Author Topic: Mounting 27" D9800 Advice  (Read 1347 times)
Batfink91
  • Last login:December 29, 2014, 02:32:33 pm
« on: December 09, 2009, 04:57:57 pm »
Can anyone give any advice on the best way to mount this monitor please? This is a link to my actual arcade cabinet built by Turnarcades which I am picking up on Saturday.  http://forum.arcadecontrols.com/index.php?topic=97544.0
Also, do you have to have glass installed over this monitor or is this just a personal preference thing?
isucamper
    • my project arcade blog
Re: Mounting 27" D9800 Advice
« Reply #1 on: December 09, 2009, 11:53:59 pm »
The best way is probably to get one of those adjustable arcade monitor mounts.  They attach to the sides of your cab and adjust to the size of your monitor.  Can't find a link just right now, but you should be able to find them with some searching.
I didn't know these existed, so I just glued and screwed wood supports to my cab and fastened the monitor to them.  Here's a pic showing the bottom 2 supports.  I also added two on the top in the same fashion.  Seems pretty solid to me.
http://i49.photobucket.com/albums/f298/isucamper/caba1.jpg
Glass is a personal preference.  You might want it for authenticity, but you'll even see a lot of cabs out in the wild that don't have any glass on them.
THE SYSTEM          Popeye
bigpete405
  • Last login:April 30, 2014, 07:48:03 pm
« Reply #2 on: December 27, 2009, 10:27:32 pm »
thats how I mounted mine. Hope it helps you a bit
