Author Topic: TinyXP on laptop?  (Read 2877 times)
LeedsFan
TinyXP on laptop?
« on: January 21, 2008, 04:49:27 am »
I'm interested in using TinyXP on a bartop project using an old IBM Thinkpad 240. Everything about the TinyXP software looks great... except for one thing. I read that TinyXP is not suitable for laptops because there is no built in hardware support for laptop batteries. However I have no plans to use the rechargeable battery at all. I will be running the bartop from mains power at all times. Does this make any difference?
Seems a shame if TinyXP cannot be used on old lappies because these old machnes would benefit greatly from it.  :dunno
I just want to run vertical classics through MaLa with a U360 and two buttons. I hear that you get various options on installing TinyXP with/without drivers and IE etc. Sounds like just what I need really. :)
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
Re: TinyXP on laptop?
« Reply #1 on: January 21, 2008, 09:01:22 am »
I've just started using TinyXP and think it's cool. Not sure about laptop use but the only problem I found is even when I install graphics drivers, it will not allow me to display any larger than 640x480. I only want to go to 800x600 for a bit of smoothness but it doesn't want to play.
Ritalin
  • Last login:May 07, 2015, 12:25:39 am
« Reply #2 on: January 21, 2008, 03:31:37 pm »
I have TinyXP running on an old laptop and it works great.
My laptop is a Toshiba Satellite 2805-S202 with only 128MB or RAM (PIII @ 698 Mhz)
Performance with MAME is outstanding.
Even for more complex games likes Alien vs. Predator, etc.
TeutonicDarkness
  • Last login:July 16, 2019, 10:54:16 pm
« Reply #3 on: January 21, 2008, 08:04:33 pm »
 Works great here no problems with battery/power.
I can use any resolution plays every Game I have tried
so far.
I took a miniature wireless keypad and use it as a remote to
navigate the Menus in Mamewah.....
Its a blast Tiny XP is just Awesome for my Laptop/Game console
thingy....
Give it a shot....
*** Teutonic Darkness ***
govee
  • Last login:February 19, 2012, 09:26:30 pm
« Reply #4 on: January 25, 2008, 12:02:27 am »
Which TinyXP? I run Beast and Platinumon a 1.8ghz celeron toshiba and both work well. Platinum is a lot heavier but provides more resources out of the boxand includes DHCP so you actually get the IP assigned which allows P2P to run faster.
TeutonicDarkness
« Reply #5 on: January 25, 2008, 10:19:15 pm »
 Well if you need Internet use TinyXP version 2,
If not and you just want to use it as a Gamebox
use TinyXP Version 1.
Myself I use TinyXP 1 on my laptop.
Think I might have 3-4 processes running in
background needless to say ....its really fast!
I take care of all my internet needs on my Non-Gaming system.
Also make sure if you use a (TinyXP)
make sure it was put together by experience
a lot of others claim to be tinyxp but where put together
by someone else.
Alternatively you could also do it yourself:
http://www.nliteos.com/nlite.html
Hope that helps...
