Author Topic: AtomicFE with HAPP trackball mouse buttons ?  (Read 1791 times)
Nataq
  • Last login:October 21, 2023, 09:09:45 am
  • Arcade of the dead... now alive!
« on: October 03, 2009, 11:51:03 pm »
Is there a way to use the trackball mouse buttons in AtomicFE ?
I had done the layout in AtomicFE and wired my control panel later with mouse buttons from the happ trackball for credit 1 and credit 2. Now I just found out that I cant use mouse buttons in AtomicFE after all the time I've spent doing the layout.
So, is there a way or I just have to use another front end ?
Help please!!
youki
  • Last login:October 12, 2025, 12:33:39 pm
  • Atomic Front End Creator
    • Atomic Front End
Re: AtomicFE with HAPP trackball mouse buttons ?
« Reply #1 on: October 05, 2009, 05:02:51 pm »
Hi,
Does the trackball is seen as a mouse by windows?
Or does you button are seen as keyboard key ?
did you try to go in the "control" menu of AtomicStudio , then "configure" and change button affectation?
If your button are view as windows joysticl button, you have to use utilities like "Xpadder" or "Joy2Key".
Nataq
« Reply #2 on: October 07, 2009, 08:58:21 pm »
Thank you for answering and sorry for the time it took to come back i've been very busy lately...
Finally, the issue was my lack of knowledge using mame... nothing to do with AtomicFE. My "mouse" (trackball) wasnt activated in my mame.ini file. I set it to 1 and everything worked.  :P My bad.
And since I've got your attention, thank you very much for AtomicFE. I'm discovering it more and more every day and I am very happy with it. Awesome work!!
youki
    • Atomic Front End
« Reply #3 on: October 08, 2009, 05:35:25 am »
Thanks a lot.
Yes, generally if you take time to invest in my FE , you discover how it is flexible and powerfull.
Even if , i admit, some point are not very easy to discover...  :-\
Nataq
« Reply #4 on: October 09, 2009, 09:26:21 am »
By the way, I registered on the name of Nataq on the ArcheoGamers forum but never got any confirmation or password to access it... It's been like 5 days. Are you the one that can grant me access ?  :)
Thank you
youki
    • Atomic Front End
« Reply #5 on: October 09, 2009, 09:34:34 am »
I'm going to mp you.
