Author Topic: 25" Pentranic model 1125 differet shades of black strips?  (Read 2066 times)
Mauzy
« on: January 24, 2008, 08:53:21 pm »
Hey everybody. Yes, I have another monitor problem. Luckily, this one isn't crippling.
I have a Pentranic monitor (Model 1125) that was manufactured in August of 97, and I have noticed that there are strips of varying shades of black/gray running vertically with one jet black streak going down the left side. These streaks/strips only appear on black screens; color works and looks great. Ive messed with the adjustments a good amount, and the only way to not see the strips is to turn the brightness way low.
I wouldn't think that the monitor is old enough for the caps to go bad, but it wouldn't surprise me. What would should I look for?
BTW, Remember to beware the "unbeatable?" pterodactyl...
rockin_rick
  • Last login:May 27, 2017, 09:20:20 am
Re: 25" Pentranic model 1125 differet shades of black strips?
« Reply #1 on: January 24, 2008, 11:04:47 pm »
I believe that those are jailbars and that they are typically cause by bad caps.  I would do a cap kit on it.  There are other monitors (like the Polo) that go through caps fast, so it's not unheard of.
If I do not respond to your post in a timely manner, feel free to PM me.
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #2 on: January 24, 2008, 11:52:29 pm »
it is indeed "jailbars" . the most common failure is of the rgb boost cap . typically 10uF @ 250v.
that failure may include a dark pic left, ranging to bright w/retrace on right.
in this instance , there may well be a faulty cap on a flyback secondary ( scan derived supply )
likely on a 15v source .....
qrz
Mauzy
« Reply #3 on: January 25, 2008, 04:28:15 pm »
So should I do an entire cap kit, or should I just do the one? I guess while I have it off and discharged I should do them all, but I'm not sure...
grantspain
  • Last login:Today at 03:36:41 am
« Reply #4 on: January 25, 2008, 05:04:13 pm »
depends on the chassis but usually find that cap on the neck card,others you find near the flyback transformer
