Author Topic: how many nova matrixs?  (Read 2218 times)
ivwshane
    • My first mame cab! (WIP)
« on: November 12, 2008, 08:09:11 pm »
My marquee area is roughly 8.5"x30" and I'm looking for something that will light it evenly.
My thinking is two side by side but is that too many or not enough?
Does anyone have some pics with one or two in their cab?
ivwshane
Re: how many nova matrixs?
« Reply #1 on: November 13, 2008, 05:00:25 pm »
No one uses this product?
« Reply #2 on: November 13, 2008, 05:06:03 pm »
Before I would buy 2 of those and use them, I'd use a fluorescent light fixture.
paulscade
  • Last login:December 26, 2022, 09:40:35 pm
    • My Arcade Project - Blastoff!
« Reply #3 on: November 13, 2008, 05:06:16 pm »
I'm using one... but unfortunately, I can't comment too much as the marquee is the only thing missing from my project:
http://forum.arcadecontrols.com/index.php?topic=82241.msg875391#msg875391
I have the UAII cabinet... at 25" wide.  The NovaMatrix is mounted in the center about 10" back from the marquee.
The light seems bright enough and I figured that at 10" back, I wouldn't have any hot spots.
We'll see once I get a marquee.
I think that at 30" wide... you might want to use two.
... Why is it that you always find it in the last place that you look? ...
vizzinni
  • Last login:November 03, 2024, 08:52:08 am
  • Inconceivable
« Reply #4 on: November 13, 2008, 07:12:17 pm »
I used one, but I should've used two, and mine is only 19.5" wide.  In a dark room the light is adequate, but just barely.  But, it's cool, easy to install, and will last forever.
http://forum.arcadecontrols.com/index.php?topic=81238.msg850046#msg850046
tomdotcom
  • Last login:March 05, 2014, 11:55:56 pm
« Reply #5 on: November 13, 2008, 07:21:37 pm »
I used adjustable angle flourescents in my neo cab from our local light store. They are actually under cabinet lights for kitchens and stuff like that. They can be hard wired or use standard plugs. Worked like a charm.
=-= Pins: Fishtales, Bram Stoker's Dracula, Revenge from Mars, Skateball =-=
=-= Custom Mame cab =-=
ivwshane
« Reply #6 on: November 13, 2008, 11:58:06 pm »
Thanks for the info.
How far back did you have it from the marquee?
I don't want to go florescent mainly because of space issues and I just want something maintenance free.
tomdotcom
« Reply #7 on: November 14, 2008, 12:19:08 am »
I'd guess they are about approx 4-6 inchesback from the marquees..you can see pics on my neo geo restoration topic..there are two of them in mine..
« Last Edit: November 14, 2008, 12:22:05 am by tomdotcom »
tomdotcom
« Reply #8 on: November 14, 2008, 12:21:23 am »
edit double post oops
vizzinni
  • Inconceivable
« Reply #9 on: November 14, 2008, 08:57:24 pm »
It's mounted about 8" back from the marquee. and a little higher than center vertically (I had to get over the speakers).   I played around with different positions, adjusting for the output angle, and that seemed to work the best.
ahofle
    • Arcade Ambience Project
« Reply #10 on: November 15, 2008, 12:57:13 am »
Do people really have to maintain their fluorescent marquee fixtures that often?  I've had a cheapo $7 one behind my marquee for over 5 years now with no problems.  I've heard people here saying they burn out constantly.  Maybe I just got lucky?  :dunno
tomdotcom
« Reply #11 on: November 15, 2008, 01:00:11 am »
Even if mine did burn out they are easily accessible on the neo cab because the whole top of the cabinet opens up from the front. I really don't think it's much of an issue unless you have to take apart alot of your cab just to get at them.
« Reply #12 on: November 16, 2008, 01:06:26 am »
I use one in mine and it looks great.
Check out this video here on "How to install a marquee".  You'll see it there.
http://forum.arcadecontrols.com/index.php?topic=80229.0
Also, here's a pic of it with the lights off:
Works great for me.
~ DeLuSioNaL
ivwshane
« Reply #13 on: November 16, 2008, 02:35:57 am »
Thanks delusional. How wide is your cab?
« Reply #14 on: November 16, 2008, 05:35:05 pm »
I'm housing a Betson 27" arcade monitor in there.  I managed to squeeze it into a 25" cab.  I don't know the exact measurements of the cab itself, but the monitor is 235" wide.
The marquee's dimensions are 24.5" x 7.75".
~ D
