Author Topic: Cutting slots for T molding  (Read 3241 times)
Boingo
  • Last login:March 14, 2014, 09:13:41 pm
« on: July 23, 2008, 10:10:18 am »
I presume cutting the slots for T molding would require a router, but I need to know what kind of bit, and where that kind of bit can be obtained.  Presumably, it would not be available at the local Home Depot, since T molding is no longer commonly used.
Any info would be much appreciated.
  • Last login:Today at 03:49:32 pm
Re: Cutting slots for T molding
« Reply #1 on: July 23, 2008, 10:14:33 am »
1/16" 3-wing slot cutting bit.  I ordered mine from MLCS.
Chadwick
  • Last login:January 11, 2010, 03:23:34 pm
« Reply #2 on: July 23, 2008, 02:34:45 pm »
When buying a slot cutter, you have 2 choices to make.
1)  Kerf size (1/16" for your needs)
2) arbor size (usually 1/4" or 1/2", some manufacturers offer 3/8" as well).
You need 3 parts for a complete assy.
1) the slot cutter - almost always 1-7/8" diameter
2) the bearing - almost always 7/8" diameter, giving you 1/2" depth of cut
3) the arbor - almost always comes with a few washers and a lock-nut on the end.
If you're ordering online, I suggest you get one arbor, one bearing, and 2 or 3 cutters.  There isn't a lot of braze holding that 1/16" piece of carbide on the end of the cutter and it doesn't take much effort to trash your tiny carbide tips.  They aren't that expensive and you don't want to pay for shipping one little cutter if you wreck your first one before you complete your project.
paulscade
  • Last login:December 26, 2022, 09:40:35 pm
    • My Arcade Project - Blastoff!
« Reply #3 on: July 23, 2008, 05:10:29 pm »
I bought my 1/16" kerf, 1/4" arbor slot cutter at Lowes (here in South Florida).  Since you mentioned Home Depot, I thought I'd post.  I lucked out... it was on the discount rack for $8.  Such a deal!
... Why is it that you always find it in the last place that you look? ...
ratzz
« Reply #4 on: August 14, 2008, 04:31:05 pm »
Here is another pretty good resource...
http://www.t-molding.com/store/home.php
This is where I'm going (eventually!) ...
Paulson
  • Last login:January 29, 2015, 06:55:37 am
« Reply #5 on: August 14, 2008, 05:28:05 pm »
 I have mine on order...it's been a week since I ordered...with 25 feet
 of chrome T-molding...they have a special price cause they get orders
 from people building poker tables who require 25 feet.
