Author Topic: hiscore.dat source code?  (Read 1496 times)
LeedsFan
« on: July 19, 2009, 02:26:04 pm »
I'm looking for Mame v.132 hiscore.dat source code. Is this available? I've been to the hiscore.dat website and I can only get the compiled v.132. Seems strange 'cos v.131 source is available.
I want to try my hand at this:
http://www.mameworld.info/ubbthreads/showthreaded.php?Cat=&Number=90849&page=0&view=expanded&sb=5&o=&fpart=1&vc=1
....... but of course I need the Mame.132 Hi-score.dat source. If I use the official Mame.132 code I will give up my Hi-score saves.
WedgeWood
  • Last login:May 08, 2019, 07:37:06 pm
  • ...thankyou Lars
Re: hiscore.dat source code?
« Reply #1 on: July 21, 2009, 09:34:48 pm »
Try here
http://forum.arcadecontrols.com/index.php?topic=64298.0
These diffs patch the official Mame release to add hi-score support in again, as well as a couple of other little tweaks that can be turned on/off in mame.ini
Once you've patched the Mame source with the hiscore diff, you can use that patched source to add the vertical bezel fiddle you mentioned.
I highly recommend Mr. Do's compiling Mame tutorial, also mentioned in the above thread.
Good luck!
Why finish building?  There's puzzles to be a-bobblin'!
