Author Topic: touch screen monitor  (Read 4394 times)
prezo1
  • Last login:February 28, 2020, 07:45:03 pm
« on: February 13, 2009, 06:24:43 pm »
i have bought a touch screen monitor to make a jukebox.i have set the screen up but when i touch it the cursor moves away from my finger,about 2"  to the right.i have downloaded the latest drivers for it and cleaned the screen.any ideas please.
it is a 3M 17 Inch MicroTouch Touch Screen LCD Flat Monitor
thanks
prezo
« Last Edit: February 13, 2009, 06:28:35 pm by prezo1 »
sarge
  • Last login:April 27, 2015, 01:42:54 pm
Re: touch screen monitor
« Reply #1 on: February 13, 2009, 06:35:07 pm »
Did you try to calibrate it???
prezo1
« Reply #2 on: February 14, 2009, 08:01:14 am »
yes i have tried on 2 and 4 corner calibration.
Kevin Mullins
    • Me on Myspace
« Reply #3 on: February 14, 2009, 09:55:56 am »
What model monitor is it ?
Are you running the 3M MT 7.12 drivers and utilities ?
http://www.touchscreens.com/support-drivers-microtouch.html
Try going into the MICROTOUCH CONTROL PANEL then TOOLS and RESETTING the controller.
And then re-calibrate.
There's always a chance it's just a bum screen too.
« Last Edit: May 01, 2010, 12:45:23 am by Kevin Mullins »
coinopman
  • Last login:June 09, 2009, 09:18:53 pm
« Reply #4 on: February 17, 2009, 09:57:46 pm »
make sure u have a good ground. place one hand on a known grounded metal area. then touch screen if it works properly then u have a ground issue.
shrunkenmaster
« Reply #5 on: April 30, 2010, 02:04:32 pm »
Having troubles too with a 3m touchscreen, just posted in the monitors forum - any answers?
lilshawn
« Reply #6 on: April 30, 2010, 03:39:01 pm »
not sure about the 3-m controllers, but the ELO ones have an advanced calibration. you have to touch the screen about 20 times all over but it works.
have a look through the programs and the options you may find something similar.
shrunkenmaster
« Reply #7 on: April 30, 2010, 03:53:59 pm »
hi lilshawn, I take it you don't mean trying ELO drivers instead? I've exhausted all the install/config options with the 3M drivers. Tried version 12 and 13 of the 3M drivers and the calib is still way off. Maybe I have a duff screen.
Franco B
« Reply #8 on: April 30, 2010, 04:06:32 pm »
Maybe you do have a faulty screen. I bought two 17" 3M Microtouch's, downloaded the drivers and it has worked fine on the first one I have tried. I haven't tried the second one though.
lilshawn
« Reply #9 on: April 30, 2010, 04:46:06 pm »
no, no... i j ust thought maybe they had the same type of thing.
try calibrating "small" IE if you get a target in the top left, come towards the middle of the screen about 1 inch. if you get a target in the bottom right side.. again come towards the middle... see if it works (even slighly)
Kevin Mullins
    • Me on Myspace
« Reply #10 on: April 30, 2010, 07:06:59 pm »
3M Control Panel -
Under  "Tools", click Advanced Options, Enable Manual Linearization.
A new tab with appear as "Controller..... click "Linearize".
This will start a much more detailed calibration process and accuracy test sequence.
grantspain
  • Last login:Yesterday at 10:50:37 am
« Reply #11 on: April 30, 2010, 07:20:09 pm »
someone mentioned ground earlier-this is very important
