Author Topic: Will the Benson 27" monitor fit this Killer Instink 2 cab?  (Read 2118 times)
eclypse
  • Last login:September 03, 2007, 11:43:10 am
Hello,
Can someone tell me if the 27" Benson monitor http://www.betson.com/products/IMP-44-4070-RT fit this cab?? Its a former Killer Instink 2 cab made my Midway.
It has a 25" monitor now.. The cab is 26 3/4" wide and the monitor is 23.5 24" wide.. Just dont know if its gona fit with the brackets.
ahofle
    • Arcade Ambience Project
eclypse
Re: Will the Benson 27" monitor fit this Killer Instink 2 cab?
« Reply #2 on: May 15, 2007, 06:17:38 pm »
Thanks man! I guess thats means its a go.
Joystick Jerk
  • Last login:June 26, 2024, 05:10:33 pm
  • Slave to the stick.
« Reply #3 on: May 15, 2007, 07:00:54 pm »
Have you opened her up yet? The bracket width doesn't come into the equation. The monitor rests on top of the brackets, so there's no bracket metal between the mounting frame on the monitor and the side of the cab. Speaking of brackets though, if you do want to upgrade to a 27", you'll need to get some new brackets because I believe the brackets in the KI cab are of a fixed width. Slikstik has a decent set of adjustable brackets that should work fine in mounting a 27" monitor in your cab.
eclypse
« Reply #4 on: May 15, 2007, 08:30:47 pm »
Last night when i was messing with it and cleaned it out i noticed that the brackets looks like they were adjustable.. meaning the bolt position could slide either way as it had a long bolt track.. heh dont know how else to describe it.
I guess i'll have to take another look and possably a pic just to make sure it will work.
I may be doing a cap kit for the monitor i have now.. so either way i'll get a better look at the mounting brackets.
Thanks for the info though.. Atleast i know where i can find the brackets if i need them.
