Author Topic: ms pacman high score not saving, my mame.ini file is attached  (Read 8601 times)
squirrellydw
  • Last login:April 12, 2021, 11:30:22 am
I am using mame 113 which has been recompiled and I have the highscore.dat file in the hi folder in the mame folder, any idea why it won't save?  Do I need to use a different version of ms pacman, I am using the master now.
I b**ch. People listen!!
Thenasty
  • Trade Count: (+17)
  • Last login:September 07, 2026, 10:30:25 pm
Re: ms pacman high score not saving, my mame.ini file is attached
« Reply #1 on: June 16, 2007, 05:00:20 pm »
officail MAME don't support hiscore.dat anymore. YOu need to use a unoffical build to use the dat.
Free VGA Breakout Cable
squirrellydw
« Reply #2 on: June 16, 2007, 07:20:26 pm »
I am I had someone recompile it for me.
squirrellydw
« Reply #3 on: June 17, 2007, 10:00:20 am »
Anyone?  This is really the whole reason I build my cab.  This is the most important thing for me, I don't know what I am doing wrong.  Unless it wasn't compiled right, anyone wanna compile 113 with all the fancy stuff for me?
moriartyds
  • Last login:November 05, 2007, 09:09:39 pm
« Reply #4 on: June 17, 2007, 03:20:09 pm »
It's really not that hard to compile your own, and that way you can be sure it's done correctly.  Just ask questions here, follow the instructions on the Mr Do page (see the highscore.dat sticky in the software forum).
squirrellydw
« Reply #5 on: June 17, 2007, 06:52:19 pm »
One problem is I have a Mac and my PC is in my cocktail table not that I can't use it but its not the easiest
TOK
  • The Game Always Wins
« Reply #6 on: June 17, 2007, 07:09:46 pm »
Just go backward in revisions. I stopped at .99, because I felt they actually started going backward shortly afterward, removing features and slowing emulation.
squirrellydw
« Reply #7 on: June 17, 2007, 07:43:17 pm »
If I do that what issues might I have by using a 113 ROM set?
TOK
« Reply #8 on: June 17, 2007, 08:41:25 pm »
Try the games you want to use, you may find they work fine. Perhaps a ROM manager like ClearMAME pro (?) can fix them if you need to roll back.
SGT
  • Last login:March 04, 2026, 07:39:32 pm
« Reply #9 on: June 17, 2007, 10:09:16 pm »
Well I don't have mine in front of me, but I think the hiscore.dat file goes into the same folder as mame.exe.  The hi folder is where the high scores are saved.  May be wrong, but that's the way I remember doing it after compiling.
Also by highscore.dat, I assume you meant hiscore.dat.
« Last Edit: June 17, 2007, 10:12:19 pm by SGT »
squirrellydw
Re: ms pacman high score not saving, FIXED
« Reply #10 on: June 17, 2007, 11:36:04 pm »
woohoo, I figured it out.  My mame dir was set to read only   :banghead: :banghead:
moriartyds
« Reply #11 on: June 18, 2007, 10:27:38 am »
Well, if you run into any other problems, check to see if you have a folder lableled "HI" in your mame directory.
