Author Topic: Mame is not letting me change the resolution to 640x480.  (Read 4973 times)
Timstuff
  • Last login:April 16, 2014, 02:24:29 am
  • I feel asleep !!
« on: July 11, 2008, 01:18:40 pm »
For some dumb reason, I don't think the latest versions of Mame will let me run in 640x480, even if I change the .ini file. Instead, it runs games at 800x600, and then scales it down to fit my TV's screen. This is a huge pain, since it also means that overscan correction is turned off while the game is running, which caused the top and bottom of the screen to get lopped off.
I also have Mame32 .105 on this computer, and games have no problem at all running at 640x480 on it. I don't recall trouble with Mame .125 either, but it had a whole host of other problems that made it more or less unusable for me. Mame 124 defaulted to 800x600 too, and I couldn't change it there either.
Am I editing the .ini file incorrectly, or have recent versions of Mame just been very buggy when it comes to resolutions? Which version of Mame should I be using to avoid having resolution problems and still have a good amount of game support?
ahofle
    • Arcade Ambience Project
Re: Mame is not letting me change the resolution to 640x480.
« Reply #1 on: July 11, 2008, 04:23:39 pm »
Do you have 'switchres' set to 1 in mame.ini?  If not, you should.
