Author Topic: vga to component?  (Read 4188 times)
shorthair
vga to component?
« on: May 16, 2007, 11:06:43 pm »
I was thinking of getting a cheap 27" TV and checking out how games'll look. Will a vga to component (I guess it's a breakout cable, right?) work at all?...perhaps with some powerstrip help?
Joystick Jerk
  • Last login:June 26, 2024, 05:10:33 pm
  • Slave to the stick.
Re: vga to component?
« Reply #1 on: May 17, 2007, 01:51:20 am »
Generally not. Some ATI cards came with a dongle to convert signals in this way, but they required the specific card to be used along with them since it wasn't just a wire conversion. Does your video card not include an S-Video jack? Most cards made in the last 6 or 7 years have one.
shorthair
« Reply #2 on: May 17, 2007, 02:17:58 pm »
A little while ago, I was thinking of trying a TV out and thought this might work so bought a this type of cable, thinking the signal quality would be better, and that it might be less fuss than going the DVI/dongle route. I don't think I can return it now, but it was only 12 bucks.
ahofle
    • Arcade Ambience Project
« Reply #3 on: May 17, 2007, 02:26:43 pm »
You need a color space converter, not just a cable adapter.
Something like this:
http://www.zantech.com.au/cyp/cp265.html
shorthair
« Reply #4 on: May 17, 2007, 10:22:23 pm »
That unit appears to be the wrong direction: component in, outputting to component or RBG. I would need it the other way.
Hmm. I don't know why they'd make such a cable as I have, then. Maybe I can return it. It is a bit past the return period, but I still have the receipt.
Joystick Jerk
« Reply #5 on: May 18, 2007, 06:42:03 am »
The cable you have is meant for either monitors or output devices that can do colourspace conversions on their own. Which is fairly rare, but some devices can.
You can also find more options if you look for a device called a video transcoder. Still, most aren't cheap.
ahofle
« Reply #6 on: May 18, 2007, 11:16:28 am »
Google for "vga component converter":
http://www.smarthome.com/777060.html
shorthair
« Reply #7 on: May 18, 2007, 02:59:04 pm »
J J : Ah, well there you go. I guess I'll try to return it.
ahofle: yeah, I think FF still has one of those for a little less than that, though I think that's probly the best 'new' price I've seen. I'm only interested in tinkering so that much money isn't in the budget. Thanks, though.
FrizzleFried
    • Idaho Garagecade
« Reply #8 on: May 19, 2007, 02:19:38 pm »
Yup...I have that exact little box for sale still.  Hell,  I forgot what I was asking...I think it was like $90 shipped.
ahofle
« Reply #9 on: May 19, 2007, 05:36:33 pm »
How well did it work?
rhett
  • Last login:November 19, 2007, 01:36:31 am
« Reply #10 on: May 21, 2007, 05:15:19 am »
I'm totally confused about how you use a space converter along with a vga component converter.
FrizzleFried
    • Idaho Garagecade
« Reply #11 on: May 21, 2007, 03:55:34 pm »
It works pretty damn spiffy.  I'd give the image quality a 7/10 on my old analog HDTV and 10/10 on my digital HDTV.   It's nice.
8way
  • Last login:February 03, 2017, 05:52:21 am
  • This is my BOOM stick!
« Reply #12 on: May 25, 2007, 10:24:38 am »
     You can do VGA to COMPONENT on any RADEON card with a driver hack and a DIY VGA to COMPONENT cable.
Things you need:
            1.   ATICVPatch.zip (http://www.myav.com.tw/forum/showthread.php?s=48ac19ee7c95dfd22760bf9fbc3af485&threadid=184534&perpage=12&pagenumber=10)
            2.   Power Strip
            3.   The parts to make your VGA to COMPONENT cable (Radio Shack)
     Fallow the instruction found here (http://www.avsforum.com/avs-vb/showthread.php?t=212199&page=1&pp=20). Disregard the registry entries and it only working on Windows 98. ATICVPatch works in XP now and it does it all for you. Just use the site for making the VGA to Component cable and to basically see what you’re actually doing. By the way this does not work on newer ATI drivers so you need to use older ones. I tried it and it works pretty well. The only downside is you don’t get a display till windows loads. And the glitch in ATI’s drivers that cause the advanced display menu to disappear after this hack suck too. And that’s why you have to use powerstrip to setup the resolution.
shorthair
« Reply #13 on: May 25, 2007, 03:55:29 pm »
Above and beyond, in more ways than one. Thanks.
