Author Topic: Wells Gardner SUCKS !  (Read 4810 times)
Level42
« on: August 04, 2008, 01:31:57 am »
I just wanted to say that the quality of Wells Gardners 6100 PCB's S-U-C-K-S  !!!!!
I've never worked on a worse piece of ---steaming pile of meadow muffin--- than this.
I don't know where they got their PCB's from but the solder won't flow and the soldering islands/tracks come off like nothing.
Wells Gardner=HELL, Amplifone=HEAVEN.
pfff, had to get thet out. Sorry guys :)
DJ Infinity
  • Last login:January 19, 2012, 03:48:16 pm
Re: Wells Gardner SUCKS !
« Reply #1 on: August 09, 2008, 11:47:32 pm »
If You Are Going To Meddle At Least Listen
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #2 on: August 11, 2008, 05:58:51 pm »
wonder if they are using that Pb free solder . it has a higher melting temp (ave +50 F) than leaded solder.
so, set tip temp around 700 F ....  and the stuff is prone to splash when over heated (>850 F)
and overheating WILL lift pads . so, be quick   ;)
qrz
qrz
Rickn
  • Last login:May 08, 2020, 01:32:28 pm
« Reply #3 on: August 11, 2008, 07:35:20 pm »
Yes if they are using lead free solder it requires more heat... yeah just what you needed more heat... more lifted foils and traces.
RickN
Always happy to help.., for the best in displays
Rick Nieman
Rick@Niemandisplays.com
www.niemandisplays.com
1023 Rife Rd Cambridge, Ontario Canada N1R5S3
519-621-1722
MonMotha
« Reply #4 on: August 11, 2008, 07:43:01 pm »
Doesn't help that these are always cheap-o phenolic boards usually with non-plated holes and cheap soldermask.  At the temps required for Pb-Free solder reflow, the darn boards will start to delaminate, so it's no surprise that traces fall off.  Really, almost all monitors have this problem to an extent, but WG also seems to have a terrible waves soldering process that leaves cold joints everywhere requiring lots of rework.  Perhaps they just chucked Pb-Free solder in the pot without resetting anything?
A temp controlled iron is almost mandatory for reworking phenolic boards with Pb-free solder.  Don't bother with your $5 Radio Shack.
Oh yeah, boo lead free solder.  Just don't eat the leaded stuff, and you'll be fine. :)
Minimum I've found to re-work Pb-Free is 325C.  350C works better.  Issue is that at the lower temps, you sometimes have to keep the heat on so long that the board and surrounding surfaces heat up too much.  At higher temps, the immediate area gets too hot and falls apart.  It's much easier to find a balance with leaded stuff.
You can flow in some leaded solder sometimes to lower the melting point as you're working.  This can help out if you need to re-work the same area repeatedly as it lets you use cooler temps for the later passes.  Problem is that you can end up with lots of flux residue or just plain too much solder.
For the monitor guys: any reason they don't use FR-4 in monitors?  It stands up to heat way better.  Just a cost issue?  If so, why do people care to save maybe a buck on what are sometimes $1000+ monitors?
ahofle
    • Arcade Ambience Project
« Reply #5 on: August 12, 2008, 02:51:23 pm »
I highly doubt they used Pb-free solder in a 20+ year old vector monitor.  :laugh2:
ahofle
« Reply #6 on: August 12, 2008, 02:55:57 pm »
While on the topic of WG, what is going on with their website?  I get warnings from google about it being an unsafe site with malicious file downloads!  Google 'wells gardner' and then click on the company website (should be first match).
http://www.google.com/safebrowsing/diagnostic?site=http://www.wellsgardner.com/
"Warning - visiting this web site may harm your computer!"
Ummon
  • Trade Count: (+13)
« Reply #7 on: August 12, 2008, 04:58:47 pm »
I just went there and don't get this...although, I get apparently something similar visiting the Daphne forums. Owenby explained that he didn't have the funds to get a Win license of some sort, so IE flags it. If you're using Firefox, might be something else.
« Last Edit: August 12, 2008, 05:05:47 pm by Ummon »
Yo. Chocolate.
Stephen Hawking
ahofle
« Reply #8 on: August 12, 2008, 05:11:23 pm »
Well you have to go there from a google search result link (ie. don't type the URL in).
