Author Topic: Wanted: Joystick Port Sparepart for Atari 800XL  (Read 1845 times)
Luigi
  • Collecting/restoring cabs
« on: September 26, 2007, 01:15:42 am »
Hi.
Sure I know: this has nothing to do with arcade :)
I saved an Atari 800XL from the dump (complete with Datasette and 1050 Floppy). It had a keyboard issue the letter U was permantly printed on the screen without pressing the key. I could fix this but there is another problem. Due to the missing first pin in the joystick port 1 Player 1 cannot move up (see picture).
I've been searching in germany for the right part but could not find it. Do you know a source where I can get an (almost) original sparepart or at least something that looks similiar?
Would be great.....thanks :)
bleargh
  • Last login:Yesterday at 12:17:05 pm
  • ribbit...
Re: Wanted: Joystick Port Sparepart for Atari 800XL
« Reply #1 on: September 26, 2007, 01:35:05 am »
Aren't those just 9-pin DIN connectors?
Been a while since I've seen one from the front, but they do remind me of DINs...
Luigi
« Reply #2 on: September 26, 2007, 01:39:14 am »
Yes, they are :)
And I've found a sparepart but it's far away from looking like the originals and before I do this I will continue my search for something that might look more like it should :)
boykster
  • The cake is a lie!
« Reply #3 on: September 26, 2007, 01:50:02 am »
I doubt you'll find an oem replacement part, but you should be able to use pretty much any 9-pin d-sub male connector.  Its <possible> a PCB style right angle plug will fit right in....
http://www.action-electronics.com/computerconnectors.htm#Pcb
DRB-9PR is the part # you want
Luigi
« Reply #4 on: September 26, 2007, 02:20:35 am »
I'm afraid you're right. But I will replace both ports so they look equal.
I found something that looks pretty much like the original.
I guess I'll have to take a closer look at the mainboard
« Reply #5 on: September 26, 2007, 08:45:20 am »
I just Freecycled two Atari computers... wish this request had been two weeks earlier.
Luigi
« Reply #6 on: September 27, 2007, 06:59:43 am »
That's life  :)
 :cry:
Thenasty
  • Trade Count: (+17)
  • Last login:January 25, 2026, 04:03:57 pm
« Reply #7 on: September 27, 2007, 08:15:41 am »
aren't the SERIAL PORTS on PC the same. Use those... Not he 25 pin but the 9 pin.
Free VGA Breakout Cable
boykster
« Reply #8 on: September 27, 2007, 01:37:54 pm »
that's what a 9pin male pcb mount connector is....see pic above.
Good call though.... ;)
Dervacumen
  • Last login:June 12, 2024, 01:58:21 am
  • Home of Three Squares dice game
    • Beaker Games
« Reply #9 on: September 27, 2007, 08:45:06 pm »
Check out Atari Age Forums.  I'll bet someone has a part they would ...ahm...part with.
I recently offed my entire Atari 8-bit collection to a member there.  No 800XL stuff but plenty of 800 parts.  There's got to be lots of parts, or leads there.
Bringing to life a child's imagination.
Luigi
« Reply #10 on: October 01, 2007, 03:00:39 am »
Thanks for your hints.
There's a german Atari forum and I will get a burned  :dizzy:  mainboard where I can get the parts from :)
