Author Topic: soft15khz*****SOLVED****  (Read 3555 times)
Nemss316
  • Last login:April 28, 2010, 10:30:00 am
« on: October 31, 2008, 02:11:38 pm »
Ok, so I downloaded Soft15KHz last night to verify it works, and I know it works. Problem is, now I can't get my LCD to show the screen, so I need to take Soft15Khz off. I'm assuming by using Windows Safe mode, I can do this, correct?
« Last Edit: October 31, 2008, 02:58:38 pm by Nemss316 »
Nemss316
Re: soft15khz
« Reply #1 on: October 31, 2008, 02:34:52 pm »
Nevermind, I just booted to safe mode, and removed the drivers. Now I'll just reload the drivers I had.
Epyx
  • "You're an oddity"
Re: soft15khz*****SOLVED****
« Reply #2 on: November 01, 2008, 12:46:11 am »
This stung me the other day too...all of a sudden my lcd was going into power saving mode in WIndows...removed soft15khz and drivers in safe mode and good to go.
Last Project
Epyx Tutorials:
Tutorials
« Reply #3 on: November 01, 2008, 09:04:10 am »
thats because Soft15 is used to run the computer to an arcade monitor not your desktop LCD
SirPeale
  • Green Mountain Man
« Reply #4 on: November 01, 2008, 09:16:11 am »
I think he tested it with an arcade monitor, but then switched back to the LCD but didn't remove it first.  At least that's the gist I'm getting.
Epyx
« Reply #5 on: November 03, 2008, 07:16:01 pm »
Was using it with my tv before I realized that Soft15khz only works with SCART tvs/Monitors not our NTSC ones.
Last Project
Epyx Tutorials:
Tutorials
