Author Topic: U360 problem  (Read 1581 times)
Todd H
  • Last login:August 26, 2024, 02:23:32 pm
  • It's Gameday!
U360 problem
« on: December 28, 2008, 12:56:29 am »
Well crap. I just had one of the four metal spacers you use with the restrictor plates break off in the base of my U360. Is anybody else finding the screw holes a little hard to screw into? Three of them were easy enough that I could tighten by hand but one of them just seemed a little too tight. You can see the screw that has broken off in the top hole in the picture attached. Time to e-mail Andy I guess. :(
Edit: Looking at this link, looks like I'm not the only one having this problem.
http://forum.arcadecontrols.com/index.php?topic=78618.msg853807#msg853807
« Last Edit: December 28, 2008, 01:06:20 am by Todd H »
MajorHavoc
  • Last login:December 04, 2015, 09:08:40 am
Re: U360 problem
« Reply #1 on: December 28, 2008, 08:12:20 am »
Bummer!  I'll have to keep this issue in mind when I go to install restirctor plates on my U360.  Any chance you could easy-out the broken off stud and replace it with  a brass or nylon spacer?
Todd H
  • It's Gameday!
Re: U360 problem
« Reply #2 on: December 29, 2008, 07:12:35 am »
Can't say enough good things about Andy. He's sending me out the replacement parts to fix this.  :notworthy:
isucamper
    • my project arcade blog
Re: U360 problem
« Reply #3 on: December 29, 2008, 11:12:42 pm »
I had this exact same thing happen to me.  Andy shipped me a new base and spacers.  He also gave me the tip of using the white thumb nuts to screw in the spacers which worked a lot better than a pliers. :)
But yeah, installing those plates can be a huge pain in the butt and it's definitely not an exact science.
THE SYSTEM          Popeye
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
Re: U360 problem
« Reply #4 on: December 30, 2008, 12:05:35 am »
We had someone screw in all the pillars we have in stock, into a base to make sure the threads were OK, before sending out. (probably one of the most boring tasks ever!)  They used the thumb-nut as the instructions state.
So I am not sure why this happened again. Maybe we will need to change to a different, harder alloy.
New parts will be on the way anyway.
Andy
