Author Topic: iTS THERE A WAY TO BYPASS THE (ITS NOW SAFE TO TURN OFF PC)  (Read 2433 times)
Denverlatino
  • ---Buyer Beware - transactions with this user are in dispute--- ... Banned ...
  • Last login:May 13, 2009, 02:55:24 pm
« on: April 15, 2008, 09:11:26 pm »
iM SETTING UP AND OLD PC DEDICATED TO MAME, EVERYTHING LOOKS GOOD ECEPT FOR  WHEN I TURN THE PC OFF I HAVE TO WAIT FOR THE , ITS NOW SAFE TO TURN OFF YOUR COMPUTER. dOES ANYONE KNOWS HOW TO TURN THIS OFF SO THE COMPUTER TURNS OFF BY ITSELF? THANKS :cheers:
[transactions in dispute -- see http://forum.arcadecontrols.com/index.php?topic=77030.0]
... Banned ...
  • Last login:May 30, 2026, 12:00:14 pm
Re: iTS THERE A WAY TO BYPASS THE (ITS NOW SAFE TO TURN OFF PC)
« Reply #1 on: April 15, 2008, 09:18:03 pm »
You will have to have an ATX type power supply.
If you have the older AT style then I dont think you can do it.
When you turn it on, is it a pushbutton or on/off switch?
Denverlatino
« Reply #2 on: April 15, 2008, 09:30:09 pm »
Its a pushbutton, too bad then
... Banned ...
gonzo90017
« Reply #3 on: April 16, 2008, 01:08:13 am »
I think there might be a way:
If the computer is not ACPI-compliant, you may be able to work around this issue by installing the NT APM/Legacy Device. Before you install the NT APM/Legacy device, you must first disable the Microsoft ACPI Device if it is installed.
To disable the Microsoft ACPI Device: 1.   Open Control Panel, and then double-click System.
2.   Click the Hardware tab, and then click Device Manager.
3.   On the View menu, click Show Hidden Devices.
4.   Expand Non-Plug and Play Drivers.
5.   Do either of the following:    •   If Microsoft ACPI Driver is not listed:
In the NT APM/Legacy Support branch of the device tree, you will see the item NT Apm/Legacy Interface Node. It will show a red X to indicate that it is disabled.
Right-click NT Apm/Legacy Interface Node, and then click Enable.
After you follow these steps, Windows will shut down correctly.
•   If Microsoft ACPI Driver is listed, follow these steps:    a.    Double-click Microsoft ACPI Driver.
b.    Click the Driver tab, and then in the Type box, click Disabled.
c.    Click OK, and then restart the computer.
d.    When Windows restarts, repeat these steps to open the Microsoft ACPI Driver Properties dialog box, and then click the Driver tab.
Verify the following:    •   Disabled appears in the Type box.
•   Stopped appears in the Status section.
After you verify that the Microsoft ACPI Device is disabled, continue with the following steps to install the NT APM/Legacy device:
e.    Open Control Panel, and then double-click Add Hardware.
f.    When the Hardware Wizard stops searching for new hardware, click Yes, I have already connected the hardware, and then click Next.
g.    Scroll to the bottom of the Installed Hardware list, click Add a new hardware device, and then click Next.
h.    Click Install the hardware that I manually select from a list (Advanced), and then click Next.
i.    Under Common Hardware Types, click NT Apm/Legacy Support, and then click Next.
j.    Click NT Apm/Legacy Interface Node, and then click Next.
k.    Click Next again, and then click Finish.
The computer will now correctly shut down.
Denverlatino
« Reply #4 on: April 17, 2008, 07:10:03 pm »
Wow sounds a bit to advance for me but not hard, ill post results on this, thanks allot for your help.  :cheers:
... Banned ...
Denverlatino
« Reply #5 on: April 18, 2008, 09:20:23 pm »
It work , thanks allot.  :cheers:
... Banned ...
Ummon
  • Trade Count: (+13)
« Reply #6 on: April 20, 2008, 06:14:48 pm »
I'm assuming Denverlatino is using XP here. I have a win98 computer that has a regular push button, but does the 'okay, you can turn off now' thing. Is there a way to do auto-shutdown on this?
« Last Edit: April 20, 2008, 06:18:04 pm by Ummon »
Yo. Chocolate.
Stephen Hawking
