!
I actually live in Tacoma, and I have called around to my local stores looking for 5/8" MDF with no luck.  I have pretty well resigned myself to using 3/4" for the sides of my cab and 1/2" for other parts, which should actually work fine.  It is not having the 5/8" for the CP that is trickier, since I cannot get the 3/4" final thickness including plexi without having 5/8" MDF.
Epyx
« Reply #11 on: March 18, 2010, 04:07:27 pm »
You could route the bottom of the 3/4" CP to 5/8"...since its the bottom it won't matter if you have some slight streaks of imperfection.  That way the top will be smooth and you can still have the T Molding flush with any plexi/laminate.
Last Project
Epyx Tutorials:
Tutorials
FlatEarth
« Reply #12 on: March 18, 2010, 04:18:18 pm »
That is a good idea, I had not thought of that.
My other thought is to use 3/4" and a CPO from mamemarquees.com and no plexi.  I understand their CPOs are pretty tough, and it is not like it will get really beat up through personal use in my basement.
TEKNYNE
« Reply #13 on: March 21, 2010, 04:51:58 pm »
Just a note for North Westerners, I am in WA state. Check for a Pro-Build (use to be Lumbermans) They are a northwest chain and typically have everything wood wise, or can get it within about 48 hours. And I am sure they are up there as I remember getting parts for work when I lived in Seattle.
From Walla Walla WA
TEKNYNE
250 Coupe
  • Newbie
  • Last login:September 27, 2011, 12:23:32 am
« Reply #14 on: May 11, 2010, 05:34:49 pm »
You might give Dunn Lumber a call, I don't have a Pierce County phone book handy and hate online phone lookups (for looking up lumber yards in Tacoma) but Dunn has a location a few miles North of me in Des Moines, (206) 241 0409.
My thoughts on 1/2" sides are that it would be out of proportion in a stand up but be OK in a bartop.
Michael