Ummon
« Reply #9 on: August 14, 2008, 05:02:32 pm »
I see. Take this google result, for example; search term was 'wells-gardner'. The first link (which is wgec.com) works fine. Goes righ to WG. The second link, which says wells-gardner in it, does what you say.
http://www.google.com/search?q=wells-gardner&rls=com.microsoft:en-us:IE-SearchBox&ie=UTF-8&oe=UTF-8&sourceid=ie7&rlz=1I7ADBF
Yo. Chocolate.
Stephen Hawking
mewyn
  • Last login:September 23, 2008, 11:16:06 pm
« Reply #10 on: August 14, 2008, 08:10:51 pm »
I think at one time their site was compromised and their admin needs to contact google to get them off the safe browsing blacklist.  This will only happen if you're using FF3 with safe browsing enabled, or a plugin for other browsers.
Level42
« Reply #11 on: August 24, 2008, 05:14:18 am »
Yeah, I was talking about the "old" Wells-Garder from the golden age.
Here's a picture to further prove my point:
A big resistor, simply NOT soldered !!! Nothing ever touched this !!! I bet this WG 6100 neckboard was NOS because I can't believe that it "just" made contact for 25 years.
So I thought this would fix the problem, soldered it, only to discover yet ANOTHER contact problem with the wiring somewhere on that print. Still have to find out where, but I guess I'm just going to shotgun it and re-solder ALL wires......sigh.....
Ken Layton
  • Guru
  • Technician
« Reply #12 on: August 24, 2008, 12:55:37 pm »
Umm.....I got news for you. Wells still hasn't fixed their soldering problems.
Ummon
« Reply #13 on: August 24, 2008, 07:37:04 pm »
On all models, multisyncs included?
Yo. Chocolate.
Stephen Hawking
smartbomb2084
  • Last login:January 13, 2021, 03:14:53 pm
  • Having a SMART phone will make you DUMB.
« Reply #14 on: August 24, 2008, 11:08:44 pm »
As far as lifted traces go... how come nobody has mentioned the age old trick of mixing  aftermarket solder with the factory hard solder to make parts more easliy removeable?  I do this to EVERY solder joint whether installing cap kits or changing other parts and have had only a few lifted solder pads on WG monitors.
I think the bad lead free solder rap is just a cover-up for poor soldering skills.  'nuff said.
Ken Layton
  • Guru
  • Technician
« Reply #15 on: August 25, 2008, 10:17:15 am »
Lead free solder requires MORE heat. Just what foil traces don't need is more heat to cause lifting.
MonMotha
« Reply #16 on: August 25, 2008, 12:53:19 pm »
Mentioned in a lead-free context, but same idea.
And yes, lead-free sucks.  You have to get it hotter, causing lifted traces or even delamination of cheaper PCBs (like those commonly used in monitors).  It can grow tin whiskers.  The flux is NASTY stuff that some argue is worse for assembly in terms of health risk than all the exposure to lead ever was.  It's not quite as much of a disposal concern, but I sure hate working with it.  Lead at least is just a matter of "wash your hands and try not to breath the fumes too badly".  The Pb-free flux fumes are downright foul in many cases.  I'm fairly proficient at soldering (if it has leads, chances are I can get it soldered, and I can do some leadless packages, too), and I hate the lead free crap.  Yes, better soldering skills can help, but it's just plain harder to work with.  I *can* solder lead-free, but I don't like to.  It seems that many are in agreement here...
I'd still like to know why all monitor PCBs are that cheap phenolic material when FR-4 (or other higher temp laminates in the same family) stands up to heat so much better.
Jeff AMN
    • Gamer Theory
« Reply #17 on: August 25, 2008, 01:02:53 pm »
Hmm, I don't know. I've been soldering for a very long time and the lead-free crap irritates me. I just don't like the amount of heat I need to have going to get it to flow.
smartbomb2084
« Reply #18 on: August 27, 2008, 01:04:18 am »
Beat down lead free solder all you want people...  What's harder to work with than 1980's Williams' solder?  Have you ever tried removing a 7489 RAM from a ROBOTRON CPU board?
Level42
« Reply #19 on: August 29, 2008, 08:18:53 am »
No need to work on Williams' ---steaming pile of meadow muffin--- anymore:
http://forum.arcadecontrols.com/index.php?topic=83897.0
