Author Topic: mame with MameWah scanlines help  (Read 4975 times)
ablizno
  • Last login:August 15, 2011, 09:04:29 pm
  • [insert text here]
« on: April 14, 2008, 06:15:20 pm »
How do i use scanlines in MameWah i've been searching online and in the forums. I understand that i have to do something along the lines of :
mame -effect scanlines
but i have no idea what this means.
creatine28
  • Last login:July 26, 2012, 03:41:48 pm
  • Which way to the Arcade?
Re: mame with MameWah scanlines help
« Reply #1 on: April 14, 2008, 07:48:40 pm »
Just went through the same issue when I was setting up Mamewah.
In the your mame directory(Not mamewah) just edit the mame.ini and enter the words         scanlines           next to the option for effects.
Effects                  scanlines
# WINDOWS VIDEO OPTIONS
# use d3d or ddraw
video                          d3d
numscreens                1
window                       0
maximize                    1
keepaspect                1
prescale                     1
effect                          scanlines
waitvsync                  0
syncrefresh                0
« Last Edit: April 15, 2008, 01:02:44 am by creatine28 »
ablizno
« Reply #2 on: April 14, 2008, 09:51:51 pm »
Actually that didnt work... that whole section is missing from my mame.ini this is what mine looks like:
### mame.ini (mamewah v1.62) ###
emulator_title                            Arcade
### List Generation Settings ###
rom_path                                  C:\mamewah\config\mame\roms
rom_extension                             zip
dat_file
nms_file
catver_ini_file                           C:\mamewah\config\mame\catver.ini
list_generation_method                    rom_folder_vs_listxml
### Execution Settings ###
pre_emulator_app_commandlines
emulator_commandline                      C:\mamewah\config\mame\mame.exe [name]{nodosbox}{nosafelaunch}
post_emulator_app_commandlines
general_app_commandlines
### Artwork Settings ###
artwork_image_paths                       C:\mamewah\config\mame\snap
movie_preview_path                        C:\mamewah\config\mame\previews
movie_artwork_no                          1
enable_fuzzy_search                       0
history_dat_file
history_dat_artwork_no                    2
### Screen-Saver Settings ###
enable_music_in_screensaver               1
select_random_game                        0
saver_type                                gamelist_slideshow
movie_path
movie_fullscreen                          1
quit_delay                                0
saver_commandline
### Additional Settings ###
music_path
lcd_display_file_path
description_display                       [description]{scroll}
### Settings used by MAMEWAH ###
current_list                              0
« Last Edit: May 01, 2008, 12:28:52 am by ablizno »
ablizno
« Reply #3 on: May 01, 2008, 08:53:26 am »
nobody knows?
Ginsu Victim
  • Comanche, OK -- USA
« Reply #4 on: May 01, 2008, 09:34:27 am »
I know one thing...
You can't follow directions.
This means the program M.A.M.E., not the mame folder in mamewah.
« Last Edit: May 01, 2008, 09:37:00 am by GinsuVictim »
ablizno
« Reply #5 on: May 01, 2008, 11:07:54 am »
since i extracted mame into my mamewah directroy there is only one mame.ini, i will start from scratch and do something different and see if i can figure it out.
« Last Edit: May 01, 2008, 11:13:12 am by ablizno »
ablizno
« Reply #6 on: May 01, 2008, 11:22:13 am »
Upon extracting mame to its own directory i see no file titled "mame.ini"
Ginsu Victim
« Reply #7 on: May 01, 2008, 11:23:16 am »
try running it first. It will make one.
ablizno
« Reply #8 on: May 01, 2008, 11:27:05 am »
i ran it and it said it cant find roms and it crated the cfg folder. inside of that folder is default.cfg and empty.cfg the documentation said to type "-createconfig /-cc" to create the mame.ini file but when do i type that, this is really confusing.
Ginsu Victim
« Reply #9 on: May 01, 2008, 11:31:08 am »
So there's no INI file of any sort in your root Mame folder?
ablizno
« Reply #10 on: May 01, 2008, 11:32:20 am »
there is no ini file anywhere
Ginsu Victim
« Reply #11 on: May 01, 2008, 11:35:21 am »
I'm not at home, so I don't have it in front of me to help.
What version / build of MAME are you running?
« Last Edit: May 01, 2008, 11:47:54 am by GinsuVictim »
ablizno
« Reply #12 on: May 01, 2008, 10:41:47 pm »
I am using .124a
Onji
  • Last login:December 20, 2024, 05:31:43 pm
« Reply #13 on: May 01, 2008, 10:54:27 pm »
just goto dos, goto your mame directory and type
mame -cc
and hit enter
that should create the mame.ini for you
ablizno
« Reply #14 on: May 02, 2008, 07:23:07 pm »
Ok do to a sound problem i switched to fastmame 84 and it works wonderful. But here is the problem i have both a fastmame.ini and mame.ini i set both of them to scanlines 1 and it still didnt display scanlines. Yes there is the scanlines file in the artwork folder.
